20 Most Recent
Nvidia GeForce2 MX (32 MB) Graphic Card Questions & Answers
It's corrupted
First I would shut down the pc and make sure the adapter is seated properly in the MB. If it is and the problem persists download the driver here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
and reinstall the driver. If you need detailed instructions post back.
Video is not displaying it asks to install vga
hi im josh in cebu phils.may i help you? Friend if the video asks to install compatible drivers. it means that the driver installed dont work with the video card. to solve this install the video driver cd package with your video card.and reboot you pc after.the software driver will automatically updates your video to high and fine resolution.so try to do it. thats all friend good lcuk hope i helped you.
Computer game not responding
what is the name of the game certain games have different system requirements check to see if your computer will actually run the game first before you download
Problem with image display on monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133236
That should fit the bill you're asking for. However, your current video card should definitely support 1024x768 fully, even at high hz refresh rates (assuming you are using a CRT). The "waves" may be caused by your video card, but it's really hard to say.
If you have more money, I would recommend this card, as it has a higher price/performance ratio:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102730
That is probably going to be the last high-performance AGP card ever produced, as the AGP bus has been discontinued now for some time. You may need a higher-end Power Supply, however. Good luck!
Gt 630 nvidia, error code 43
Update your video card driver at NVidia.com. More current drivers eliminate the conflict caused by having 16GB RAM.
Need Nvidia pcg 7v1m driver Graphics win.7
go google and type in--- nvidia drivers -- download the driver for your graphics board and win 7
or if you have a graphics board already install click on the board and change compatibility to win 7 in the properties tab
you will also find an update drivers in the sam properties section
