20 Most Recent eMachines eME528-2012 Laptop Questions & Answers
0answers
Function key not working how do you enable it
check for a key on your keyboard that has an f on it. Most new keyboards are multifunction and the F keys are also shortcut keys.
5/30/2015 8:47:11 PM • eMachines... • Answered on May 30, 2015
How do I enable bluetooth E728
I used to work for Acer (who own emachines) and I am pretty sure that that unit does not have a Bluetooth module, if you did it would start loading drivers & set itself up as soon as the button or key combo was pressed, it was a manufacturers option not standard. When you press the key or button it will state in green lettering at bottom of screen "NO BLUETOOTH DEVICE".
12/20/2013 11:03:57 PM • eMachines... • Answered on Dec 20, 2013
Bluetooth
restore go to control panel and use utility system restore put the last date that you know was working Good.God bless you
7/19/2013 2:56:15 AM • eMachines... • Answered on Jul 19, 2013
I want us the camera
check whether the driver of cam is installed or not and also install some cam application like manycam
2/1/2013 12:44:04 PM • eMachines... • Answered on Feb 01, 2013
E528 screen black
Sometimes it is no more complex that the contrast is set incorrectly. This would be the first place to look. Should be a key combination on the laptop to adjust it.
Hope this helps. I would appreciate your feed back as I do this for fun not pay.
8/31/2012 7:28:01 PM • eMachines... • Answered on Aug 31, 2012
2answers
My notebook is processing very slow
You might have some viruses and malware.Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.Download, Install and Run Malwarebytes Anti-Malware:http://majorgeeks.com/download.php?det=5756When Installing choose the non-pro version.Download, Unzip, Install and Run TDSSKiller:http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.htmlDownload, Install and Run Super Anti-Spyware:http://majorgeeks.com/SUPERAntiSpyware_d5116.htmlIf you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.htmlMake sure to select ALL of the "threat categories" when you install or configure Avira...You should be in pretty good shape if you run and install all of these programs...
6/27/2012 9:31:07 PM • eMachines... • Answered on Jun 27, 2012
EME528-2012 bios update
Wow how fancy is that you have a windows flash executable waiting for you at emachines support at support.gateway.com:http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=3234 That`s convenient that you don`t have to do it from DOSI`m not certain; but you may want to ensure that you have administrative privileges when you click the executable file :) Have funChristopher
5/19/2012 1:11:32 AM • eMachines... • Answered on May 19, 2012
2answers
I DELETED MY WEB CAMERA
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=3234 i hope this site will help you fix the problem, choose for the following webcam or download all of them so you can choose what is the most compatible to your laptop, let me know if it works or not so i can help you again : )
9/15/2011 6:26:03 AM • eMachines... • Answered on Sep 15, 2011
0answers
I dont know where the web cam is on my laptop
Webcam is Item 1 in the picture below.
7/25/2011 8:07:39 PM • eMachines... • Answered on Jul 25, 2011
2answers
Did not receive a manual
Probably not. There should be some help files on your computer under the "programs" menu.
If you need more, go to the e-Machine site and look there.
7/9/2011 7:11:02 AM • eMachines... • Answered on Jul 09, 2011
What is my wpa passphrase or wpa key
if you have forgotten your access key/password, you will need to reset, and then reconfigure your router to create a new password. You can find information on how to do this for your particular brand/model of router both in the router's manual, and on the manufacturer's website.
12/28/2010 4:24:54 AM • eMachines... • Answered on Dec 28, 2010
I counted 13 quick beeps at startup on an emachines E520. what dose that mean ? how do i fix it please ?
Thirteen quick beeps at startup on an eMachines E520 usually indicate a problem with the laptop's RAM (Random Access Memory). This could mean that the RAM is not properly seated in its slot, or it could be a sign of a faulty RAM module.
Here are some troubleshooting steps you can try to resolve this issue:
Turn off the laptop and disconnect it from the power source.
Remove the battery from the laptop.
Locate the RAM compartment on the bottom of the laptop.
Check to make sure that the RAM module is seated properly in its slot. You may need to remove and reinsert the RAM module to ensure a proper connection.
Replace the battery and turn on the laptop.
