20 Most Recent Epson Livingstation LS57P2 57" Rear Projection HDTV Questions & Answers
I just fixed the problem on my epson 57" living station. The picture is like new. Yo have to clean the dust off of the the 3 lcd lenses. (I'm not sure if thay are actually called lenses)
You can get to these by entering thru the front of the TV. Yes the front. You must remove the screen. There are A LOT of screws. This screen housing covers the entire front of the tv. and you have to remove the back panel and ALL the screws on the back of the tv to get it off. The only electronics that have to be disconnected are the Speakers and the front control panel. They both have snap connectors. After you remove the entire front panel which houses the screen and expose the inside mirror you will see more screws. You must remove those as well to remove the mirror housing. DO NOT REMOVE THE MIRROR FROM THE HOUSING. Note that there is a peg that is next to a screw in thre front of the mirror housing thst you must pull the plastic housing out in that area to release it.After you remove the mirror housing you will see the 3 LCD panels or lenses. YOU DO NOT HAVE TO REMOVE ANY ELECTRONICS OR SCREWS AT THIS POINT. Use a can of compessed air to spray the dust out of this area. I used a vacume to catch the dust as it flew out in the air. Try to hold the can as upright as possible.Keep hitting it with the air until no more dust comes out. Put the tv back together. As you open up the tv you will see dust everywhere. I took the oppurtunity to clean as much as I could. The Mirror though was clean an I was afraid to touch it.
I am a Construction Salesman yet fairly handy. I have no electricle experience. This took me 2 1/2 hrs. I spent the first 45 min. trying to get to the lcd panels from the back of the tv. Don't waste your time. You can't.
Epson... | Answered on Jan 03, 2015
Have you cleaned the unit? They build up dust...
Epson... | Answered on Apr 10, 2014
It probably needs cleaning. They build up dust after a while...
You need to reset the "Lamp Hours" in your settings. It is a timer that just runs down, and doesn't know if you changed the bulb. It just needs to be reset to 0.
tryin unplugging t.v for an hour then plug it back in it worked for me i have the same t.v just the 47 inch
Epson... | Answered on Jun 27, 2013
On the front right where it says LIVINGSTATION, that panel lifts out. Inside you will see two screws, loosen them, (they will not come out because of a retainer) gently pull the box out. Once it is out, there is a wire retainer that has to be removed. Once that is removed, then loosen the nuts from the bulb. Then reassemble. Putting it back in, takes patience, do be in a hurry when putting it back in. It will only go in one way, make sure the bulb is facing the inside when sliding it back in. Hope this helps you..I haven't yet replaced the whole unit from epson ($300) only the bulb, which didn't need it after all. If you have any questions e mail me..
Epson... | Answered on Nov 29, 2012
If model indicated turn color all the way to zero and stand back and look at screen with set on.
Does it have an area/s that are yellow instead of black and white or gray?
Epson... | Answered on Apr 16, 2012
leesa_champa,
This could literally be anything. See my tip at http://www.fixya.com/support/r4606286-troubleshoot_dlp_tv for help with isolating the problem.
Thanks for using FixYa and for the great rating.
hardrocko
Epson... | Answered on Jun 13, 2011
The card light orange (blinking or steady) means that the system is reading the card or initializing the photo reader system.
The Printer light means that there is a printer error, this can be related to card error.
Remove card from the inside and restart the TV with no card after disconnecting power cord for two minutes.
If that does not work, then you may have a faulty card reader , in that case call Epson at the number printed on user manual.
Epson... | Answered on Mar 27, 2011
Epson Livingstation LS57P2 57" Rear Projection HDTV Logo
63 questions posted
Top Epson Televison & Video Experts
Steven
Steven
Level 1 Expert
antoniorojas
janman
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Televison & Video
Most Popular Question
sound goes off screen says no signal
  • Televison & Video
