20 Most Recent Amphion Mediaworks M-510 Portable DVD Player Questions & Answers
How can I replace the battery?
Check the bottom of the the other side,there is a square plastic plate with a four small philip screws.Take out those four small philip screws there should be a square Litium battery behind that plastic plate.
12/15/2010 8:02:54 PM • Amphion... • Answered on Dec 15, 2010
Need replacement battery
You can try googling the internet or contacting customer support to see if U can get a replacement battery. Is the battery taking some kind of a charge? If it is taking a charge that lasts a short time, U can get by by checking the players ac in voltage. Example: If it is 9 volts, U can get a 6 d cell battery holder from the internet, and go to batteryspace.com and go into wires and connectors. Get the two prong wire that has an two alligator leads on the other end. You can buy a universal 6V-12V battery pack charger from this site, and get the powerizer 10000 mah rechargeable d cells to boot. U might want to use the .9 Amp setting, or the 1.8 amp setting if yopu are feeling adventurous. The powerizer batteries have sometimes leaked, especially the smaller C size when using this setting(1.8 amp) The site also sells compatible tips that will fit that connector. If the battery cannot take ANY kind of a charge, what kind of battery is it? If it is built in, youre in luck. If it is a clip on detachable type, U have a problem as the cutoff voltage with those type of players is typically higher on the ac in jack since the player isnt recognizing that discharged battery pack is still connected. For that, you could try a 8 d cell battery holder and just use alkalines if you don't want to risk cell reversal with your rechargeables, or just get the 8.4 Volt battery pack that site sells. I also recommend accupower evolution low self discharge rechargeables, found at thomas distributing.com id U have the cash. Good luck, and let me know how it turns out. Hint: the voltage rating of the battery power supply listed on the player may be lower than the AC in jack. Consult your manual. Use the specifications used in the battery listed. A 7.4 lithium ion pack or a 7.2 nimh battery pack will work if it is basically a 9 volt circuit. A 7.4 litium ion battery included with the player would mean you would use 6 D cells inserted in a battery holder hooked to this unit.
5/4/2009 7:18:24 PM • Amphion... • Answered on May 04, 2009
3answers
Need user manual for Amphion MediaWorks (AMW) M520 Portable DVD player
Hi, You should be able to get what you need from: PGE Corporation Limited Unit 3 Newmarket Court Kingston Milton Keynes MK10 0AG Tel: +44 (0) 870 1280 880 Fax: +44 (0) 870 1280 878
7/20/2007 10:20:50 AM • Amphion... • Answered on Jul 20, 2007
Where can I get a replacement remote control for an Amphion MediaWorks DVD player?
Amphion is no longer in business. Look on the web for a universal which will work and then find the codes you need. Both are on the net.
5/8/2015 7:15:46 PM • Amphion... • Answered on May 08, 2015
Need universal code for: T365
ello brass..... Here is an excellent link to almost all of the codes... http://www.remote-codes.com/
Joe
Thanks for choosing fixya!
12/8/2010 4:01:40 AM • Amphion... • Answered on Dec 08, 2010
Remote Control
1800-remotes.
1/2/2009 5:46:32 PM • Amphion... • Answered on Jan 02, 2009
Where can I find a
For a replacement remote for your model, click on the blue link www.remotes.com and you will find one there. The original remote is no longer manufactured, but they offer a replacement that is as close as possible to original. The price is $39.95. If you want exact, I'd go this route. If you want something not as pricey, you can always opt for a universal remote and you can purchase those anywhere. Hope this answered your question. Please take a few seconds to rate how helpful this post was for you. Thanks and good luck. [email protected]
9/19/2008 2:14:04 PM • Amphion... • Answered on Sep 19, 2008
2answers
Can you cast or mirror with this TV from Android device
Yes you can EXCEPT You give zero clue of the devices. all questions need 'make model (what it is)' and in you case you need TWO of those. Mirror your Android phone or tablet screen to the TV
  1. From your Android phone or tablet, open the Google Home app.
  2. Tap the left hand navigation to open the menu.
  3. Tap Cast screen / audio and select your TV.
Chromecast built-in - Learn - TV - Google
3/22/2023 6:06:15 AM • Televison &... • Answered 10 hours ago
2answers
2answers
Hi. Where can I purchase a replacement battery for my portable DVD player? Model BAT-09?
It can bought from most of the electronic spare part selling shops.
3/21/2023 3:36:06 PM • Televison &... • Answered Yesterday
I have a thin purple vertical line running down my screen from my webcam, How do I fix this?
If the thin purple vertical line is only visible when you are using your webcam, then it might be a hardware issue with your webcam or the cable connecting it to your computer. Here are a few things you can try:
  1. Disconnect and reconnect your webcam: Unplug your webcam from your computer and plug it back in again. Sometimes, the connection can become loose, causing issues with the display.
  2. Update your webcam drivers: Check if there are any available updates for your webcam drivers. Go to the manufacturer's website and search for the latest driver for your webcam. Download and install it on your computer.
  3. Test your webcam on another device: If you have another device with a webcam, try connecting your webcam to it and see if the purple line still appears. If it doesn't, then it's likely an issue with your computer.
