20 Most Recent Amphion Mediaworks T342 System Questions & Answers
If you are seeking the code to operate a DVD player, it would be generated by the remote if the remote has programming capability.
Amphion... | Answered on Jun 03, 2014
did you program the remote? or was it standard? if you did all of this it sounds like a new remote is in order,but I'd get the codes from the maker and instructions on reprogramming it,if that fails you need a new one
Amphion... | Answered on Feb 24, 2014
You can find the owners manual at manualfox.com - this should help.
Amphion... | Answered on Aug 27, 2011
try safemanuals.com or elitezoom.com
For the owners manual ask here, they can get every Amphion Mediaworks manual:
http://manualfox.com/link/amw.htm
Amphion... | Answered on May 18, 2011
Here is the AMW T342 manual
Hi, well first that R6, that seems burnt, I suspect that the actual resistance is probably OK, resistors seldom go faulty, insomuch that they change their resistance a bit, usually they are either the right value, short circuit, or open circuit, rarely is there just a change in value, that reading of 64K, may indeed be right. But not always
the Wattage depends usually on the size, they come in 1/8th Watt, very small, Grain size, 1/4 Watt about 2mm x 5mm, 1/2 watt is larger, about 3mm x 10 mm, 1 watt is a large 5mm x 15 -20mm.
The ONLY thing that can cause a resistor to overheat and discolor is an overload, meaning something AFTER that component is drawing too much current, usually because there is a short circuit, or near to, somewhere after that discolored component.
The color code for a 700 OHM resister would be Violet, black, black.... if it is a 64K, then the code is, Blue, yellow orange. (There is also a four/five band type code too, in that case they would be Violet, black, black, black, & Blue, yellow, black, red.)
See chart below.
http://www.google.co.nz/imgres?imgurl=http://www.leonaudio.com.au/res-code.gif&imgrefurl=http://www.leonaudio.com.au/res_code.htm&h=1018&w=686&sz=27&tbnid=eNAR-clnfWTcKM:&tbnh=150&tbnw=101&prev=/images%3Fq%3Dresistor%2Bcolor%2Bcode&zoom=1&q=resistor+color+code&usg=__hEZmxaXf7C2iMX8UMfaNU1LxHNY=&sa=X&ei=8Vh1TYnsOYy0sAOO173MBA&ved=0CC4Q9QEwAg
Amphion... | Answered on Mar 07, 2011
You may be able to however I have no codes for this so you will need to perform a power scan, follow these instructions:
***** Before starting: Hold the aux button down for four seconds or until all four lights at the top are lit hit 222 then (#) pound.
  1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate (about 3 seconds), then release.
  2. For AUX mode Power Scan ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
  3. Press and release the Power button.
  4. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
  5. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  6. To verify the code works try several different functions for that equipment
Daniel Busa
DISH Network Customer Service
Amphion... | Answered on Jan 25, 2011
you have to reset the system you have to take a disc out and setup your speaker system again reference your product manual.
Amphion... | Answered on Apr 07, 2009
You can use an all in one remote to work most of the features. I have one of the newer models. (sorry don't know the model #) but I had to contact the all in one customer service and they helped me with a procedure to load the code to make the remote work with the AMW player.
Amphion... | Answered on Feb 07, 2009
http://newamw.pgeco.com/language.php
Its a European link. They don't seem to have a North American site.
Amphion... | Answered on Jan 26, 2009
you need to get the optical digital audio cable
Amphion... | Answered on Dec 24, 2008
you need to start the system without a disc then go into setup and reprogram the system for audio setup
Amphion... | Answered on May 04, 2008
I just found the unlock code for the t342 says to turn player on without a disc insetred then press setup go to preferences press 1379 select region 0= multiregion
i,d suggest laser head problem.
Dirty-weak laser unit. try a head cleaning disk.
Mike @ compurepair.
Amphion... | Answered on Apr 30, 2008
Amphion Mediaworks T342 System Logo
21 questions posted
Top Amphion Mediaworks Audio Players & Recorders Experts
Marvin
Marvin
jakesaints
Level 1 Expert
Tom Chichester
Are you an Amphion Mediaworks Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Amphion Mediaworks Audio Players & Recorders
Most Popular Question
help me
  • Audio Players & Recorders
