20 Most Recent Sakar IConcepts Clean Radial CD Cleaning Kit - Cleaning kit (10769) DIR Questions & Answers
How do I clean my DVDs
Those kits are worthless. Just use a soft lint free cloth and some windex.
1/30/2013 7:01:54 AM • Sakar IConcepts... • Answered on Jan 30, 2013
3answers
Power inverter
Most likely a fuse. Check for a fuse on the inverter itself or one inline with the plug. Usually you can screw off the tip of the plug and replace the fuse inside.
3/26/2023 8:42:09 PM • Electronics -... • Answered on Mar 26, 2023
2answers
Nsm performer classic
If your NSM Performer Classic jukebox is not accepting money and playing music, there could be a few different issues that could be causing this problem. Here are a few things you can try:
  1. Check the coin mechanism: Make sure the coin mechanism is clean and in good working order, and that the coin chute is not blocked.
  2. Check the bill acceptor: Make sure the bill acceptor is clean and in good working order, and that the bill path is not blocked.
  3. Check the credit display: Make sure the credit display is working properly and that it is displaying the correct amount of credits.
  4. Check the software: Make sure the software on the jukebox is up to date and that there are no errors.
  5. Check the selection buttons: Make sure the selection buttons are working properly and that the jukebox is able to receive selection inputs
  6. Check the amplifier and speaker: Make sure the amplifier and speaker are working properly and that the jukebox is producing sound.
If none of these steps resolves the issue, it is possible that the jukebox may be defective and require repair or replacement. In that case, contact NSM customer support for further assistance.
2/21/2023 1:01:50 AM • Electronics -... • Answered on Feb 21, 2023
How to delete all in my sony ericsson x10i
To delete all data from your Sony Ericsson X10i, you can perform a factory reset. Here are the steps to do this:
  1. On the home screen, tap the "Menu" button.
  2. Scroll down and tap "Settings."
  3. Scroll down and tap "Privacy."
  4. Tap "Factory data reset."
  5. Tap "Reset phone."
  6. Confirm that you want to delete all data by tapping "Erase everything."
Please note that this will permanently delete all data, including contacts, messages, apps, and settings. It's also a good idea to back up your data before performing a factory reset.
1/24/2023 4:54:21 AM • Electronics -... • Answered on Jan 24, 2023
Sky plus wont record and watch another channel at the same time says no signal
If your Sky Plus box is not allowing you to record one channel while watching another and is displaying a "no signal" error, there could be a few potential causes for this issue: Insufficient signal strength: Make sure that your Sky Plus box is connected to the satellite dish correctly and that the dish is pointing in the correct direction. Weak signal strength can prevent the box from tuning in to channels properly. Dish misalignment: If your dish is not properly aligned, it may not be able to pick up a signal from the satellite. You can try adjusting the dish yourself or contact a professional to align it for you. Technical problem with the box: There may be a technical problem with your Sky Plus box that is preventing it from recording and watching different channels at the same time. This can be caused by a hardware malfunction or a software issue. Subscription issue: Make sure you have the appropriate subscription package that allows you to record and watch different channels at the same time. Box is full: If your hard disk is full, the sky+ box may not be able to record or watch another channel. It would be best to check all the above points, if the problem persists, contact Sky customer service for further assistance. Why is my Sky saying no signal on some channels? Faulty Satellite Cable There are all sorts of things that can cause a cable to become faulty like age, condition, and whether it's damaged and weathering/ water ingress. To fix- A new coaxial cable or two new coaxial cables may need to be installed for Sky+ boxes and Sky Q boxes.
1/24/2023 4:41:53 AM • Electronics -... • Answered on Jan 24, 2023
Hard drive crashed on tascam dp02
A hard drive crash on a Tascam DP-02 digital recorder can be a major issue, as it can result in the loss of recorded audio files and settings. Here are a few potential solutions below: Check the connections: Make sure that the hard drive is securely connected to the Tascam DP-02. If the connections are loose, the hard drive may not be recognized by the device. Reformat the hard drive: If the hard drive is still recognized by the Tascam DP-02, you may be able to reformat it and use it again. This will erase all data on the hard drive, so make sure to back up any important audio files before reformatting. Replace the hard drive: If the hard drive is not recognized by the Tascam DP-02 or reformatting does not work, you may need to replace the hard drive. You can use a compatible hard drive with the same capacity or larger. Seek professional help: If none of the above solutions work, it may be best to take your Tascam DP-02 to a professional technician who can diagnose and repair the issue. It is important to keep in mind that, regardless of the solution, you will lose the audio files and settings that were stored on the hard drive. Backing up your files regularly is crucial to avoid data loss. reset my Tascam DP o2 - You May Try onces. To perform a factory initialization of the DP-02 turn the unit off. Hold the Up Arrow and Track Edit while powering the recorder on. You'll get a confirmation screen and then press the Yes/Enter button.
