20 Most Recent Panasonic Toughbook 19 Rugged Notebook - CF-19K4RAX2M Questions & Answers
Boot menu panasonic toughbook
Go to the top right hand side to get to the search function (magnifying glass). Fill in the search box with 'msconfig'. It should find msconfig.exe. click on this file and you have access to the boot menu amongst other functions.
8/9/2014 4:42:17 PM • Panasonic... • Answered on Aug 09, 2014
My screen does not flip 180 degrees when i turn the screen around
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display. Windows XP/Vista Monitor Orientation Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
1/28/2013 8:31:41 PM • Panasonic... • Answered on Jan 28, 2013
Screen upside down on a panasonic CF-T8
On any Panasonic Toughbook you can rotate the screen as follows: Hold down the "CTRL" and the "ALT" keys and while holding down these two keys press the "UP Arrow" key and then release all three keys. This will reset the screen so it is right side up instead of upside down. Good Luck and regards from: Richard, Authorized Panasonic Canada Toughbook Dealer since 1989. P.S. The arrow keys look like this: The up arrow is the one on the top arrowkeys-wizlq2ugugduqihzx2y1x4lj-1-0.jpg
4/6/2018 5:40:18 PM • Panasonic... • Answered on Apr 06, 2018
How do I turn on the keyboard lights on the Panasonic CF-53. I don't know the function.
I'm not sure if yours is the same layout as the CF-53 I use. But my F12 button has a picture of a button with light on it. I use FN-F12 to adjust the brightness of the keyboard. Mine goes through 5 brightness levels before returning to off and starting over.
12/3/2016 2:49:23 AM • Panasonic... • Answered on Dec 03, 2016
Panasonic cf-y4 driver
The VGA or "Video Driver" for the Panasonic Toughbook CFY4 can be found at: http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html Remember to choose your operating system and then click on the "Download Now" button located on the right side. Good Luck! Regards, Richard - Montreal Based Panasonic Canada Toughbook Dealer since 1989
2/18/2016 5:54:02 AM • Panasonic... • Answered on Feb 18, 2016
F11 key
From two different websites: The same answer 1) "F-11 seems to have been an emergency hot key for police use" The website: http://forum.notebookreview.com/threads/rubber-illuminated-kb-cf-29.239110/ 2) "The red F11 can be programed to report through police dispach an officer is in trouble. This key only works with Special software used by Law Enforcement." The website: https://groups.google.com/forum/#!topic/toughbook/J__ssDTCm_0 Both these guys gave the same opinion and both seem very knowledgeable. Good Luck! Regards, Richard - Montreal Based Panasonic Canada Toughbook Dealer since 1989
2/18/2016 5:13:06 AM • Panasonic... • Answered on Feb 18, 2016
Screen stays dark
On ALL Panasonic Toughbook Models, if the screen stays dark I would shut-off the Toughbook and connect an external monitor to the VGA port (15-pin female connector), which is usually BLUE in color. Make sure the monitor is ON first, then turn ON the Toughbook. If the monitor comes on then your problem is the backlight or possibly the inverter of the screen. If no image is shown on the external monitor and the screen stays dark and you cannot hear any startup (ie. Windows) sound, then your video card may be defective. Very few Toughbooks fail this way since they are normally very very relaible but it can happen. Good Luck Regards, Richard - Montreal Based Panasonic Canada Toughbook Authorized Dealer since 1989
2/18/2016 4:50:23 AM • Panasonic... • Answered on Feb 18, 2016
0answers
CAN I PLUG AN 18 VOLT CHARGER INTO MY LAPTOP THAT SAYS ITS 15.6 VOLTS
yes, but you should be able to get a universal charger with proper output cheap
2/8/2016 5:32:07 AM • Panasonic... • Answered on Feb 08, 2016
Laptop dies when unplugged
Panasonic Toughbook PC Laptops usually have very reliable battery pack. When your unit is plugged-in but the Power is OFF, you should see an LED light as follows: RED FLASHING: Means the battery needs replacement. Orange/Yellow Solid: Means battery is charging. Solid Green: Means battery is fully charged. NO Light AT ALL: Means that Battery Pack is missing. There is also a battery calibration utility on all Panasonic Toughbook PC's manufactured since 2004. This is a factory installed software and is only present in factory units. This software may also be downloaded as a driver from the Panasonic Toughbook website as follows: http://pc-dl.panasonic.co.jp/dl/ Check also in the bottom right hand corner under Windows for the battery Icon. This will indicate if the battery is charging, present or not present, and under Windows 7+ will indicate if the battery needs to be replaced or not. Good Luck! Regards, Richard - Montreal Based Panasonic Toughbook Authorized Dealer since 1989.
2/8/2016 5:27:55 AM • Panasonic... • Answered on Feb 08, 2016
0answers
CF-30KCPALAM
Be the first to answer 10/26/2015 9:26:30 AM • Panasonic... • Posted on Oct 26, 2015Be the first to answer
How to fix wireless on toughbook cf 29h
Hi, Follow the attached link download and install the driver and software.
3/7/2015 5:03:53 PM • Panasonic... • Answered on Mar 07, 2015
0answers
Panasonic cf-30 touch screen not working
Replace the screen if possible. Ifnot replace the laptop.
4/14/2014 12:40:38 AM • Panasonic... • Answered on Apr 14, 2014
0answers
0answers
Cf-29
Be the first to answer 4/4/2014 9:59:02 PM • Panasonic... • Posted on Apr 04, 2014Be the first to answer
Panasonic Toughbook 19 Rugged Notebook - CF-19K4RAX2M Logo
4 questions posted
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Toughbook Panasonic
  • Toughbook Panasonic
Most Popular Question
boot menu panasonic toughbook
  • Computers & Internet
