20 Most Recent Fujitsu PlasmaVision P50XHA40US 50 in. HD-Ready Television Questions & Answers
I have a 50"monitor that will not go on
my plasmavision is dead..how to service
9/21/2013 6:20:48 PM • Fujitsu... • Answered on Sep 21, 2013
0answers
Hitachi will not turn on
power supply need to check..
1/12/2013 9:23:57 AM • Fujitsu... • Answered on Jan 12, 2013
Lg 50 inch won't come on
LG tv won't come on
1/12/2013 1:50:17 AM • Fujitsu... • Answered on Jan 12, 2013
Red led flashes once green led flashes twice will not start
bad power supply
10/20/2012 8:30:07 PM • Fujitsu... • Answered on Oct 20, 2012
Picture but not sound on
May I know if you haven't a sound in all inputs?
If you hooked up the sound input to other system before, you must hooked up now the audio input at the back of your TV to get the sound.
Please double check the audio hooked up at the back panel of your TV, try to hooked it first on Audio1 input, then to Audio2 input, and finally to Audio3 input.
Jdvillanueva
9/21/2011 11:26:11 AM • Fujitsu... • Answered on Sep 21, 2011
Picture but not sound on my Fujitsu Plasmavision.
Picture but not sound on my Fujitsu Plasmavision. TV used to be hooked into a control 4 system that handled sound but now no system is attached. Help! Tried adjusting the sound settings for a while last night to no avail.
9/21/2011 10:55:53 AM • Fujitsu... • Answered on Sep 21, 2011
My TV monitor has developed a vertical blue bar
The unit does need service. where are you located ? I can point you in the right direction. It may be less expensive to replace the unit. what was its original cost?. I would have to do a little digging, but may find the answer and a relative cost for you. post a comment/reply on this question and I will try to help you further.
6/1/2011 5:23:32 PM • Fujitsu... • Answered on Jun 01, 2011
When I turn on my
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
5/5/2011 6:16:17 PM • Fujitsu... • Answered on May 05, 2011
When turn on, Power Lamp
This problem has three symptoms; 1. Power problem, 2. Lamp problem or 3. ballast problem.
One of the above three has to be the problem of the TV...
How long have you been using this TV and have you ever changed the lamp?
A bad or dying projection lamp could cause the problem, also a defective ballast. The ballast board helps to ignite the lamp. So, you might need to replace the projection lamp and if possible, ballast board.
As for the power, once a TV does not turn on, it is said to have a power problem. This issue is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
3/9/2011 10:36:05 PM • Fujitsu... • Answered on Mar 09, 2011
We had a power outage
There is not much to set, just check that the receivers are set to HD. Eventually try unplugging the plasma TV from main for twenty minutes.
Check video options if the two boxes have HD settings , then set them to 1080p HD output.
If that does not work, try swappping wideo input, sometimes a power surge may damage HDMI inputs on an HD TV.
9/16/2009 7:26:00 PM • Fujitsu... • Answered on Sep 16, 2009
2answers
50" Plasma Fijitsu TV
You should go to the audio menu and make sure your not in the SAP(Second Audio Program) mode. also check around at the other features in that audio menu. If still does not work, there is a 3 year warranty on this model. Call up where you bought it and find out who to call for service. Good Luck Ps Please dont forget to rate this thread.
11/25/2006 8:37:43 PM • Fujitsu... • Answered on Nov 25, 2006
Won't turn off
Unplug the unit from the wall not just to turn it off but to see if it resets and goes back to normal.Plugn it back in after 5-10 minutes.Good thing for you is new.
10/3/2006 3:27:29 PM • Fujitsu... • Answered on Oct 03, 2006
Fujitsu PlasmaVision P50XHA40US 50 in. HD-Ready Television Logo
24 questions posted
Top Fujitsu Televison & Video Experts
Marvin
Marvin
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Televison & Video
Most Popular Question
when turn power lamp
  • Televison & Video
