20 Most Recent Gateway LCD30TV Television Questions & Answers
A start-up surge after an outage may have affected the power supply.
Gateway LCD30TV... | Answered on Dec 31, 2017
sample of a line diagnally from bottom to top of page.
Gateway LCD30TV... | Answered on Mar 17, 2008
Hola Christian, por la falla que describes, parecer?a ser un problema de fuente de alimentaci?n, podr?as tener los capacitores hinchados, esta condici?n puede generar la falla que comentas
Si tienes conocimientos t?cnicos, puedes reemplazar los capacitores hinchados y alg?n otro cercano
Te envio un video
Espero puedas recuperar el monitor lo antes posible
Saludos Franco Dosil
Hello Christian, for the failure that you describe, it would seem to be a problem of power supply, you could have the capacitors swollen, this condition can generate the failure that you comment
If you have technical knowledge, you can replace the swollen capacitors and some other nearby
I send you a video
I hope you can recover the monitor as soon as possible
Greetings Franco Dosil
Gateway... | Answered on May 10, 2019
Should be a setting in the setup menu. Set picture size from Stretch, to Normal.
Gateway... | Answered on Jan 02, 2017
You want a converter box for what?? You all ready have a HD display and you can support S-Video so why a converter ??
Gateway... | Answered on Nov 18, 2016
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Gateway... | Answered on Jul 09, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts. ..
Televison &... | Answered on Apr 17, 2016
have a look at all the ventilation slots and openings for dust, fluff and other similar obstructions, a slight reduction in cooling airflow can have a dramatic effect on equipment internal temperatures
Gateway... | Answered on Jan 20, 2016
Gateway LCD30TV Television Logo
6 questions posted
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Televison & Video
Most Popular Question
diagonal lines moving from bottom top
  • Televison & Video
