20 Most Recent Barnes & Noble nook color eBook Reader Questions & Answers
Cannot un-root and re-set to original factory
maby need a new one whats the tablet name and brand.
11/20/2017 4:09:23 AM • Barnes & Noble... • Answered on Nov 20, 2017
I've had my book color
I think you need a new battery.
7/7/2017 8:51:59 PM • Barnes & Noble... • Answered on Jul 07, 2017
Need to factory reset my nook color
Press and hold power button and your "n" home button almost simultaneously (Power first and the "n" ) Hold these until your screen flashes the "Touch the future of Reading" message, wait 2 seconds and release buttons. You will then get a Prompt asking you if you want to reset it to the Factory Settings. Good Luck.
6/26/2017 8:55:15 PM • Barnes & Noble... • Answered on Jun 26, 2017
How do i resize the font on my Nook Color Reader?
Steps To Change Font Size On Nook Tablet Step 1: Chose a book that you would like to read on your Nook. Step 2: Next, view the Reader Settings Step 3: Tap the screen to expose the menu, where you will see a "Text" icon. Step 4: After having clicked on the "Text" icon, you will see that you have the option to change the font size. There will be a letter "A" that will allow you to change the size. Click on the "A" and decide which font is best for you. Step 5: Touch the main screen to return to your book. If you still have any kind of problem then you can take nook color support from experts by calling nook help number. You can also navigate to www Nook com for more information. nook color-fksmbbcs1b32zb2abicmztb5-4-0.jpg
3/24/2017 6:30:02 AM • Barnes & Noble... • Answered on Mar 24, 2017
Why my nook tablet will not turn on ?
If the screen is off and won't turn on, make sure the battery has a charge. Plug in your device for 30 minutes before trying anything else. If it is on or if the battery has a charge you may need to "hard reset" the Nook. Although this is very uncommon, it may happen. Below are a few solutions that may help.
  • Hold down the power button for 10-15 seconds. The Nook should power off and you can turn it back on again. Everything should work normally.
  • If that does not work you will need to hold down the power button and the "N" button for 10 or more seconds. Again, this should force your device to power off and you can start it up normally.
  • Take out the N2A Card and try the same steps again. Your Nook should boot up into Nook mode. You'll have to restart it again with the N2A Card in to boot up in Android mode.
One of the tasks above will usually correct this issue unless you have a hardware problem with the Nook. Our cards cannot cause hardware problems unless they are forcefully inserted wrong. If you determine you do have a hardware problem you will need to take the Nook back to the retailer if it is still under warranty. The Nook usually comes with a one-year (non-accidental) warranty through Barnes & Noble. Some retailers, like Best Buy, exchange them in the store under warranty. Don't forget to hold onto your N2A Card until they return your Nook! If you still have any kind of issue thenhttp://www.tablethelpline.com/nook-support/ you can take Nook Help from experts by calling nook customer service number.
3/24/2017 6:17:39 AM • Barnes & Noble... • Answered on Mar 24, 2017
My Nook Library has disappeared on my Nook-how do I restore it?
Download all the archived and unarchived books and save them to your computer. Never deleted these. You have two options for the archived books. Un-archive them and they will appear on your nook and download as you see fit. OR... Sideload them. Which is probably what you did before since archived books already disappear from your My B&N Library and would have had to be in your My Documents Library. Not exactly sure what you mean by 'does not go to my nook' when you try and save/download from the website. If still having any kind of issue then you can take nook support from experts or call nook help number.nook reading-rgbm4egpwhlyy1resprahfdp-3-0.gif
3/22/2017 6:30:07 AM • Barnes & Noble... • Answered on Mar 22, 2017
How to unlock your nook if you forgot passcode
If you forgot the password then just hard reset it. Here is the method to reset your device: Hard Reset Procedure For Nook Users 23905885-jnsfx5bc0nd4eqoghjnvkdjy-2-0.jpg
1/9/2017 7:58:29 AM • Barnes & Noble... • Answered on Jan 09, 2017
Problems with my nook
Nook is among the most popular e-Reader devices after Kindle. If you are using Barnes & Noble Nook and facing a certain issue in the device, then you have to take Nook support. If you find nothing useful on the website, then Call Toll Free No. +1(844)-305-0086
1/9/2017 7:54:35 AM • Barnes & Noble... • Answered on Jan 09, 2017
MYH NOOK COLOR IS NOT MOVING IT IS FROZEN WHAT CAN I DO?
Try these two simple methods: Troubleshoot Your Nook Frozen Screen With 2 Simple Methods you can also call call Nook Customer Service Number @ +1(844)-305-0086 (Toll-Free).
1/9/2017 7:52:57 AM • Barnes & Noble... • Answered on Jan 09, 2017
3answers
How do you unlock your nook, when you forget your
From what I have found on this issue it looks like you will need to restore your nook back to factory settings. Any books you bought and backed up from Barnes & Nobles should re-download once you have restored the device and re-registered.
To complete a factory fallback:
1. Turn your device completely off.
2. Power up the device while holding in both the power button and the physical "n" button at the bottom of your NOOKcolor.
3. The device should begin to power up and you will see the welcome screen however keep holding both buttons down and the device will power down.
4. Repeat step 2.
5. When the welcome screen comes up, release both buttons.
6. The device will begin to power on and then a window will pop up asking if you would like to restore your device. Press the "n" button once and again to confirm.
7. The NOOKcolor will restore itself to full factory defaults and will startup as if it were brand new.
8. Re-register your device (while connected to a WiFi network) and you will start over fresh
7/21/2016 1:08:06 AM • Barnes & Noble... • Answered on Jul 21, 2016
Will I loose my Library when I replace the battery
Your book from Barnes and Noble are on THEIR server under your account. Anything else you have added can be stored onto your laptop. Generally, your items will stay in memory a long time without battery power. You should be fine IF you can remember the password to your account and your account name (an email address).
5/6/2016 9:45:13 PM • Barnes & Noble... • Answered on May 06, 2016
Where can i find my 9 inch nook hd replacement screen kit
The Nook is not designed to be opened. There are many screen protectors available to put OVER the screen. You cannot replace a screen without doing damage to the device.
3/22/2016 6:28:38 PM • Barnes & Noble... • Answered on Mar 22, 2016
Device locked. do not know pass code
You need to take it back to Barnes and Noble to have them manually unlock it.
3/21/2016 10:28:58 PM • Barnes & Noble... • Answered on Mar 21, 2016
Wont Lendme books
Think you have to buy them. Go to a library if you want to borrow.
3/3/2016 4:40:49 AM • Barnes & Noble... • Answered on Mar 03, 2016
If my nook doesn't turn on after fully charging it, does this mean I need a new battery?
If you are within 1 year of purchase, you should contact 800-the-book with your serial number or registered email (for the B&N account associated with the device) and arrange replacement of the unit. They very easy about returns, although you may need to settle for an alternate color to expedite replacement.
10/19/2014 3:57:11 PM • Barnes & Noble... • Answered on Oct 19, 2014
Barnes & Noble nook color eBook Reader Logo
150 questions posted
Top Barnes & Noble Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Rick Rock
Rick Rock
Are you a Barnes & Noble Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Barnes & Noble Tablets & eReaders
Most Popular Question
resize font nook color reader
  • Tablets & eReaders
