20 Most Recent
Fujitsu Plasmavision PDS-4229 42 in. Television Questions & Answers
Have a fujitsu pds4229w-s it Have
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
3/9/2017 11:08:12 AM •
Fujitsu...
Answered
on Mar 09, 2017
Power on light is blinkin display is not appear
How many timed do this light blinks at one time switch ON? These blinks are fault indication, and are called blinking codes. If you wish to get more details about these blinking codes, check this link. It has details about blinking codes to many brand TVs. By these number of blinks, you can get an idea about the faulty circuit stage inside it, and it will make repair easy.
Pull up previous posts by its left sidebar, or
type in the
brand name and model number to of your set, to its
search box, and press '
Enter' or view it in
Mosaic /
Timeslide option.
10/6/2013 9:56:03 AM •
Fujitsu...
Answered
on Oct 06, 2013
Power dose not turn on
When i put plasma into power. The power light 1st turn green and suddenly goes red and does not gets on.
11/4/2011 8:44:25 AM •
Fujitsu...
Answered
on Nov 04, 2011
Have a fujitsu pds4229w-s it turns on and then
Hi
Thanks
for using FixYa. A plasma TV is a very hard working device. It is
working harder than any TV that has been built before, and as a result it
produces a lot of heat. 75% of technical problems in plasma TV's are caused by
overheating problems. X, Y sustain, buffer boards controls
picture, fires the gas, and many others functions. When either of these boards goes
bad common problems include negative image, no image, vertical or horizontal
stripes on picture, turns on and than turns off, and many more. You’ll need to
open the back off the TV and check for any swollen/bulged/leaky capacitors on these
boards and replace whichever has gone bad. All this is only recommended if you
have electrical expertise & know how to solder/re-solder components as these
units contain high voltages even when switched off. Please do accept the solution if
the issue is resolved or else revert for further assistance.
Thanks
Rylee
3/12/2010 6:12:02 PM •
Fujitsu...
Answered
on Mar 12, 2010
The problem is definitely not your sustain boards. The symptoms of a faulty X sus board is heavy dark staining over the image, like a broken dark cloud over the picture..or...no picture at all when the X sus is totally damaged. The fault symptoms of a faulty Y sus board include..no picture to a picture being present but with sparklies all over the screen. If the Y sus buffers are faulty, you would have no picture..or a picture with static lines or bars across it. How are you connecting your video source? If you are using Scart, i would make sure that the lead isnt faulty by swapping it for another to be sure. Ive seen weird symptoms like the one you have described from a loose Scart plug or faulty lead. If you are using HDMI, i once again suggest that you try another lead to rule out the lead. Another test would be to swap the input ports .i.e another scart input or another HDMI input. If you are connecting video via the UHF input, try another input and see if it does the same. If not, you will have a faulty tuner. I think the best way is to try connecting video via UHF, Scart and HDMI..does fault occur on all 3 inputs? You state that picture is ok at first..is this from TV being switched on cold.If so it may be the power supply warming up and developing a thermal fault. Cheack power supply caps (if they are bulging at their tops replace them)
3/10/2010 7:36:21 PM •
Fujitsu...
Answered
on Mar 10, 2010
Have
Your diagnosis is spot on. The sparkling picture is caused by failed sustain board. But to diagonise which one is bad you are going to need a multimeter with the ability to measure capacitance(Upto atleast 1mF).
Note that if you do not have prior experience in electronics you can have a tech diagonise which one it is and order the part online and have him replace it in your set. It is not advisable to handle High VOltage electronics with out prior experience.
3/10/2010 6:48:35 PM •
Fujitsu...
Answered
on Mar 10, 2010
Reinstalling Power supply
The green wire with yellow stripe goes to ground anywhere on the chassis. And the black cable should be keyed so that you can only hook it up in one place.
3/26/2008 5:17:15 AM •
Fujitsu...
Answered
on Mar 26, 2008
No power up
After servicing for 3 years, my Fujitsu PDS-4229 has exactly the same problem as yours and I've put it aside for nearly 2 years. Have you found any solution yet? Someone was selling the service manual on eBay. Would you like to share the cost of GBP 5.0 (~ US$10.5)?
12/17/2007 5:04:26 PM •
Fujitsu...
Answered
on Dec 17, 2007
