20 Most Recent
Sharp CD-BA2600 CD Shelf System Questions & Answers
The display just reads "protect"
Protect is bad. It means the amplifier thinks it is overloaded. Check the speaker wires to make sure there are no loose connections or shorts.
Where can i get an
The antenna is very simple if you which to keep the cost down and live near the stations you like. A piece of twin lead from Radio Shack about 6 feet long will do the trick. Split one end down the middle about 30" and make into a tee "T" connect the other end to your radio. If you are further away from from your stations, a commercial antenna will produce better reception.
I have no antenna and radio doesn't play
Looking at Sharp's site, you have a 3 pin plug that goes into the rear of the unit. the top pin is FM the middle and bottom are AM. You can get female "bullet" connectors and make your own if you wish. Or you can order it from Sharp. Probably under 20. Hope this helps
Error code 0203
This is a mechanical error. The mechanism is stuck and can not reset to a known condition. Look to see if a CD has slipped nad try to get it back in place. If that is not the case, it will need service as the mechanism is now out of timing.
Dan
When switch on my sharp radio ;generate some noise like helicopter,
pardon me for asking why do you have to changed the capacitors, cap usually have rating and values, unless you have good reason to changed these, ensure you are replacing the same ratings.
noise from radio usually occurs if there is interference of some sort, or insufficient or fluctuating voltages
if the sound seems high pitch, then it is from capacitors you have replaced
