20 Most Recent Sharp CD-XP120 CD Shelf System Questions & Answers
I have a cd xp120 sharp mini stereo andt it won`t read the disc,i bought and replaced the lens but it still says no disc.
To fix this properly the whole laser assembly needs to be purchased, because it comes pre-aligned which is critical when it comes to a set up.
5/7/2012 8:51:37 PM • Sharp CD-XP120... • Answered on May 07, 2012
Can the motor that spins the cd be the problem why the disc does not read
Yes! but keep in mind that when the laser drops below a critical value the pladder motor will not spin, making it look like the motor is the problem when in fact it is the laser that is the issue.
4/7/2012 2:23:53 PM • Sharp CD-XP120... • Answered on Apr 07, 2012
Sharp cd xp 120 CD play button does not work.
The pad switch"hidden under the button" is more than likely the issue.
3/17/2012 4:46:31 PM • Sharp CD-XP120... • Answered on Mar 17, 2012
The antenna is missing... can I buy a replacement?
You can buy them at any Radio Shack or a business like that.
3/4/2012 7:43:20 PM • Sharp CD-XP120... • Answered on Mar 04, 2012
I need Manuals for Sharp
Hi, you may download the manual through this site:
http://www.eserviceinfo.com/download.php?fileid=29455
Note that this is a multi-part manual. Please download the manuals "0 to 1" by clicking on it or by clicking on "To download the file, please click here" before extracting.
Note that you need winzip to extract the file. I hope this helps
8/23/2011 10:18:10 AM • Sharp CD-XP120... • Answered on Aug 23, 2011
Where can I get a user manual for a sharp cd xp
I will advice you check manualsonline.com to search for the manual of your unit.
Take care.
10/24/2010 9:29:06 AM • Sharp CD-XP120... • Answered on Oct 24, 2010
CD Player not working
Since the unit was in storage for a while dust may have settled on the lens.Try cleaning the lens.
2/22/2009 10:01:27 PM • Sharp CD-XP120... • Answered on Feb 22, 2009
FM or AM
You may have to manually set the preset stations on the unit itself. Read the user manual.
3/22/2008 1:59:14 AM • Sharp CD-XP120... • Answered on Mar 22, 2008
Cd changer malfunction
I know that this sounds like a crazy solution to Pitsy`s CD problem but today i took a chance by using my lawn gas blower. First I opened the drawers of my CD turntable and also my cassett doors. I put ear plugs on and blasted the air into the openings. All i can say is it is now working fine !! Lou F.
11/30/2007 7:47:20 PM • Sharp CD-XP120... • Answered on Nov 30, 2007
Sharp Atomic Clock spc373 - How do I change time zone from Pacific to Central?
None of these helped. No where on the back of my Sharp SPC373 does it say TIME ZONE7783a6a7-cffe-44d1-bfd3-70fe44ddcda5.jpgI have had this clock awhile. Changed the battery. Reset 4 times. Manually changed time and it always goes back to PST
11/7/2022 6:03:47 PM • Sharp Audio... • Answered on Nov 07, 2022
I have a sharp atomic clock model spc900 and the alarm goes off every night at midnight. I don't know how to stop it.
The SPC900 has 2 alarms. On the back of the unit there is a buttion labeled "Alarm On/Off". Press the that button to cycle through the alarm on/off possibilties. On the screen you will see what alarm(s) is (are) turned on. There are4 possible settings: off (no alarms displayed), alarm 1 only, alarm 2 only or both alarms. The indicators are just above the seconds display and to the right of the big hour/minute display.
5/30/2022 8:28:20 PM • Sharp Audio... • Answered on May 30, 2022
My Sharp CD-BH950 mini component system will not change tracks on CD's. Have tried all trays and multiple CD's with no luck. It just plays the first track over and over.
Look over your player and see if a program is set. Sometimes you can set a program on the CD player to play the first song on cds. Turn program play off. It’s sometimes called delete bank where all song are skipped except first track. Or you can have the repeat button on. Turn that off. There also could be a malfunction with the player. If your still having problems reset the system.
3/22/2022 6:26:44 AM • Sharp Audio... • Answered on Mar 22, 2022
My sharp 3 disc rotary won't play past the first track on any disc
Sounds like the laser is stuck and cannot move because the slide motor has failed.
3/15/2022 2:23:55 PM • Sharp Audio... • Answered on Mar 15, 2022
Sharp model GX-CD 610 GY has error 000 what does error 000 mean
The basic binary errors are usually something small. 0000 is usually a cleaning error. I would try to clean the lens with the recommended cleaner and then try again. If problem persists the lens may be saying its dirty due to a scratch on it. These are hard to diagnose because it's a process to remove. I would clean it then replace the lens if needed.
2/23/2022 4:37:02 PM • Sharp Audio... • Answered on Feb 23, 2022
I have a Sharp CD-DH950P.. For all 5 trays I get the cannot read signal. I tried a CD disk cleaner and I get the same message.
Possible laser failure. Could be dust on the lens ... CD cleaners do more harm than good and are sold because people want them.
12/15/2021 3:23:10 PM • Sharp Audio... • Answered on Dec 15, 2021
Sharp CD-XP120 CD Shelf System Logo
Popular Tags
17 questions posted
Top Sharp Audio Players & Recorders Experts
Gary
Gary
Colin Stickland
Colin Stickland
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Audio Players & Recorders
Most Popular Question
cd xp120 sharp mini stereo andt won t
  • Audio Players & Recorders
