20 Most Recent
KDS Valiant 6480iPTD Notebook Questions & Answers
Iinstaled win xp, now monitor will not work. can i
Turn your notebook off.
Turn your notebook on, and immediately start pressing the F8 key, once or twice per second,
until you see the Windows "start-up" menu (white text over a black background).
Choose the "start in VGA (low-resolution") mode" (or some wording similar to that).
You computer will start-up in '800-by-600-by-256-colours' mode, which should work.
Adjust the screen-resolution, and the number of colours to "optimal" values.
KDS Valiant...
Answered
on Jan 31, 2011
KDS Valiant No Video at desktop (WinXP Pro)
there might be a problem with the VGA driver. while booting, repeatedly press F8 until you get the boot options (black screen with white text) with your arrow keys, you select "boot in VGA mode"
then you can easily reinstall the video driver.
KDS Valiant...
Answered
on Oct 02, 2010
Space bar does not work
Hello, Thomas.
I'd suggest flipping your notebook on its side and then over, lift/pull the space bar slightly with a flat screwdriver or other thin, flat object. First shake, then spray compressed air in the area.
Hopefully, something is lodged (like a paper clip or other small object) and will be removed.
If not, the space bar cannot be replaced, unlike other keys. So, you would need to replace your keyboard.
Hope this helps.
Hope this helps.
KDS Valiant...
Answered
on Dec 22, 2009
Try it with only the battery.
Try it with only the power cord without the battery.
If neither of these work, you most likely have a bad motherboard.
KDS Valiant...
Answered
on Sep 12, 2008
CMOS
u wann remove it so u can get in uslay buy a speaker in ther relly small looking 2 wires to it not avg desktop style ok usesaly covered also and they are very hard to find orginal replacement battery ok thx nick
KDS Valiant...
Answered
on Feb 03, 2008
How to disable the temperature sensor.
Are you aware of any power management settings in the bios which would be shutting the system down?
How long does it run before it shuts down?
Also check in the os for power management settings.
The power board indeed needs to be in place for the machine to operate.
Good luck.
KDS Valiant...
Answered
on Aug 12, 2007
Cannot Boot
Removing the cmos battery isn't always enough to reset the bios you may need to find the 'JBAT1' terminal on the mobo and put jumper across pins 2-3 then back to 1-2.
But it may be a faulty mobo where the charger connects to the board.
KDS Valiant...
Answered
on Feb 23, 2007
