20 Most Recent
CF Martin 000X1AE Java Mahogany Acoustic Electric Guitar Questions & Answers
Battery martin 000X1AE
The battery is in a black cloth bag inside of the guitar. The Fishman Sonitone has a small board with vol/ton control next to sound hole. Follow the black and red wires from the board to the battery pack. Good luck!
11/23/2018 12:22:46 PM •
CF Martin...
Answered
on Nov 23, 2018
How do I change the
Most there is a little release right by the tuner EQ that allows the tuner with battery box to tip out to replace.
9/5/2011 6:28:42 PM •
CF Martin...
Answered
on Sep 05, 2011
Buzz from the 1st string,
Have the guitar setup at a reputable guitar repair shop. This is likely a truss rod setup problem which an inexperienced person should NOT attempt on an expensive guitar. It could also be that the slot in the nut is too low for that string. They can shim the nut if needed or replace it. There are several settings that have to be right to have good playability.
6/11/2011 5:29:58 AM •
CF Martin...
Answered
on Jun 11, 2011
I need to repair internal wires
Typically you have to unstring the guitar to get access to the insides.
Use a small miirror to view the insides. You may need to drag the jack out of the sound hole to resolder wires if they are broken. There should be three wires on the jack. One carries the audio, one the ground, and the third connects the battery when the instrument cable is plugged in.
After re-soldering the connections if needed, procure a piece of 1/4 inch wood dowel from your hardware store. Push the dowel through the hole where the jack goes and near the sound hole. Push the jack onto the dowel and then pull it back through the jack hole and pass the nut over the dowel and onto the jack threads and tighten. The extract the dowel rod from the jack.
It is near impossible to reach clear into the guitar body to put the jack back in without the dowel rod unless you have very tiny arms.
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring.
This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM •
Music
Answered
on Dec 31, 2023
Breaking Roland RD 600 hammers
The Roland RD-600 is a digital piano, and its hammer action mechanism is designed to simulate the feel of an acoustic piano. The hammers in digital pianos like the RD-600 are typically made of materials like plastic or a combination of materials to replicate the weighted feel of acoustic piano keys.
The breaking of hammers in a digital piano is not a common issue, and it's not typically related to the age of the instrument alone. Several factors could contribute to the breakage of hammers, and it's essential to consider the following possibilities:
- Excessive Force: If the keys are played with excessive force or if there's any physical damage to the instrument, it could lead to the breakage of hammers.
- Material Quality: The quality of materials used in the construction of the hammers can impact their durability. If the hammers are made from subpar materials, they may be more prone to breaking.
- Manufacturing Defects: In some cases, there could be manufacturing defects that make the hammers more susceptible to breakage.
- Maintenance: Lack of proper maintenance, such as cleaning and regular inspection, may contribute to the wear and tear of components, including hammers.
If you've observed a pattern of hammers breaking with regularity, it might be worth investigating the specific cause. If it's due to excessive force or physical damage, adjusting playing habits and taking care during transport can help mitigate the issue.
As for whether it's worth purchasing new hammers from Roland, it depends on the extent of the damage and the overall condition of the instrument. If the RD-600 is in good condition otherwise and you enjoy playing it, replacing the hammers could be a reasonable option. However, you may want to assess the cost of replacement hammers compared to the overall value of the instrument, factoring in the cost of a used RD-600 and any potential future maintenance needs.
11/12/2023 2:54:05 PM •
Music
Answered
on Nov 12, 2023
