20 Most Recent Hyundai Sonata 09 2009 Questions & Answers
Why is my 2009 hyundai sonata battery dying after only 3 years?
Hello! First of all, is it a three year battery?...If not,lets check the alternator output...You'll need a multimeter (digital is best)...If you do not have one they can be bought at Lowes or home Depot for under $20...With the key off measure the voltage across the Battery...Example 12 volts...Start the engine...take the reading again...should be 13.9 volts...ie...1.9 volts higher, which means the alternator is working...If all of the above is correct something is remaining on that's draining the battery...most common is the under-hood light remaining on...Lastly, it's just a bad battery that needs replacing...Your vehicle requires a minimum of 600 cranking amps...Send a comment..Guru..saailer I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
1/17/2012 2:35:59 PM • Hyundai Sonata... • Answered on Jan 17, 2012
Need to know how to replace the rear window brake
Unplug the connector in the trunk. Remove the 2 gold-colored screws from inside the trunk. They can be seen from the trunk. One of them is thru the larger square opening where the wire connects to the high-mount brake light. The second is on the right side thru a small (screwdriver width) hole covered by a piece of foam tape. After removing the 2 screws, go inside the cabin and the brake light housing pops right up. Disconnect the bulb from the housing while inside the cabin. Back in the trunk, remove the wire and bulb. The wire from the connector to the bulb socket should be about 5 inches long.good-day !
11/3/2011 5:03:39 AM • Hyundai Sonata... • Answered on Nov 03, 2011
2014 Hyundai i20. Radio in it won't eject disc.
Did you try resetting the Radio / CD? You may need the Radio Security Code, so make sure you have it. https://www.google.com/search?q=hyundai+i20+reset+radio ..
5/12/2023 4:23:28 PM • Hyundai Car... • Answered on May 12, 2023
My question wasn't answered, so here it is again. my Hyundai stereo says error 4 when i try to play CD's i have copied?
I surprised people still burn cds...time for a new radio the laser might not read mp3
5/13/2019 12:37:50 AM • Hyundai Car... • Answered on May 13, 2019
I have 05 hyundai XG 350. The wire harness was cut so im wiring aa cd player and new harness together.. The are throwing me off. I have 2 yellows a black wire with white stripe. One green with a brown stripe.. A. Blue and a tannish color one.. Which is the ignition .. The battery and the ground
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
2/6/2019 9:21:30 AM • Hyundai Car... • Answered on Feb 06, 2019
Po-hm5064h-01
Tengo un estereo de nissan modelo po hm5064h-01 y no tiene la clavija del cableado, como se puede saber en cual pin soldarle los cables
4/13/2017 7:58:24 PM • Hyundai Car... • Answered on Apr 13, 2017
3answers
I have recently purchaes Hyundai
This problem seems to be common in Hyundai i20 with AVN sold in India.
My i20 with AVN also has the same problem. The Hyundai dealer is not able to solve this issue. He has replaced the AVN system also, with no luck.
I suggest you contact your dealer to rectify this issue.
regards, Pradeep
6/26/2014 4:16:12 AM • Hyundai Car... • Answered on Jun 26, 2014
What is the best way wire diagram of Hyundai sonata 2004
Color codes for 2004 hyundai sonata stereo wiring Yahoo Answers Try this link. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
6/9/2014 9:10:17 AM • Hyundai Car... • Answered on Jun 09, 2014
Where can i find original car audio kit for my hyundai?
try the Hyundai sellers
2/26/2014 12:33:30 PM • Hyundai Car... • Answered on Feb 26, 2014
0answers
0answers
Hyundai Sonata 09 2009 Logo
6 questions posted
Top Hyundai Car Audio & Video Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Hyundai Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hyundai Car Audio & Video
Most Popular Question
need know replace rear window brake
  • Car Audio & Video
