20 Most Recent Fujitsu P42VHA30WS Television Questions & Answers
3answers
I have recently moved into
1. Yes, it has 2 speakers with 2 x 10 watts power. Check the link below for the specs:
http://www4.shopping.com/xPF-Fujitsu-P42VHA30WS
2. I couldn't find a way to access the menu without a remote
3. Try these codes and it might work for your universal remote control:
007, 008, 009, 021, 026, 028, 029, 032, 033, 040, 041.
Hope one of these codes work with your remote control.
3/27/2019 12:34:53 AM • Fujitsu... • Answered on Mar 27, 2019
I need a remote control
Hello
Universal remote codes for Fujitsu with RCA RCR311S universal remote control are:
1228, 1027, 1186, 1229, 1045
OK.
7/2/2011 10:42:51 AM • Fujitsu... • Answered on Jul 02, 2011
I direct tv picture but no sound
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me. If your connected to a seperate speaker system, attempt to disconnect from that unit and only run sound through your tv to see if that does the trick.
1/16/2011 2:00:35 AM • Fujitsu... • Answered on Jan 16, 2011
Get an error message
Condition 1 error denotes there is some defect in the fan inside.
You cannot deal with this problem.
Please remove the plug from receptacle and contact you dealer
Thanx
7/31/2010 7:59:51 AM • Fujitsu... • Answered on Jul 31, 2010
Picture gets hung
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
8/17/2008 7:49:20 AM • Fujitsu... • Answered on Aug 17, 2008
0answers
FUJITSU ASYG Forward Comms Fail at Startup
5/23/2023 2:01:04 PM • Fujitsu... • Answered on May 23, 2023
Fujitsu P55XHA40US powers off after 5 minutes, led blinks 1 time red 3 times green, what does it means ?
go into set up for power see if set to turn off
3/27/2022 6:05:25 AM • Fujitsu... • Answered on Mar 27, 2022
Remote control model AR-RAH1U operating guide
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. https://homenol.blogspot.com/ http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
5/28/2020 3:55:14 AM • Fujitsu... • Answered on May 28, 2020
Our fujitsu TV model P42VHA2OUS, 42" (2003) has no picture and green light does not come on. Is there a reset button? Or is the TV broken?
Test the power to the outlet first. You can simply plug your phone charger in and see if you can charge your phone. Assuming the outlet is fine...
If it's a universal type of cord (one that doesn't need to be specially ordered), get a new cord and try that.
If that doesn't work, you'd at this point need to consider either taking it to a TV repair shop, or get a new TV. I'd recommend a new TV because there's very affordable brands like TCL.
3/6/2019 2:08:39 PM • Fujitsu... • Answered on Mar 06, 2019
Fujitsu P42VHA30WS Television Logo
Popular Tags
10 questions posted
Top Fujitsu Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Televison & Video
Most Popular Question
recently moved into
  • Televison & Video