If the problem persists, try removing the RAM module and testing it in a different laptop or using a different RAM module in the eMachines E520 to determine if the problem is with the RAM module itself or with the laptop's RAM slot.
If none of these steps solve the problem, it may be necessary to contact a computer technician for further assistance..
3/22/2023 9:07:20 PM • eMachines... • Answered on Mar 22, 2023
How to factory reset a Emachines Etower 633id it boots up but says operating system not found it has Microsoft Windows ME Millennium Edititon (from Windows 2000 Professional)
  1. Boot the computer to the boot menu: To do this, restart the computer and press the appropriate key when prompted to enter the boot menu. On most eMachines computers, this is the "F12" key.
  2. Select the CD/DVD drive as the boot device: Use the arrow keys to select the CD/DVD drive and press the "Enter" key to boot from it.
  3. Insert the Windows ME boot disk: Insert the boot disk into the CD/DVD drive and restart the computer.
  4. Choose the "Start Computer with CD-ROM support" option: When prompted, choose the "Start Computer with CD-ROM support" option.
  5. Run the Windows ME setup program: The setup program should start automatically. Follow the on-screen instructions to install Windows ME.
  6. Format the hard drive: During the setup process, you will be prompted to format the hard drive. Choose the "Full" format option to erase all existing data and perform a complete factory reset.
  7. Install Windows ME: Continue to follow the on-screen instructions to complete the installation of Windows ME.
After the installation is complete, the computer should be in a factory reset state and you can begin setting it up as a new system. Please note that resetting your computer to the factory settings will erase all personal data and installed programs, so be sure to back up any important data before proceeding with the reset.
2/13/2023 2:51:11 AM • eMachines... • Answered on Feb 13, 2023
2answers
How do i remove the bios password i set but forgot. i want to change some settings and cant get through.
Larry picks up a question from 2015 ;>) Larry Ng Feb 07, 2022 no PC model told hopeless If desktop, the jumper on the MOBO marked PW_CLR on most. Never laptops
6/21/2022 8:55:19 PM • eMachines... • Answered on Jun 21, 2022
2answers
My local disk E is missing.
device manager 1 of 10000 model ODD optical disk drives made, each drive made has LIMITS some only do CD ROMS BD is blue ray , FIY if missing or maked with red or yellow errors or shows up as unknown that all means DRIVER IS BAD , wrong or missiong NO PC Told so can not tell you how to fix that, lacking such a key fact . (but is at your oem makers PC support page under DRIVERS) brd-undefined-undefined-0.jpg
6/21/2022 8:52:19 PM • eMachines... • Answered on Jun 21, 2022
Hi! I have an emachines laptop E525.I is not going on
moved you out of monitors and into laptops, only forum. emachines full model not old like this example E525-901G1Mi windows 7 loaded day1.
  • the switch is bad Lid close switch
  • set wrong in power settings.
  • or the driver is missing that makes this switch work.
so why not just assign the sleep mode, to auto sleep then on what does the power button do in settings, set to do nothing or set button to only sleep . (3 choices here) or let auto sleep do the work, set. set to say 5min idle. the switch is inside it deep and if you rip it out as you go there most noobs break 2 or 3 FFC cable jacks and now it is bricked and $300 mobo wrecked emachines or junk grade, made by Acer.com owned now and that maker does NOT have service manuals making service a royal Pain. best is work around the problem as I just told how. or ask any shop to fix it. they do know how.!!!
5/16/2022 1:18:24 PM • eMachines... • Answered on May 16, 2022
2answers
Reset my eMachines eM350-2074 Black Intel Atom N450(1.66GHz)
Larry has the answer. Larry Ng Feb 07, 2022 no reason stated, the OS reloaded, ?that? what does reset mean to you? and why.? (selling PC or PC infected?) what:"? ahhhh a Netbook sold new with XP or W7, lost the install media? page 22 in your manual shows that you must create recovery media day one, new. if not , it is GONE. https://www.emachines.com/ec/en/US/conte... ..
5/4/2022 2:12:26 PM • eMachines... • Answered on May 04, 2022
eMachines eME528-2012 Laptop Logo
Popular Tags
25 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • eMachines Computers & Internet
Most Popular Question
enable bluetooth e728
  • Computers & Internet
