20 Most Recent
Vizio XWR100 Wireless Router Questions & Answers
I can't complete the setup
OK... Have you checked the settings of the LAN card in your PC? It should either be set to DHCP or 192.168.1.2 for the IP address and 192.168.1.1 for the gateway.
Where is the password on the router
Open firefox or opera in the address box put 192.168.1.1 for your version of router the login name and password name are unknown on the site i am using so you are on your own from there
Www vizio com
Access your router page i.e by accessing your IP of the router; the username and password of the page is by default admin.Thereafter go to the wireless settings where you can change the username and password of your network.You can also avail our technical support by visiting our website: http://www.vtechsquad.com
What does error I/O has occured mean
Follow this which may be help you..http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/an-unexpected-io-error-has-occuredfilebootbcd/793dadd6-bedb-4be2-8f55-be25f92a3470
The router will not stay
The first thing that I would do is to reset the router to restore its internet if only for a few minutes. Then follow the link to get the latest firmware for that router. Through the web interface flash the firmware to the latest version. For instructions on how to flash the firmware, they are on page 10 of the manual available at the second link below.
Cheers
http://www.vizio.com/xwr100.html#support
http://70.168.148.201/documents/downloads/accessories/XWR100/549XWR100%20User%20Manual.pdf
Need installation instructions
The short and shinny setup
- With your modem plugged in and running.
- Plug in the Ethernet cable that came with the router into the Ethernet port on the modem and the other end into the port label "WAN or Uplink"
That's it. Some additional steps I would take are to log into the router and setup WPA2 wireless security if it is not already enabled by default. This will keep unwanted people off your network.
Hhow do i get it towork wirelessly
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledi
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
hope this helps
