20 Most Recent Fujitsu Plasmavision PDS-4221 42 in. Television Questions & Answers
the fujitsu pds 4222ws uses bnc connectors. they have all kinds of adaptors to use for any type of wire
Fujitsu... • Answered on Aug 29, 2013
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
There is details about the blinking codes to Fujitsu Plasma Display.
Fujitsu... • Answered on Nov 03, 2012
Looks like there is a mismatch in the connections.
Fujitsu... • Answered on Aug 23, 2012
i have one call 631-838-3516
Fujitsu... • Answered on Oct 09, 2011
Hi.
It sounds like the same thing that is wrong with a huge number of tv's nowadays.
Your tv is suffering from capacitor failure.
These small parts control the entire tv's power system.
They act like small booster batteries, and give a large pulse to the tv to energize the screen.
Unfortunately, there is no easy fix, other than taking it to a business with specialized techs that do this type of repair.
The reason that it need specialists is because of the capacitors being very dangerous.
Even when they aren't turned on, they can still hold 100 volts or more of static charge each, so that they give a combined power output sufficient to turn the screen on.
The best two places that I have found are Fry's, and BestBuy.
Both of these companies have the specialists for this repair.
Before you pay for the repair, have them give you a quote as to what the repair cost is going to be.
You may find that it would be cheaper to just replace the tv instead of repairing the old one.
I hope this helps you understand what is going on.
Good luck to you, and have a nice day !
Fujitsu... • Answered on Apr 24, 2011
I doubt if its a power cord problem. Anyway you need a IEC 3 pin power cable. Try it.
Fujitsu... • Answered on Mar 19, 2011
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Fujitsu... • Answered on May 11, 2010
Take a SCART lead and connect the output from the SKY box and connect to anyone of the SCART sockets on the TV. Alternatively take the digital out from the Sky box to a digital input on the TV. The necessary connection wires can be obtained from most TV Retailers, Electrical Chain Stores, Some PC dealers, online at eBay, etc. Direct Digital connection will give the best quality picture and if you use a SCART cable then make sure it is high quality thick shielded cable and gold flashed connectors as there are many inferior products out there.
Fujitsu... • Answered on Oct 24, 2009
Hi, Power your HDTV off and power back on, if the problem persist the your power supply board is faulty. If your device falls within the warranty period then you just might have to send it back to the manufacturers and if it does not fall under that period then you will have to carter for the cost of replacement. Regards
Fujitsu... • Answered on Aug 31, 2009
HI , i have the same problem . it is either the power supply unit or the plasma display panel . I am problem solving it currently . generally the cost is about $1000 (aus) to fix . it is worth doing as fujitsu are outstanding plasmas .
if u need service manual pls email me at [email protected] and will send service manual .it has the the checks to do so u know which part needs replacing . U need some experience to do the checks
hope this helps
Fujitsu... • Answered on Dec 21, 2007
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. https://homenol.blogspot.com/ http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Fujitsu... • Answered on May 28, 2020
Test the power to the outlet first. You can simply plug your phone charger in and see if you can charge your phone. Assuming the outlet is fine...
If it's a universal type of cord (one that doesn't need to be specially ordered), get a new cord and try that.
If that doesn't work, you'd at this point need to consider either taking it to a TV repair shop, or get a new TV. I'd recommend a new TV because there's very affordable brands like TCL.
Fujitsu... • Answered on Mar 06, 2019
Fujitsu Plasmavision PDS-4221 42 in. Television Logo
Popular Tags
20 questions posted
Top Fujitsu Televison & Video Experts
ADMIN Canada
ADMIN Canada
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Televison & Video
Most Popular Question
fujitsu plasma vision monitor pds42211
  • Televison & Video
