20 Most Recent
Sharp Aquos LC-15S1E 15 in. LCD Television Questions & Answers
Sharp lc15s1e
the red light is
First unplug the unit from the outlet for 1hr.
Before you plug it in, press and hold the power button key at the front panel for 1 minute to drain the boards from voltages and make it reset itself.
Plug back in the unit and then try if the symptoms still persist to assist you further.
Jdvillanueva
Sharp TV LC60LE745U the screen remained black and an arrow on the bottom of the TV stay blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
