20 Most Recent
LG E2250V-PN 21"LCD Monitor Questions & Answers
Lg monitor dual
The monitor L.G. is plug in my P.C. The driver is instaleted . But ...don t work ? Why ?
Disassembly lg e2250v
To disassemble your TV you need a screw driver to unscrew the cover and other parts that you need to take off..For proper instruction go and download manual on www.retrevo.com
My Monitor is stuck in
This sounds like a power suply issue. If the product is under warranty get it replaced, otherwise contact tech support.
My LG E2250V-PN turns on
Hi sophie,
I see you want to extend you monito to an LG external monitor.
Have you tried selecting the input PC or the input that is for the cable that you are using for the Video.
If you are using HDMI select the Input HDMI on your LG if you are using DVI then you should select the input DVI to be able to get the signal from the Laptop come out of your LG.
I hope this helps.
Have a nice day,
mvincentc
The monitor worked well until I had to reformat
Hi jhruston,
I see that you are having issueswith the resolution on the LCD monitor that you have.
Since you reformatted from Vista to Win7 if I may ask have you reinstall all the drivers needed for you machine most important would be the video driver, also you can change the resolution of the Graphics on your machine to accomodate the LCD size try a higher rsolution this should be able to fit on th LCD Monitor that you have.
Also there is an option in Win7 to Fill the whole screen avoinding to have a black portion ion the Top and Bottom or Left and Right side of the LCD monitor.
I hope that this helps regarding your concern.
Have a nice day,
mvincentc
Monitor was on went off