1/24/2023 4:38:08 AM • Electronics -... • Answered on Jan 24, 2023
I have a Keb Inverter and it's showing negative reading while on standby
Contact them direct. They will be interested to hear this. Did you check polarity with a test meter? https://www.google.com/search?q=keb+inverter+reverse+fault KEB Inverter - Contact Our Responsive Team Ad·https://www.kebamerica.com/ KEB America Is a Top Manufacturer Of Industrial PCs, HMIs, VFDs, Clutches, Brakes, & More. The Future in Control & Automation Technology w/ Customizable Products - Contact Us Today! Since 1972. Responsive Support. Customizable Products. Automation Experts.
DrivesUp to 1,000Hp; 230 & 460V classes. High Performance
ContactReach Out to Our Responsive Team Expert in Customizability
Contact UsSales Quotes Technical Support
About UsThe Future in Control & Automation Made in USA
1/23/2023 12:35:33 AM • Electronics -... • Answered on Jan 23, 2023
Why won't my cmt-ep505 turn on?
The fuse needs to be replaced then because it has blown on you or it might also be the fact that it was stopped working on you guys and you will need to buy a new one.Or it could be the plug or the power cord.
1/19/2023 7:11:47 AM • Electronics -... • Answered on Jan 19, 2023
KEB F5 = DC Bus voltage coming, Control card OK, but Display Power Not found, how do solve this problem.
If you are experiencing a "Display Power Not found" error on your KEB F5 Inverter and the DC bus voltage is coming and the control card is functioning properly, there may be an issue with the display or the power supply. Here are a few steps you can try to troubleshoot the issue:
  1. Check the power supply for any visible signs of damage or malfunction.
  2. Check the display for any visible signs of damage or malfunction, such as cracks or loose connections.
  3. Check the wiring and connections to ensure that they are secure and properly connected.
  4. Check the F5 Inverter's fuse and circuit breaker to ensure that they are functioning properly.
  5. Try resetting the F5 Inverter by unplugging it and waiting a few minutes before plugging it back in.
If these steps do not resolve the issue, it's best to contact a professional repair service or the manufacturer for further assistance. They will be able to diagnose the problem and recommend the appropriate repairs. It's also a good idea to stop using the F5 Inverter until the issue has been resolved, as continuing to use it may cause further damage.
1/7/2023 10:50:54 PM • Electronics -... • Answered on Jan 07, 2023
I have a problem with hybrid b1200. When in stereo mode input A is not working. Input B is working as if the mode is in parallel yet is in stereo mode
If input A is not working on your hybrid b1200 when in stereo mode and input B is working as if the mode is in parallel, it's possible that there is an issue with the wiring or connections for input A. Here are a few steps you can try to troubleshoot the issue:
  1. Check the wiring and connections for input A to ensure that they are secure and properly connected.
  2. Check the b1200's fuse and circuit breaker to ensure that they are functioning properly.
  3. Try resetting the b1200 by unplugging it and waiting a few minutes before plugging it back in.
  4. Check the owner's manual for any troubleshooting tips or information on common issues.
If these steps do not resolve the issue, it's best to contact a professional repair service or the manufacturer for further assistance. They will be able to diagnose the problem and recommend the appropriate repairs. It's also a good idea to stop using the b1200 until the issue has been resolved, as continuing to use it may cause further damage.
1/7/2023 10:47:11 PM • Electronics -... • Answered on Jan 07, 2023
How to connect usb flash drive on Toshiba model no.32AV615DB
it does not have USB input
12/17/2022 3:55:04 PM • Electronics -... • Answered on Dec 17, 2022
Have anyone BPS-8203 diagram ?
It doesn't exist. Take it to an electronics engineer for component testing or just buy a new one. https://www.google.com/search?q=BPS-8203+wiring+diagram ..
12/14/2022 7:16:11 AM • Electronics -... • Answered on Dec 14, 2022
How to reformat my phone QTW88 TV Duo
Better backup your phone data first as this will wipe such. (You will lose Google account data on the phone, for example.) 1. Turn off your cell phone. 2. Hold the Sym button together the Power button. In the Android recovery menu 3. select Wipe data/factory reset > using the volume down or up button 4. Select Enter. 5. Select "Yes - delete all user data" 6. Press Power key to confirm. When Data wipe complete is displayed, 7. select reboot system 8. Press Power key to confirm to reboot.
12/9/2022 6:21:50 AM • Electronics -... • Answered on Dec 09, 2022
So what memory exit usb do I to have? Will any usb work?
Unfortunately a badly written question. What is a 'memory exit USB'? ' do I to have '? Word missing? All USBs work. Some dives that you attach them to have 'maximum capacity' restrictions.
