20 Most Recent KDS Valiant 671DP Notebook Questions & Answers
needs a new lcd inverter
KDS Valiant... | Answered on Jan 16, 2010
Hi there.
Hold down the Fn key and look at the F keys for what looks like sun icon on them, use them to adjust the brightness up or down.
Good luck and thanks for using Fixya!!
KDS Valiant... | Answered on May 19, 2009
the hard drive is under the key board you have to slide out the end parts were the speakers are and pop up thew middle plastic part that powers up the lap top and there are two screws that come out for the keyboard then you will see the hard drive
KDS Valiant... | Answered on Mar 22, 2009
Contact the makers of your laptop and order the recover disk. They go around $40.00 to $50.00 dollars.
KDS Valiant... | Answered on Feb 15, 2009
It should, but there are other opions. Ever hear of ubunto? Its a free os you can download for free, Or go on Ebay and buy a disk of the os you are currently using. Should save a lot of money.
KDS Valiant... | Answered on Dec 29, 2008
The power supply and laptop are both hot because your fan isn't working. You'd know if it was working by the whirring sound it would be making. Send it in for service.
KDS Valiant... | Answered on Dec 28, 2008
Click 'start' than 'all programs' than 'accessories' than 'system tools' than 'system restore'. Then follow the directions.
what i will do is take the battery out and put it back in after you wait about 5 min if it doesn't work u might have to go in your computer like i'm prolly gon have to go in mine
KDS Valiant... | Answered on Dec 14, 2008
It is most likely a hardware problem. Try re-booting it. Sure you'll loose all your memory, but at least it will work again. If you go on the manufacturer's website, i am sure it will tell you how to do that.
Hope this helps!
sounds like it is time for a recovery disk install..hope you have one
KDS Valiant... | Answered on Oct 10, 2008
Right click on the desktop, select view, then select show desktop icon.
KDS Valiant... | Answered on Jul 01, 2008
It sounds like the screen inverter is going out. The inverter works in this way: The power supply cuts the amount of power going into the board down, however the screen needs more power to enable it to function properly, so the inverter boosts the power back up to a level that the screen needs. If the inverter starts to go out it can create a multiple amount of indications that are noticable on the screen, one of them is darkening of the screen. It could also be the screen itself, but I'm leaning towards the inverter.
KDS Valiant... | Answered on Jun 18, 2008
Wow. Never heard that one before. Here are a few ideas as they come off my fingers: 1. Try a reload of the operating system, what is referred to as a repair install. 2. You could try booting from a diskette and then try to find out what is wrong with the recognition of the mouse. 3. Perhaps hooking up a usb mouse? 4. Disable the laptop mouse in the bios, which hopefully you can get to before the hang. Take your pick and work from easiest to hardest. The boot looks like it is freezing on the laptop mouse, so if you want to get past that portion of the boot, you have to resolve it or blow away the code that is not recognizing the mouse, if you presume that the mouse is funcitonal. If not, fix the mouse. Hope this helps Karl
KDS Valiant... | Answered on Apr 19, 2008
first of all try to start your laptop in safemode
1 start laptop
2 continously press F8 key
3 when you see menyu select "start windows in safe mode"
if your computer starts with same mode and you see the desktop
then you just have to restore your xp with earlier system restore check point
and if you dont see desktop in safe mode also then you must have to install win xp again
steps for restore windows xp
1 start
2 programs
3 accassories
4 system tools
5 system restore
6 chose restore system to earlier time
then select any earlier date in calender at which computer is working properly
and click restore
it restores your xp and restart your pc and your problem will be solved
if still having problem then you must reinstall windows xp
KDS Valiant... | Answered on Mar 26, 2008
hi
it is not advisable to replace cmos bettery on your own if you are not aware of opening notebook
because each and every notebook wil lcome with its own tricky fittings
so if you dont know how to open your notebook
just go to ant technician and let them do it for you
first step: lay the screen fully down, then pry the two speaker covers outward. You may have to move the screen around to get them out.
second step: lift the center section containing the power button upward.
third step: loosen the two small phillips screws that hold the keyboard on.
fourth step: gently lift the keyboard up. There is a ribbon cable that plugs into a socket. There is a liftable tab on either side of the socket. Gently pry them up to release the ribbon cable and thus the keyboard.
fifth step: The hard drive is now visible. It is held in by three screws: one on the left and two on the connector. Once these three screws have been removed you can lift the drive out.
Take the old drive out of the holder and remove the connector. Install connector onto the new drive then secure into the drive holder.
Remainder of assembly is reverse of disassembly.
You may need to pry the ribbon tabs up to ensure that the ribbon cable seats down fully. Once the ribbon cable is down, push down the tabs to lock the keyboard in securely.
hope this helps.
Karl
KDS Valiant... | Answered on Nov 18, 2007
KDS Valiant 671DP Notebook Logo
26 questions posted
Top KDS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • KDS Computers & Internet
Most Popular Question
hard drive
  • Computers & Internet
