20 Most Recent Sanyo DWM-2500 System Questions & Answers
contact people who made it.
Sanyo DWM-2500... • Answered on Feb 07, 2013
In stereo, yes. At a minimum your PC should have a headphone output and/or a rear-panel stereo speaker output (usually 1/8" green), which is essentially the same. Get into the audio controls and set whichever you use to be Large Stereo speakers.
Get an adapter for the 1/8"-stereo-to-RCA-cable pair and attach it to the only analog audio input on the Sanyo.
Sanyo DWM-2500... • Answered on Dec 14, 2010
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Sanyo DWM-2500... • Answered on Feb 03, 2009
I get all the sound I need but I can't play the TV through the sound system. It is a samsung DB390. Can play DVD's through the system but not the TV. Any ideas?
Roger
Sanyo DWM-2500... • Answered on Jan 26, 2009
Check that the speakers wiring are correct, refer to the user manual diagrams to verify.
Try swapping the Speakers connections to test if the single speakers are working.
Ensure that sound mode is set to 5.1 or to the desired output, if this is 2.1 for example, you will get only three speakers working.
If the problem is none of the above, than the unit may be defective.
Sanyo DWM-2500... • Answered on Dec 22, 2008
You most likely are not meeting the specs required by the player. Check the manual on the cd for the specs the player can resolve or use the converter on the cd to convert your mp4's wmv to meet the specs.
Sanyo Audio... • Answered on May 07, 2021
Is your tv compatible with wireless speakers?
Sanyo Audio... • Answered on Mar 07, 2021
Use code search on your Sanyo URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
Sanyo Audio... • Answered on Dec 21, 2020
There might be a diagram but I haven't seen any belt fitting diagrams at all, merely the odd exploded view. Replacing cassette belts is as much fun as a jigsaw puzzle - you keep removing screws and parts until you can fit the belt and then you reverse the process...
Sanyo Audio... • Answered on Jul 04, 2020
Hello Hannes, FM ANT, is the connection of the antenna to receive FM radio stations (Frequency Modulated) Here you can connect a cable of approximately 1 meter, and use it as an antenna, depending on where you are, rural or remote areas. the city, you might need an external antenna, similar to those used for analog TV reception I sent you a link to download the user manual of your Sanyo Greetings Franco Dosil Hola Hannes, FM ANT, es la conexion de la antena para recibir estaciones de radio de FM (Frecuencia Modulada)Ahi pedes conectar un cable de 1 metro aproximadamente, y lo usas como antena, dependiendo de donde te encuentres, zonas rurales o alejadas de la ciudad, podrias necesitar una antena externa, similares a las usadas para recepcion de TV analoga te envio un link para que descargues el manual de usuario de tu Sanyo Saludos Franco Dosil https://mans.io/files/get/499596 https://mans.io/item/sanyo/dc-da1460m https://elektrotanya.com/sanyo_dc-da1460m_micro_component_system_sm.rar/download.html
Sanyo Audio... • Answered on Jun 18, 2019
Hello Walter, what do you want to repair in your Sanyo DC-D37U, the mechanism of the CD player? I sent you the link to download a Service Bulletin of those mechanisms I hope you can repair it, comment the results Greetings Franco Dosil Hola Walter, que es lo que quieres reparar en tu Sanyo DC-D37U, el mecanismo del reproductor de CD? Te envio el link para que descargues un Boletin de service de esos mecanismos Espero puedas repararlo, comenta los resultados Saludos Franco Dosil https://www.dtforum.info/index.php?action=dlattach;topic=7137.0;attach=9887
Sanyo Audio... • Answered on Jun 02, 2019
Sanyo DWM-2500 System Logo
Popular Tags
11 questions posted
Top Sanyo Audio Players & Recorders Experts
 Mikey
Mikey
ray gallant
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Audio Players & Recorders
Most Popular Question
get new remote mine no longer workes
  • Audio Players & Recorders