12/4/2022 6:47:19 PM • Electronics -... • Answered on Dec 04, 2022
3answers
How will this Home - Smart Speaker with Google Assistant - White/Slate compare to Amazon Echo?
Yes, the Google Home is basically the same idea as Amazon Echo. but there will definitely be things that each can do that the other can't. For example, most likely you won't be able to access each other's services... so on Google Home you most likely won't be able to order items from the amazon store or use Amazon Music... and likewise on the Echo won't be able to use Google Play Music or, more importantly, Google Search (which is far superior to Echo's search). Support for 3rd party services and Smart Home devices - The Echo has been out for about 2 years now which has given it a head start with developers to build support for these services and Smart Home devices. Currently Google Home only supports, nest, SmartThings, Philips Hue, and IFTTT for Smart Home devices... but I definitely wouldn't write off Google Home just because it doesn't support as many Smart Home devices as Echo right now, because I honestly believe Google Home will catch up very fast, especially given amount of 3rd party developer support Google already has. A couple big things that Google has created to help developers build upon is two open platforms called Google Assistant and Actions on Google... with these two platforms developers will be able to do a lot of cool, fun, and useful things with Google Home, which will not only work on Google Home devices but they'll also work on Google Pixel phones... so you can also tell Google Assistant on your Pixel phone to turn on outside lights. One area with connected devices I think Google has the leg up on the Echo is Google Home's support for Google Cast... with this you'll be able to Cast audio from your smartphone to a Google Home device and, even better, you'll also be able to Cast both audio and video from Google Home to devices that support Google Cast, like Chromecast... so you can tell Google Home to, "play CSI on the Living Room TV" and CSI will start playing on Netflix through Chromecast on your living room TV. Another area I think Google Home will be much better at is Searches. I currently have the Echo (which I think is great and use all the time), but I get frustrate with it because far too often it can't answer my questions. When the Echo can't answer my question I'll pull out my android phone and ask Google Now the same question and most of the time I get an answer to my question from Google. My wife gets frustrated with the Echo too, because she like to ask Alexa for recipes, and Alexa has never once been able to give her a recipe. Since Google Home uses the same search service I have little doubt that Google Home's searches will be far superior to the Echo searches. The last area I think Google Home will be better is, unlike the Echo currently, the Google Home devices will know about each other and work together... so when you have two Home devices within listening range of each other and you say "Ok Google" they'll work together to determine which devices is closest to you and will respond from that device only... and supposedly it'll also try to determine if you're talking to your android phone or a Home device when you say "Ok Google". Also you can create groups with Google Home devices, and Cast enabled devices, to play audio at the same time across devices in the group. The big question I have is how well will Google Home hear your voice compared to the Amazon Echo. Because the Echo does a very very good job hearing and understanding your words... although this is not the same thing as giving good search results. I'm hoping Google Home is as good at understanding your words from across the room.
11/24/2022 1:56:01 AM • Electronics -... • Answered on Nov 24, 2022
2answers
Hi everyone I need a Samsung D500 charger I need fotos on my old Samsung D500 very urg
Any mobile phone shop or electrical retailer will probably have one or use a usb lead to your computer.
11/23/2022 12:05:56 PM • Electronics -... • Answered on Nov 23, 2022
2answers
How do I connect 2 1850 watt coleman generators
It wont work. Electricity does not work like that. you can't double the power just by doubling the watts or amps. there is a lot and lots of other things involved.
I would rewire you camper so that half is run be one generator and the other half by the other generator... SO lights and fridge on one and plugs and heater on the other maybe...
11/17/2022 10:32:08 PM • Electronics -... • Answered on Nov 17, 2022
What number capacitor do I need for this?
Question edited for spelling.Question moved from Computers.'Make model (what it is)' needed.https://www.google.com/search?q=10aia6001..
10/26/2022 5:35:09 PM • Electronics -... • Answered on Oct 26, 2022
I have a aa and aaa battery charger's and all three are ful with batteries and are flashing red. What does this mean?
Que le syst?me es en surchauffe et peux donc se grill?
9/28/2022 4:09:18 PM • Electronics -... • Answered on Sep 28, 2022
I have a Statpower PROsine 2.5/3.0 inverter/charger. I heard a pop and smelled hot wiring after a power outage, when the power came back on. Anything I can replace or do to fix?
need to examine what was damaged open it up and test circuit --components with a meter
7/30/2022 12:19:52 PM • Electronics -... • Answered on Jul 30, 2022
Sakar IConcepts Clean Radial CD Cleaning Kit - Cleaning kit (10769) DIR Logo
2 questions posted
Top Sakar Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Sakar Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Sakar Electronics - Others
Most Popular Question
clean dvds
  • Electronics - Others
