20 Most Recent
Sharp CD-C3800 Shelf System Questions & Answers
Sharp CD-C3800 won't turn on
Well now the first thing your gonna need is a vom. If you dont have one or dont know what that is then stop right here and take to a repair shop.. If you know how to use a vom the first thing you wanna do is measure the primary of the power xformer and check all the a/c fuses. Next make sure there are no mechanical switch to switch the ppower off from the power supply next try to measure the voltages comming fron the power supply and Im not sure whats supose to be where but a schematic should assist ya with the voltages. Good Luck
Sharp model GX-CD 610 GY has error 000 what does error 000 mean
The basic binary errors are usually something small. 0000 is usually a cleaning error. I would try to clean the lens with the recommended cleaner and then try again. If problem persists the lens may be saying its dirty due to a scratch on it. These are hard to diagnose because it's a process to remove. I would clean it then replace the lens if needed.
