20 Most Recent
Leadtek WinFast PVR2000 Video Capture Questions & Answers
Hi im a doctor doing cardiac ultrasound and we
There are a whole load of Video latch on devices for a PC, which, in my view are fairly useless.
I'd go down the route of buying a DVD recorder with a hard drive. You'll need one with an S-Video input. And many now step this up to certainly 720P for a high def, output (HDMI) Newer ones will probably step up to 1080p.
The flexibility of a DVD recorder with a HDD will allow you to record as many takes as you want, edit and title them, also write to DVD if desired.
I'd go for the machine with the largest possible hard drive I could afford, these high def data files are usually pretty huge. Especially when uncompressed.
Worth checking for one that also has a USB port for quick file transfers.
Finally, if funds are available, then a Blue Ray recorder with a Hard Drive. Again make sure you have a S-Video input, USB port and the output ports you need. Blue ray will by definition mean you're using high def. quality video.
Oh ......... check that the box that you do buy also has a suitable connection for the monitor you're using.
Here's a url for the wikipedia website on the subject:-
http://en.wikipedia.org/wiki/High-definition_television
Towards the bottom, there are links to Extra High def 1440p and Ultra high def 4320p
I would imagine we're stepping into the realms of financial fantasy with this stuff, but its worth a read.
Can i use microphon on
No , you cannot use microphone on WinFast PVR2000 . The two audio jack is for audio input ( L & R).
Thanks
Please rate me if you got a satisfied answer
Audio
if you are having trouble with the sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
No sound from WinFast PVR2 tuner card
i looked at my windows xp winfast and i discovered that the audio was working only with the realtek hd audio
now the link is here and u can chose the driver:D:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
I can't reinstall divre for tuner pc card
first install the software/driver. make not to connect the tuner card.
next, insert the card then let it detect by itself. if it doesn't work then ask for a new driver. also be aware of your driver is match with your operating system.
When I try to access PVR2 on my computer it tells
Ok that simply means that the DirectX "Graph" or the way the filters are loaded and used, via DirectX are not being loaded or found, for many reasons. This could be a Filter not present, or a "Pin" cannot be found. You need to have all Filters installed and registered. You need the the MPEG 4 and MPEG2 Filters installed and registered. CoreAVC is real good. You should load the software that came with your card and install that and the driver. then install all CODECS and Filters I wonder if a simple re-registering all your filters will not fix it. try that. Also try installing WinDVD, that will install CODECs that may be missing, you need to get HDTV codecs that will help,also reinstall the software and drivers that came with the card.
www.free-codecs.com › Tools › Digital Radio - TV -
http://www.free-codecs.com/Software/Digital_TV.htm
At the link above, download the Amcap software it will allow you to see and use the card.
http://en.wikipedia.org/wiki/DirectShow
link above explains about graphs
No sound
It uses your computer's standard sound card. You should plug the audio output from the TV card into the Line In on your computer's sound hardware.
TV Tuner viewing
When running TV, click anywhere on it's screen, this will produce a 'drop-down window' within screen.
You can select the "Always on TOP" option.
You can also grab BORDER, with mouse, to resize it to whatever size you want.
Audio only capturing through one speaker
Check the mixer and make sure that the recording source used for capturing is enabled and that the channel is set for stereo by making sure that the balance is in the middle.
