20 Most Recent
Samsung HW-C560S Theater System Questions & Answers
Hi, I cant get my
Please rephrase. "5.1" and "only ... front right and front left" are mutually exclusive. Look at manuals.
In general, bass is 'managed' by directing it toward or away from any speaker the user declares to be LARGE or SMALL, usually based on arbitrary cone sizes instead of bass handling capability. There 'managed' bass is rerouted to the presumed capable LFE/Bass/Subwoofer channel to avoid potential damage to bass-shy speakers. Therefore, if one lacks a subwoofer one has to tell that to the receiver and designate the other speakers as LARGE or the bass will get tossed in the bit-bucket
I just picked up the
When you run the cable box and the blue ray player to your receiver you use two sets or cords yes? there for you need to run two sets of cords to your TV from the receiver. Have you done this? Both the DVD and Cable box will have different inputs to the TV. Turn the cable box on and cycle through the inputs on the TV. One should pop up for the DVD and a different one for the cable. Let me know if this works.
I hooked up the HDMI cable from the satilite to
if you have more then 1 hdmi on tv your box should have 2 u take and plug1 directly in to tv from box and keep it the same way and just change input on tv to hdmi 1 or 2 or 3 etc. most new tvs have 4 of them or let me know what box u have hope this helps ya
HW-C560S AV Receiver message display PROTECTION.
Your set is in trouble my dear friend.
Protection will appear because the processor sense that you have a faulty parts on your unit.
To avoid further damaged, your system shut it off automatically.
The main reason is your Power amplifier I.C., it is shorted,need a replacement.
I"ve strongly adviced you to look for a qualified technician or electronic shop to fix your problem.
Good day!
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try:
1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted.
2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected.
3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound.
4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals.
5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured.
6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged.
7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker.
8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings.
9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues.
10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device.
11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue.
12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality.
13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair.
Remember to refer to your device's user manual for specific instructions related to your model.
