20 Most Recent
Sharp 32R-S50 32" TV Questions & Answers
When I turn the TV on it makes the same sound it
yea that's weird, hate when stuff like that happens, double check all your connections etc. including cable. It may require calling mfr. tech support, which you will need model # name of unit etc. if a major brand, should have some tech support to go to
How much can i sell this tv used
If you are in the US or other area that has only digital signals now, it could only be used with a converter or with some remaining cable and satellite providers.
Not worth much-
Coax connector
looks like you have to replace the the tuner part (thats the slim silver box where the coax connector was ) if your handy with this solution and can repair it yourself , then you need to go to a SHARP authorized dealer to purchase the part or leave it there for repair . let me know if this helpful, thanks AJ
No channels?
Try going into the setup menu and make sure the ANT input is set to cable. Then look for Auto Program or Channel Setup and let it scan and find all the channels it can receive. After it's done you should be able to go up and down through the channels.
Faint blue vertical bars on screen
What you see on your screen are retrace lines, it can happen for various reasons. Jut lower the screen voltage by adjusting the knob specified as "screen" on the LOT, this will disappear.
Lost Remote
I personally would get myself a "Universal Remote".
These units will operate almost ANY unit that uses Infrared... Ya Punch a "Code" in for your particular TV etc, and thats it... total conrtol...
Same channel on all channels
Yeppers it certanly sounds like the tuner control curcuit or the tuner itself is bad. With the back off the set and the tV on, if you tap on the side of the tuner does the set start to work? if so the tuner has to be replaced
Sharp tele
hi
probably just a burned micro fuse on the board
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages.
good luck
How can I make the text sharp on Magnavox model 22ME601B/F7?
- Check HDMI Cable Connection: If you're using an external device like a cable box, gaming console, or streaming device connected to the TV via HDMI cable, ensure that the HDMI cable is securely plugged into both the TV and the external device. A loose connection can cause intermittent resolution adjustments.
- Adjust Picture Settings: Navigate to the TV's menu and check the picture settings. Look for options related to display resolution, aspect ratio, or picture mode. Ensure that the settings are configured correctly for your viewing preferences. Try resetting the picture settings to default and see if the issue persists.
- Update Firmware: Check if there are any firmware updates available for your TV. Sometimes, software updates can fix bugs or issues related to display resolution adjustments. You can usually check for updates in the TV's settings menu or visit the manufacturer's website for instructions on how to update the firmware.
- Check Signal Source: If you're experiencing resolution adjustments while watching content from an external device, such as a cable box or streaming device, make sure the signal source is sending a consistent signal. Issues with the signal source can sometimes cause the TV to adjust its display resolution.
- Reset TV: Try performing a factory reset on your TV to restore it to its original settings. Keep in mind that this will erase any customized settings and preferences, so you may need to set up the TV again after the reset.
- Contact Magnavox Support: If the issue persists after trying the above steps, it's possible that there may be a hardware problem with the TV. In this case, it's recommended to contact Magnavox customer support for further assistance or to inquire about repair options.
By following these troubleshooting steps, you should be able to diagnose and resolve the issue of your Magnavox TV constantly adjusting its display resolution.
Hope this helps
