20 Most Recent EnterTech Magic Sing Et19k Et-19k Et19kv Et-19kv Questions & Answers
Magic Sing ET19KV On connecting Magic Sing through RCA Cable, get buzz sound on my speakers Have chked on diff TV's and replaced the RCA cable.The Video is clear, but getting buzz on speaker
Most buzzes are caused by one of two things: "DIRTY" power or a lifted\non-existent ground. Allow me to explain; "DIRTY" power is just that. It comes in and carries a lot of static with it. Most newer systems have filters built in on the power side of the main board. The fix? Try running your Magic Sing from a wall socket that doesn't have anything else pulling from that particular circuit. You should also invest in a GOOD power strip and not one that cost $5-$10 bucks. All these are good for is getting power to multiple products simultaneously, AND they don't have the resistors and filters to give you a constant 120v AC. Monster Cable Co. was a very sought after item up to the point to where Radio Shack no longer carried their products. If you really want to get your money's worth out of the instruments you buy, don't slack on the power strip. This will be the most costly mistake ANYONE can make. Here is an article that explains what I did and gives you answers on how to fix this issue. Hope this helps. Dirty Power What It Is and Why You Need to Clean It Up Schneider Electric...
12/3/2017 4:26:22 AM • EnterTech Magic... • Answered on Dec 03, 2017
How do I do transposition in e16 Roland?
To transpose a sound on the Roland E-16 keyboard, you can use the Transpose function. Here's how to do it:
  1. Press the FUNCTION button and then press the TRANSPOSE button.
  2. Use the + or - buttons to select the number of semitones you want to transpose the sound. The range is -12 to +12 semitones.
  3. Press the EXIT button to exit the Transpose function.
Once you have transposed the sound, it will be played back at the new pitch. Keep in mind that transposing a sound may affect the overall tone and timbre of the instrument, so you may need to make additional adjustments to achieve the desired sound.
3/19/2023 10:07:47 AM • Music • Answered on Mar 19, 2023
2answers
I have a Gebr Perzina Piano serial #17358 could you tell me how old is it please.
Go to this site for information about your piano. www.gebrperzina.com
3/15/2023 9:10:54 PM • Music • Answered on Mar 15, 2023
Baldwin Pianovelle RPS keyboard silent
If the demo on your Baldwin Pianovelle RPS keyboard is playing silently, and there is no battery powering the keyboard, then it's likely that the issue is with the keyboard's internal components. Here are some steps you can take to troubleshoot the issue:
  1. Check the volume: Make sure the keyboard's volume is turned up and not muted. Look for a volume knob or button on the keyboard, and adjust it accordingly.
  2. Check the headphones: If you're using headphones, check to make sure they're properly plugged in and not damaged. Try using a different pair of headphones to see if that solves the issue.
  3. Check the speakers: If the keyboard has built-in speakers, make sure they're properly connected and not damaged. If the speakers are damaged, they may need to be replaced.
  4. Check the power: Make sure the keyboard is properly plugged in and receiving power. Check the power cord and outlet for any damage or loose connections.
  5. Check the demo settings: It's possible that the demo is set to play silently. Check the keyboard's manual for instructions on how to adjust the demo settings.
If none of these steps solve the issue, it's possible that there's a problem with the keyboard's internal components, such as the sound card or amplifier. In that case, it may be best to contact a professional technician or repair service for assistance. They will be able to diagnose and repair the issue with the keyboard's internal components.
2/26/2023 11:36:24 PM • Music • Answered on Feb 26, 2023
2answers
My Lexicon MPX100 Dual processor lights remains
Did you get it fixed?
I have exactly the same problem!
2/21/2023 11:47:41 PM • Music • Answered on Feb 21, 2023
2answers
AMEB piano practical exam results for teachers
Examination reports are sent to the Teachers within two weeks of the examination. Certificates are sent to teachers approximately eight weeks after the exam.
Hard copy theory exam results for successful candidates are sent to teachers approximately four to six weeks after the exam. For any exam requiring more than one examiner (Diploma exams) results are processed and sent to teachers as soon as possible after the exam.
On-line theory results (up to and including Grade 3) are available immediately upon completion of exam.
2/18/2023 7:03:25 PM • Music • Answered on Feb 18, 2023
Casio wk 3500 does not turn on
Check the polarity on the adapter plug. It must correspond to the diagram on the keyboard . If it's reversed, just cut and resolder the cable that connects to the keyboard. My 3500 also has a similar problem. It only switches on if I plug the power and immediately press start . If I wait a few seconds it won't start.
