20 Most Recent Peavey IPR-3000 Power Amp Questions & Answers
Measure the breaker, measure the power switch, measure the power cable,
Peavey IPR-3000... | Answered on May 14, 2016
Contact Peavey toll free at 877-732-8391 or by email at [email protected],
Peavey IPR-3000... | Answered on Jan 20, 2015
if less that 5 years old under warranty.
Peavey IPR-3000... | Answered on Sep 20, 2014
mixer left right out to eq ins, eq out to the first amp left and right sides, use the thrus to the second amp, put that amp in Sub mode
you press it back in ....
This should be under warranty if you bought it new.
If your daring enough to dis assemble it. Remove the batt inside
there might be clear jumper or 2 pads that you have to short to clear.
make sure it's unplugged to.
Peavey IPR-3000... | Answered on May 27, 2014
If its new out of the box then don't open it take it back to the seller. Its under warranty.
Peavey IPR-3000... | Answered on Apr 05, 2014
The amp takes LINE LEVEL which is in the order of 1 volt or 0 Db... a mic generates only -40DB. You need a preamp or a mixer between the mic and this amp.
Peavey IPR-3000... | Answered on Aug 13, 2011
Yes, they are NOT intended to be changed for routine volume level changes, but instead for initial balancing. Ideally, you would like to have them set about 2/3 up and control level from your mixer or other device.
Peavey IPR-3000... | Answered on Jan 03, 2011
Our new VT Series Classic is the latest version of the ever-popular tube type Peavey Classic. ... innovations incorporated into our larger and more powerful amps. ... utilizes an entirely different type of reverb unit and associated drive circuitry and ... distortion effect is mixed with the clean signal when in the Automix mode.
Peavey Music | Answered on Nov 20, 2020
everybody can win upto $15k always from home by way of running on the web. i've gotten $17294 a month ago through doing this simple and easy career online from home. Its a simple and easy career to do at the net and even a little child can carry out this interest from home. all people can land this position now by way of simply faucet on the relationship given underneath... go to home media tech tab for more detail assist your heart
HERE? w­w­w.2­3­p­r­o­f­i­t.c­o­m
Peavey Music | Answered on Sep 19, 2020
Sounds like a power supply failure. I think you need a service call to let a tech look at it. I googled around and couldn't find a free service manual, but if you're technical and have a 'scope, you might try that route. At $400, I'd try to get it fixed if I were you.
Peavey Music | Answered on Jun 14, 2020
If the resister is still intact, upload a picture of it and I will tell you the value...
Peavey Music | Answered on Feb 26, 2020
Peavey IPR-3000 Power Amp Logo
20 questions posted
Top Peavey Music Experts
ray gallant
rhodesworks
Are you a Peavey Music Expert? Answer questions, earn points and help others
View Most Popular
Peavey Music
  • Peavey Music
Most Popular Question
amp turn
  • Music
