20 Most Recent Mitsubishi Lancer 08 2008 Questions & Answers
Sounds like something is causing a power drain. If you know how to use an amp meter it's not too hard to find it. Disconnect the positive terminal from the battery with the meter set on amp put one lead from the meter on the battery terminal the other to the cable you took off the battery so that the current goes through the meter if it shows a drain pull out one fuse at a time until no drain seen then just check what that fuse goes to.
Mitsubishi... | Answered on Mar 28, 2015
Based upon what you have said, it would seem that you have something that is causing a continuous battery drain. Have you added any new electronics to the vehicle that may have accidentally been wired up to a constant hot source instead of one that is controlled by the ignition switch? Many enthusiasts accidentally install stereo amps directly to hot and find they never shut off, killing the battery. If you are skilled at electronic troubleshooting, you may be able to track down a wiring problem yourself. I will warn you that many repair shops will attempt to diagnose your problem, but few are trained to do it efficiently. If you decide to pay a pro to fix it, go to an Auto Electric specialist. They charge more per hour, but will take far fewer hours to locate and repair the problem than the corner mechanic.
RED /blk-LAMP ON==12 VOLT CONSTANT
BLACK--GROUND
PURPLE/BROWN==LAMP AUTO OR FACTORY DOOR SWITCH
Mitsubishi Car... | Answered on Feb 19, 2019
First check and make sure your + and - wires are in the wright place and the remote wire coming from the head unit is in the remote spot also make sure you have a good ground and is not loose. Its easy to get the + and - crossed even if you are sure check again I have done this a few times before even after I was for sure...Hope this helped.. The Orange or Red light is a protect light telling you something is wrong just retrace steps and make sure all the wires are connected right if not the wires then most likely the problem lies inside the amp.. Good luck...
Mitsubishi Car... | Answered on Mar 10, 2018
In the USA anyone can get their radio code for free direct from Mitsubishi by telephone. You will need the following information:
Last 8 characters of your VIN # Radio Serial Number
Call Mitsubishi:
1-888-648-7820, option 1, option 4 Current hours: 6am to 5pm Pacific, M-F.
Tell representative that you replaced your battery and now need your radio code. If you are not currently a registered owner, they will ask for your info for registration. ==============================================================
If not in the USA then sorry....Main MITSUBISHI Dealer or Radio Decoding Service only for this code
It will not be available for free or cheap from anywhere on the Internet
Mitsubishi Car... | Answered on Aug 06, 2014
dont know how to reset clock on my 2004 magna
Mitsubishi Car... | Answered on Jun 04, 2013
Actually you want to enter a code to make the radio work. To do this, make a trip to your Mitsubishi dealer
Mitsubishi Car... | Answered on Mar 06, 2013
Mitsubishi Lancer 08 2008 Logo
5 questions posted
Top Mitsubishi Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
ray gallant
Alphanso Tee
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Car Audio & Video
Most Popular Question
08 lancer battery keeps going dead tried
  • Car Audio & Video
