20 Most Recent Alpine PDX-F4 Car Amp Questions & Answers
Disconnect all speaker leads from the PDXf4 - test. If the amp turns on and says on ok - then turn off, and attach one speaker lead at a time until it turns off. When it does check that speaker and the speaker wire to see if it is blown, shorted out etc.
Alpine PDX-F4... | Answered on Feb 06, 2011
What is the code of bontec alpine a06012 car stereo
Alpine Car Audio... | Answered on Nov 03, 2020
Frankie. I am having the same problem. Did you find an answer or do I need to get a new power pack or control unit?
Alpine Car Audio... | Answered on Aug 15, 2020
I can't find the power wires on my Alpine CDA 7894
Alpine Car Audio... | Answered on Apr 17, 2020
Is this a custom instal? If yes, Check that the amps are powering up. You may need to check the fuse for the amps or the remote wire fuse. It could have blown hooking up the new battery. If there are no amplifiers check both fuses for the Alpine deck unit.
Alpine Car Audio... | Answered on Jan 07, 2020
Unplug it for about 5 minutes
Alpine Car Audio... | Answered on Nov 26, 2019
Unless other specified in paperwork, all Alpine receivers are 4ohm capable only.
Now yes there are exceptions, but not many.
Now for amp almost all alpine amps can be run in several different resistances.
Basically for sure 4ohm, now depending on model some have abilities to go as low as 1ohm stable. But for most 2 ch alpine non special amps are all 4ohm and most 2ohm capable.
Now better models can do things such as run 2,3,4 ch. And some can even get to .5 ohm loads stable.
Alpine Car Audio... | Answered on Oct 16, 2019
Do you have an external amp? Give me more info on stereo going in, and what it does do.
NEW Alpine INE-W940 Head Unit - YouTube
? 4:49
https://www.youtube.com/watch?v=1wv1LzdUYiM
Sep 5, 2013 - Uploaded by Mx Car Audio
I recently bought the Alpine W940 and the bluetooth that connects to ... A simple reboot at the shop and the ...
[PDF]INE-W940 INE-NAV-40 INE-W940S - BrandsMart USA
www.brandsmartusa.com/pdfs/manuals/20181335.pdf
sp?ciales, de l'actualit? d'Alpine, et vous aurez une chance de remporter des prix. Gracias por adquirir ... MANUAL DE OPERACI?N .... Listening to the Radio .
In Case Of Difficulty - Alpine INE-W940 Owner's Manual ...
www.manualslib.com > ... > INE-W940 > Owner's manual
Alpine Car Audio... | Answered on Sep 16, 2019
I would think a 1000 watts would be enough for 2 10's.
You can hook up two dual voice coil subs a few different ways.
First thing I would check for is what ohmage your amp is rated for.
You don't want to push a lower ohmage than what your amp is rated to handle.
That is a good way to overheat & ultimately fry your amp.
After that, you can wire your subs accordingly.
If they are dual 2 ohm subwoofers, you can wire each of them as a 4 ohm load, 2 ohm load or even a 1 ohm load.
I would personally go by what the amp is ratted for.
Remember though, the lower you run the ohmage, the better base responce & harder the hit you will get.
Alpine Car Audio... | Answered on Jul 10, 2019
manualslib.com is a 100% free online manual for any manual needed and if you want to buy there is that option to or simply just print out the pages if you have that much ink..but just an option...Hope this helps...
Alpine Car Audio... | Answered on Jun 29, 2019
Make sure even thought the wires are the same color that your car color code also matches the color code of the Head Unit if not stock radio then the color code would be in your cars manual book or find it online in the image section of the browser you are using or better yet just order your self the radio adapter for your cars model for that type of head unit your installing or troubleshooting in your case and make sure all wires and positive wires are hooked up properly because some devices will not work if all the wires are not wired correctly meaning left terminal to left and right terminal to right speaker and positive and negative wires installed correct as well.. Hope this helped..
Alpine PDX-F4 Car Amp Logo
2 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
just install new
  • Car Audio & Video
