20 Most Recent LG GH22NP21 DVD-Writer - Internal Double-layer - DVD-RAM/ R/ RW - 22x 8x 16x (DVD) - 48x 32x 48x (CD... Burner Questions & Answers
DRIVERS FOR NERO BURNING ROM
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver if you physically unplug your cd/dvd restart your computer the plug it back in the found new hardware wizard should activate if you dont have motherboard disk you will need to download the drivers http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
hope this helps
9/16/2012 8:06:53 AM • LG GH22NP21... • Answered on Sep 16, 2012
Download driver gh22np21
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver hope this helps http://download.cnet.com/lg-gce-8520b-firmware/3000-2122_4-10203021.htmlThe new firmware offers enhanced recording speed of some CD-R media on your LG GCE-8520B CD-R/CD-RW
8/10/2011 3:05:02 AM • LG GH22NP21... • Answered on Aug 10, 2011
I have dvd /rw model
if it is internal cd drive it actualy auto detect on the computer, you can see it on my computer all you need to install is the software for burning
8/4/2011 4:47:39 PM • LG GH22NP21... • Answered on Aug 04, 2011
CAN I WRITE AUDIO CD
yes, you can write it in 1x or even 42x if you want. The only thing that can happen is a chance of data loss but not quality. Also some older stereos could run into issues not just cuase of the write speed but cd incompatibilitiy. Audio CDs are nothing more than WAV files written on a CD and then a table of contents added as a CDFS file system.
6/29/2011 2:53:12 PM • LG GH22NP21... • Answered on Jun 29, 2011
Burner slows when writing. takes
make sure your cd/dvd burner is getting consistent power test all of the leads that attach including electrical to your cd/dvd burner make sure the connections are good and dust free or just replace they might be faulty
6/17/2011 3:11:35 PM • LG GH22NP21... • Answered on Jun 17, 2011
Hi! I need driver for GH22NP21
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver hope this helps
6/1/2011 9:41:03 PM • LG GH22NP21... • Answered on Jun 01, 2011
I need the driver of
you might have to physically unplug the leads for this dvd rw then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools computer management device manager scroll to cd/dvd drives + expand you could see a yellow eclamation mark ! or yellow question mark or a red x any of these you need to update the driver right click select update driver hope this helps
5/17/2011 9:54:13 PM • LG GH22NP21... • Answered on May 17, 2011
Hola, mi quemador dvd modelo
Los quemadores de DVD cuentan con dos unidades de laser. Un laser es para quemar y leer discos DVD. El otro es para leer discos CD. Es muy común que el uno o el otro falla. Si el aparato todavía está bajo la garantía, puede Ud. pedirles quemador nuevo. Si no, tal vez haya llegado la hora de comprar un nuevo. Lo bueno es ya no cuestan mucho... meno de $30 por quemador de buena marca.
5/10/2011 8:08:17 PM • LG GH22NP21... • Answered on May 10, 2011
0answers
3answers
Cant get burner to reconised on pc
Since this is an IDE drive, please check the Master/Slave/Cable Select jumpers, if you've connected the drive in the same cable of your hard drive, you should check its jumper settings, if hard drive is set as Master, the DVD writer it should be as Slave, if the hard disk jumper is set to Cable Select (CS), the DVD should be in the same way too. After this check if DVD drive is identified correctly in BIOS, it's a good idea to set drive detection as Auto, if this all is OK, check its driver in Windows, it must be appear as a DVD-RW drive.
3/3/2011 3:54:44 AM • LG GH22NP21... • Answered on Mar 03, 2011
Lg super multi securdisc driver
Optical drives (at least all modern one's) do not require a driver when run in a Windows environment. The OS provides the support automatically. Is the drive shown/listed in My Computer?
7/4/2014 5:39:12 AM • LG GH Computers... • Answered on Jul 04, 2014
Drivers needed
available here http://www.driverscape.com/download/hl-dt-st-dvdram-gh24ls50-ata-device
12/26/2013 7:11:55 PM • LG GH Computers... • Answered on Dec 26, 2013
What is the angle of polarized flim for LG Flatron E2240T?
See troubleshooting section of user manual on page 25 for help. https://gscs-b2c.lge.com/downloadFile?fileId=KROWM000342803.pdf For further help you can use this page LG E2240T-PN: Support, Manuals, Warranty & More ' LG India Support
1/7/2024 11:28:15 AM • LG Computers &... • Answered on Jan 07, 2024
LG GH22NP21 DVD-Writer - Internal Double-layer - DVD-RAM/ R/ RW - 22x 8x 16x (DVD) - 48x 32x 48x (CD... Burner Logo
22 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GH LG
  • GH LG
Most Popular Question
need driver gh22np21
  • Computers & Internet