  4. Replace your webcam: If none of the above solutions work, then it may be time to replace your webcam.
3/21/2023 8:22:23 AM • Televison &... • Answered Yesterday
Onn tv Stuck in Burn Mode
It sounds like you have already done some troubleshooting by replacing the TCON and main boards, but you are still encountering issues with the TV being stuck in burn mode. Here are some additional steps you can try: Power cycle the TV: Turn off the TV and unplug it from the power source for a few minutes, then plug it back in and turn it on again. Check the cables: Make sure all cables, including the HDMI and power cables, are securely connected to the TV and any external devices. Reset the TV: Look for a "reset" or "factory reset" option in the TV's menu settings. This will restore the TV to its default settings and may help resolve the issue. Contact the manufacturer: If none of the above steps work, you may need to contact the manufacturer for further assistance. They may have additional troubleshooting steps or be able to repair or replace the TV if it is still under warranty. Hopefully, one of these steps will help resolve the issue with your TV being stuck in burn mode.
3/20/2023 11:22:47 PM • Televison &... • Answered Yesterday
I have just reset my telefunken TLEDDS 55FHD and now the colour has changed how do I fix that
When you reset your Telefunken TLEDDS 55FHD, the TV's picture settings may have been reset to their default values. This could be the reason why the colors on your TV may have changed. To fix this, you can try the following steps:
Go to the TV's settings menu: Press the "Menu" button on your remote control and navigate to the "Picture" or "Display" settings.
Adjust the color settings: Look for options such as "Color Temperature," "Color Saturation," "Tint," and "Sharpness." Adjust these settings until you achieve the desired color output.
Use a calibration tool: If you have a calibration tool, you can use it to calibrate your TV's color settings to your liking.
Perform a factory reset: If you have tried the above steps and the color output is still not satisfactory, you can perform a factory reset. However, note that this will erase all your settings, and you will have to set up your TV from scratch.
If none of these steps work, you may need to contact Telefunken's customer support or take your TV to a repair center for further assistance.
3/20/2023 10:00:02 AM • Televison &... • Answered 2 days ago
Where is the reset button on the veon remote?
The location of the reset button on a Veon remote control may vary depending on the specific model, but in general, the reset button is usually located on the back of the remote control. Look for a small, circular button that may be labeled "Reset" or "RST". To reset the Veon remote control, press and hold the reset button for a few seconds until the LED light on the remote control turns off and then turns back on again. Release the reset button, and the remote control should be reset to its default settings. If you're unable to locate the reset button on your Veon remote control, consult the user manual or contact the manufacturer for assistance.
3/19/2023 7:39:23 PM • Televison &... • Answered 2 days ago
2answers
Siemens heliophos 4e wiring diagram
It is important to consult the user manual or contact the manufacturer directly for any technical information or support related to a specific product. They will be able to provide you with the most accurate and up-to-date information on the wiring diagram for the Siemens Heliophos 4e X-ray machine.
3/19/2023 3:05:33 PM • Televison &... • Answered 3 days ago
2answers
How do I scan the TV clc501 for channels? I don't see a button for (antenna) to scan channels. I am only getting 2 channels, any help would be appreciated.
I can provide some general steps on how to scan for channels on a TV: Make sure that your TV is connected to an antenna or cable input. Turn on the TV and go to the main menu or settings. Look for an option to scan for channels or auto-tune. This option may be labeled as "Channel Setup" or "Channel Scan." Select the option to scan for channels and wait for the TV to complete the process. This may take several minutes. Once the scan is complete, you should see a list of available channels on your TV. If you're still having trouble, I suggest referring to the user manual that came with your TV for more specific instructions. Alternatively, you can try contacting the manufacturer's customer support for assistance.
3/19/2023 3:02:51 PM • Televison &... • Answered 3 days ago
2answers
MD-1700 keyboard lights up but won't do anything?
Based on your description, it sounds like your Blaupunkt 32-inch flatscreen TV may have a damaged screen. The ink-like appearance and brief flicker followed by a dark screen are indicative of a physical crack or damage to the screen. It is possible that the TV was able to function normally after the fall, but over time the damage to the screen worsened and is now causing the issues you are experiencing. Unfortunately, this type of damage is typically not repairable and would require a replacement of the entire screen, which can be costly. If the TV is still under warranty, you may be able to get it repaired or replaced through the manufacturer. Otherwise, you may need to consider purchasing a new TV if the cost of repairing the the screen is prohibitive.
3/19/2023 2:49:46 PM • Televison &... • Answered 3 days ago
2answers
My fukuda 32 led tv no panel settings. How do i get the mirror settings?
Have you replaced the main board in the TV by chance?
3/19/2023 2:36:16 PM • Televison &... • Answered 3 days ago
Amphion Mediaworks M-510 Portable DVD Player Logo
6 questions posted
Top Amphion Mediaworks Televison & Video Experts
Marvin
Marvin
Are you an Amphion Mediaworks Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Amphion Mediaworks Televison & Video
Most Popular Question
need replacement battery
  • Televison & Video
