How to change the code on a Chamberlain Keyless Entry Garage Door opener
How do I add, program or change a Keyless Entry PIN?
Your new Keyless Entry must be programmed to operate your garage door opener.
Program using the "Learn" Button
- Press and release the "learn" button on the motor unit. The learn indicator light will glow steadily for 30 seconds.
- Within 30 seconds,
enter a four digit personal identification number (PIN) of your choice
on the keypad. Then press and hold the ENTER button.
- Release the button
when the motor unit lights blink. It has learned the code. If light
bulbs are not installed, two clicks will be heard.
Program using the Multi-Function Door Control
NOTE: This method requires two people if the Keyless Entry is already mounted outside the garage.
- Enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold ENTER.
- While holding the ENTER button, press and hold the LIGHT button on the Multi-Function Door Control.
- Continue holding the
ENTER and LIGHT buttons while you press the push bar on the
Multi-Function Door Control (all three buttons are held).
- Release buttons when
the motor unit lights blink. It has learned the code. If light bulbs are
Change a Known, or Existing Pin/Code
If the existing PIN is known, it may be changed by one person without using a ladder.
- Press the four buttons
for the present PIN, then press and hold the # button. The opener light
will blink twice. Release the # button.
- Press the new 4-digit PIN you have chosen, then press ENTER.
The light on the motor will blink once when the PIN has been learned.
Test this by pressing the new PIN, then press ENTER. The door should then move.
I hope you find this helpful. If you need further assistance please let me know!
Have a great day! :)
Carrie
