20 Most Recent
Creative Labs Nomad MuVo TX MP3 Player Questions & Answers
You can have a try Leawo Tunes Cleaner. Just follow below steps. If you still have issues or have a massive music library in iTunes or other music folders that requires a more powerful and less time-consuming option, the third-party software like Leawo
Tunes Cleaner can help you. It can not only automatically clean up duplicate songs in iTunes, but also automatically delete duplicate songs in other music folders. If you want to automatically remove duplicates in iTunes, the automatic duplicate remover might have the answer for you.
1. After kicking off Leawo Tunes Cleaner, click the "Clean-up Duplicate" entry. The program provides 2 duplicate scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
2. You could delete duplicates in iTunes music library by directly clicking "Scan iTunes" button or click "Add" button to load music files for duplicates removing.
3. After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
For more details, check:
How to Delete Duplicate Songs
Creative Labs...
Answered
on Apr 22, 2019
hi u r asking a qas thats a board problem
Creative Labs...
Answered
on Dec 12, 2010
Welcome to Fixya!
The power button is the PLAY/PAUSE button as well. Just hold it down for a few seconds until it lights up. Make sure that there is a working battery installed for it to work.
Please let me know if you have anymore question.
Thank you for using Fixya.!
Creative Labs...
Answered
on Nov 09, 2010
This is the file system problem. Use the below tool to solve it.
http://ccfiles.creative.com/ManualDn/Applications/PDE/11124/0x46D235F9/CT-RT_PCAPP_2_01_03.exe
BEFORE YOU START
- Check that the MP3 Player Recovery Tool supports your player.
- Ensure that you are using Windows XP® Service Pack 2 32-bit, Windows XP Professional x64 Edition or Windows Vista™ (32-bit or 64-bit version).
- Back up the contents of your player, if possible, as recovering your player may require it to be re-formatted, erasing all content.
- Make sure your player battery is at least 50% charged.
- Detailed usage instructions are available in our Knowledge Base.
Creative Labs...
Answered
on Sep 22, 2010
update your player with latest software.visits.creative.com
Creative Labs...
Answered
on May 31, 2010
Check to see if it is on your hardware by trying to Add it as new hardware. Even if it is there, it sounds as if your driver has died and the computer will assign a new driver, then you should be back in business.
Creative Labs...
Answered
on Jan 24, 2010
i had one of those do the same thing i had tryed everything i could to fix it and with no luck unfortunitly its a goner sorry to hear that happened to you to but look at it as an oportuniy to upgrade to one with more storage :)
Creative Labs...
Answered
on Oct 07, 2009
# To install this firmware upgrade, do the following:
1. Download the MuVoV200_PCFW_LF_1_05_02.exe file into your local hard disk.
2. Connect your player to your computer.
3. Double-click the firmware upgrade file.
4. When prompted to set your player in Recovery mode, disconnect your player from your computer.
5. Press and hold the Play button while connecting your player to your computer's USB port.
6. Continue to hold the Play button for about ten seconds after connecting your player to your computer.
7. Release the Play button when the Find New Hardware dialog box appears on the computer screen.
8. Follow the instructions on the screen to install recovery drivers for your player.
9. Double-click the firmware upgrade file and follow the instructions on the screen.
Saludos...
Creative Labs...
Answered
on May 13, 2009
- Replace the battery with a fresh battery
- Format the player with Windows Format.
- or reload the player's firmware.
Creative Labs...
Answered
on Mar 16, 2009
get a real ipod, these usb have to many problems.
Creative Labs...
Answered
on Mar 15, 2009
I tried for over a month before
I finally got this solution today and my player is working just fine.
Try and download the drivers from the following link.
http://www.nodevice.com/driver/MuVo_TX_FM/get34414.html
This needs you to enter a verification code that is hardly recognisable. Try and hit refresh (below the verification code) a dozen of times till it gives you an easy code and download the drivers(just in case you need the drivers again).
Then run the drivers after you have installed your device. You might need to try this a couple of times. It also gave me all my songs back but I reformatted the drive to be really cautious.
Wish you all the best. Hope it works for you as well.
Creative Labs...
Answered
on Mar 15, 2009
- If the player continues to shut off with a refresh battery and Windows' format, reload the player's firmware
Creative Labs...
Answered
on Mar 12, 2009