2/5/2023 10:50:39 PM • Music • Answered on Feb 05, 2023
Casio MA-120 tone bank manual
An8054 voltage regulator and sound ic has been blown off, no data is available online of ic any other ideas for powering on please help me
1/31/2023 2:00:38 PM • Music • Answered on Jan 31, 2023
2answers
Rogue bass guitar amplifer rb 120 bt
check fuse and if fail, get a shop to fix it. or buy the service manual
1/25/2023 2:16:06 PM • Music • Answered on Jan 25, 2023
Is there a way to factory reset a Yamaha PSR-E403 - 61-Note Portable Keyboard? (or) any way to get a manual/instruction for it? Please Help.. Thank You So Much
Question edited for clarity, full 'make model (what it is)'. Here is the manual http://www.midimanuals.com/manuals/yamaha/ypt-400/owners_manual/psre403_en_om.pdf Press CTRL+F to use the find feature to find 'reset', ignore 'preset' which messes the results to 16 mentions.
1/7/2023 8:57:11 PM • Music • Answered on Jan 07, 2023
Casio Privia PX-135 sound issues?
It sounds like you are experiencing a problem with your Casio Privia PX-135 keyboard. There could be several possible causes for this issue, including problems with the keyboard's internal hardware or software, or issues with the cables or connections between the keyboard and other equipment. To troubleshoot this problem, you could try the following steps:
  1. Check the connections between the keyboard and any other equipment, such as an amplifier or speakers. Make sure all cables are securely plugged in and not damaged.
  2. Try a different set of speakers or headphones to see if the issue is with the keyboard or the output device.
  3. Check the keyboard's settings and make sure that it is configured correctly.
  4. Try resetting the keyboard to its factory default settings. This can often resolve issues with the keyboard's software or firmware.
If none of these steps help, it is possible that
1/2/2023 4:58:57 PM • Music • Answered on Jan 02, 2023
Need manual for Baldwin Interlude Organ Model 127F
https://github.com/quixotictech-dev/Baldwin-Interlude-127f-Technical-Manual/releases/tag/interlude127
12/25/2022 7:36:25 PM • Music • Answered on Dec 25, 2022
My technics sx-px222 digital piano suddenly has no sound but all lights work and i hear a very very slight hum. Fuses look ok. What do you recommend i try next?
Hi, please check that the volume-down button isn't stuck and therefore forcing the volume of your piano to decrease. You might wiggle the button from side to side if you noticed that it's stuck. If possible, attempt to route the piano sound to an external speaker and see if you receive the same results as you initially did. Thank you.
12/7/2022 4:28:01 AM • Music • Answered on Dec 07, 2022
Orla GT8000 electronic organ. Where can I purchase the bolts/screws to secure the top manuals to the bottom cabinet please?
Question edited for clarity, and it appears to be an 8000 not 800. Question moved from Washing Machines category. No maker, no parts lists. The best bet is the fixings aisle in Home Depot. https://www.google.com/search?q=orla+gt8000+parts+manual ..
12/6/2022 5:43:49 PM • Music • Answered on Dec 06, 2022
I have an electone organ that when turned on its all static nothing else
If you have speakers connected to it, disconnect them to see if the static stops. If there are no speakers clean the on / off switch and any volume controls with electronic switch cleaner. Other ideas here https://www.google.com/search?q=electone+organ+static+noise ..
11/18/2022 6:44:15 AM • Music • Answered on Nov 18, 2022
I have a crate vtx200s. my problem is the amp will
Cold solder joints or broken solder joints at din plug junction on board
10/21/2022 10:02:09 AM • Music • Answered on Oct 21, 2022
3answers
I cant get the disc drive to work on my technics
Try formatting a fresh disk in the KN2000. If it doesn't work, something in the drive has gone bad. First thing would be to CAREFULLY clean the heads using 91% isoprophyl alcohol.
10/10/2022 3:14:15 PM • Music • Answered on Oct 10, 2022
EnterTech Magic Sing Et19k Et-19k Et19kv Et-19kv Logo
3 questions posted
Top EnterTech Music Experts
Marvin
Marvin
Are you an EnterTech Music Expert? Answer questions, earn points and help others
View Most Popular
EnterTech Music
  • EnterTech Music
Most Popular Question
magic sing et19kv connecting magic sing
  • Music
