20 Most Recent EliteGroup ECS G41T-R3(V1.0A) LGA 775 Intel G41 Micro ATX Intel Motherboard Questions & Answers
0answers
When I start PC, nothing display
Hello Sam, make sure you are using a good RAM module. check your RAM with other PC prior to your PC.
1/3/2014 2:04:27 AM • EliteGroup ECS... • Answered on Jan 03, 2014
After rebooted on desktop, there is no network
For the quickest fix get another LAN card.Your motherboard LAN card is not working correctly and will show up and disappear from time to time.
10/21/2013 6:40:20 AM • EliteGroup ECS... • Answered on Oct 21, 2013
0answers
Cmos setting wrong how to fix it?
..try to change the CMOS battery..
8/9/2012 3:21:58 AM • EliteGroup ECS... • Answered on Aug 09, 2012
Lan problem.yellow mark..
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers hope this helps if you cant find the driver hopefully one of these will help you
http://alpha.majorgeeks.com/Intel_Network_Adapter_Driver_for_Windows_7_d6273.html
http://majorgeeks.com/SiS191_Gigabit_LAN_&_SiS190_LAN_Driver_d5923.html
http://majorgeeks.com/IntelR_PROWireless_LAN_2100_Network_Connection_d4598.html Latest http://majorgeeks.com/downloadget.php?id=5240&file=15&evp=5fbb1c6e47482358c61a5236fb38a112
2/11/2012 7:08:22 PM • EliteGroup ECS... • Answered on Feb 11, 2012
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
What is the basic code for html code for
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
5/11/2016 10:20:28 AM • EliteGroup... • Answered on May 11, 2016
Computer will not enter bios during boot
PRESS F2 or del if you have usb use a an adapter for a ps2 connector from the keyboard will probably help to set your bios settings maybe replace your backup battery when you have lost your settings.
2/14/2016 12:19:59 PM • EliteGroup... • Answered on Feb 14, 2016
Ecs 848p-a v1.0
The manufacturer's support page for this motherboard can be found at the following link http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0 Perhaps the answer to the question you have not asked is found there.
9/8/2015 6:14:13 AM • EliteGroup... • Answered on Sep 08, 2015
P4S5MG/GL+
A manual for this motherboard can be found at the following link http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5mggl50eng.zip In the downloads section of the support for this board, there was no "Auto Setup Program". Downloads from the manufacturer for this motherboard can be found at the following link http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=42&CategoryID=1&MenuID=18&LanID=0#fragment-Download
9/8/2015 6:11:13 AM • EliteGroup... • Answered on Sep 08, 2015
Where is the battery
If you are asking where the CMOS battery is located, you will need to firs provide the model number of the ECS EliteGroup motherboard. Here is a link to help you locate yours http://www.ecs.com.tw/extra/productinfo/MB.htm
9/8/2015 5:43:48 AM • EliteGroup... • Answered on Sep 08, 2015
Hello there please guys help me I bought ecs elitegroup motherboard but it doesn't detect my g210 invidia geforce after plug my graphic cart it shows strange lines
suspect you may need to disable the motherboard built in graphics card and tell it to use PCI graphics adapter otherwise an interrupt conflict in CPU and possible conflict as both devices compete for same computer resources.
8/15/2015 1:38:38 AM • EliteGroup... • Answered on Aug 15, 2015
EliteGroup ECS G41T-R3(V1.0A) LGA 775 Intel G41 Micro ATX Intel Motherboard Logo
20 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
dont motherboard driver
  • Computers & Internet
