20 Most Recent
Sharp CD-BA300 CD Shelf System Questions & Answers
Bass dont work
Fuses blow when there's an overload. These are often caused by the power transistors or in some models a Power IC, both of which can be found on the large heatsink. You will find that this time one of these has developed a fault that doesn't blow a fuse. You should be aware that the biggest cause of these problems is faulty wiring or a faulty speaker or in some cases the wrong type speakers being used. Incorrect ohms, say 4ohm speakers fitted when they should be 8ohms is another cause.
Sharp CD-BA300
An audio output IC may be defective. This set carries two output IC's.
Cd-ba3001 manual sercvicio
HI,
PLEASE GO TO THE GIVEN LINK ,HERE U CAN DOWNLOAD pdf file.
THE LINK IS :-
www.audiolabga.com/pdf/32SC260.pdf
I HOPE THIS WILL BE HELPFULL TO YOU.
PLEASE DON,T FORGET TO VOTE ME.
GOODLUCK.................
Sharp CD-BA300 stereo system went into Protect
1 suspect speaker defect
2. suspect wiring defect ensure all your wires are connected up properly and your speaker are in good order
3. suspect that the cooler fan may be blocked and the system is overheating. use vacuum cleaner on air vents to remove dust.
4 see specialist as this product maybe defective.
PROTECT on display
Dear petfresh,
Please switch off the system, remove the speakers wires from the system and switch on the system. If system gets on then the speakers or speaker wires are defective.
Output IC is Audio out put IC.( Integrated circuit)
It can be fixed only by service technician at service point
ramesh22
