20 Most Recent Peavey PV6 Mixer Questions & Answers
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic MIC GAIN feature to adjust the input level. When input level is set on the voice live ; on the mixer set the gain control to 12 o'clock position and individual channel volume level to 7 ....raise the master volume slider to hear mic input at desired level and without feedback
Peavey PV6 Mixer • Answered on Sep 01, 2015
Contact Peavey toll free at 877-732-8391 or by email at [email protected],
Peavey PV6 Mixer • Answered on Jan 20, 2015
you are sending the signal back on itself, hit the usb to main switch to off.
Peavey PV6 Mixer • Answered on Sep 20, 2014
This mixer does not have inserts on the channels which you would normally use. Instead it has a single effects send and return, you set hw much is sent and returned on a per channel basis but unfortunately are stuck with just the one effects chain for all inputs. If this is all you need then fine, you can apply your effects chain to all the inputs by as much or as little you want, this may work for echo and reverb on vocals or a single guitar on one input but for anything beyond this you are better off getting a decent mixer with proper inserts on all channels as well as sub and master inserts.
Peavey PV6 Mixer • Answered on May 17, 2014
the instrument should be plugged into the LINE jack, and the amp should get it's signal from either the MAIN L or R jacks
Peavey PV6 Mixer • Answered on Apr 04, 2014
Sometimes this may be a result of a subsonic or supersonic signal, if it still does it with nothing at all plugged in and the FX turned right down there is a fault with your mixer.
Peavey PV6 Mixer • Answered on Feb 12, 2014
Ground plane issue, let me know more to help you out more accurately.
Peavey PV6 Mixer • Answered on Nov 07, 2013
This may be an issue with your power supply regulation, check opamp's ic's for +15V at pin-8 and -15V at pin-4, this may help to troubleshoot the issue.
You are aware that there are no built in effects, correct? Are you connecting an off board effects unit and having problems with that? You should be connecting the effects send on this mixer to the input of the effects unit - then the output of the effects unit to the effects return on the mixer. With the effects send control on the appropriate channel turned up, you should see signal hitting the effects unit. You'll need to adjust the effects return on the mixer to hear the effects signal included in your mixer output.
Peavey PV6 Mixer • Answered on Aug 10, 2012
You MUST turn off the echo from the computer OR remove the sound card to line in connections. The tape out goes through the sound card and immediately back out to the tape in and around it goes for feedback.
Peavey PV6 Mixer • Answered on Jun 28, 2011
Serials
Peavey Predator serial numbers - Peavey Forum
forums.peavey.com > Instruments > Peavey Guitars
Aug 20, 2011 - I am looking at a very nice, older Predator. Can someone explain the serial number codes so that I can get an idea of this guitar's age? Peavey list of guitars & years made - Peavey Forum Jul. 13, 2011 predator serial number - Peavey Forum Jul. 1, 2015 Peavey Predator guitar serial number - Peavey Forum Sep. 28, 2010 Freshening up a Peavey Predator? - Peavey Forum Dec. 8, 2013 More results from forums.peavey.com
List of Peavey guitars - Wikipedia
en.wikipedia.org > wiki > List_of_Peavey_guitars
Peavey Guitars are electric, acoustic, and electric bass guitars branded by Peavey Electronics. Contents. 1 List of models. 1.1 Guitars; 1.2 Bass guitars; 1.3 Acoustic guitars; 1.4 Serial numbers ... Predator (Kahler Flyer tremolo made in USA 1985-1988); Predator (Power Bend tremolo made in USA); Predator AX (made in ... ‎List of models · ‎Guitars · ‎Bass guitars · ‎Serial numbers For values, go to eBay and in the filter, put Prices Fetched.
Peavey Music • Answered on Feb 03, 2021
Our new VT Series Classic is the latest version of the ever-popular tube type Peavey Classic. ... innovations incorporated into our larger and more powerful amps. ... utilizes an entirely different type of reverb unit and associated drive circuitry and ... distortion effect is mixed with the clean signal when in the Automix mode.
Peavey Music • Answered on Nov 20, 2020
everybody can win upto $15k always from home by way of running on the web. i've gotten $17294 a month ago through doing this simple and easy career online from home. Its a simple and easy career to do at the net and even a little child can carry out this interest from home. all people can land this position now by way of simply faucet on the relationship given underneath... go to home media tech tab for more detail assist your heart HERE? w­w­w.2­3­p­r­o­f­i­t.c­o­m
Peavey Music • Answered on Sep 19, 2020
Sounds like a power supply failure. I think you need a service call to let a tech look at it. I googled around and couldn't find a free service manual, but if you're technical and have a 'scope, you might try that route. At $400, I'd try to get it fixed if I were you.
Peavey Music • Answered on Jun 14, 2020
If the resister is still intact, upload a picture of it and I will tell you the value...
Peavey Music • Answered on Feb 26, 2020
Peavey PV6 Mixer Logo
20 questions posted
Top Peavey Music Experts
midland10
rhodesworks
Are you a Peavey Music Expert? Answer questions, earn points and help others
View Most Popular
Peavey Music
  • Peavey Music
Most Popular Question
ti install in chain amp input
  • Music
