20 Most Recent MSI MEGA Stick (256 MB) MP3 Player Questions & Answers
To play a microphone recording file, press the Menu button once, and then push the Menu button to the right once, and now you should read the message of VOICE appearing on the Display. Press the Menu button again, and then use the Menu button to select a desired microphone recording file by pushing the Menu button to the right or to the left. Once the desired microphone recording file is selected, press the "play/pause" button to start playing the file.
this is all from the manual hope this helps
MSI MEGA Stick... | Answered on Jun 26, 2011
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
MSI Audio... | Answered on Oct 05, 2010
This speaker is very good.
Audio Players &... | Answered 2 hours ago
Then you must do it! This is the reason;
The reason you are receiving this this message is that some of the Viera Cast features require the accurate time on the TV, so if the clock is not set you will receive this message when trying to use the Viera cast or Connect function. ... Unfortunately it is not possible to manually set the time on the TV.
Please confirm clock setting error message, when trying to use ...
Audio Players &... | Answered 14 hours ago
Request the manual from the manufacturer/distributor.
Audio Players &... | Answered 15 hours ago
Hello, Daniel -
I suggest you contact JPay directly (via a telephone call). This is the link to the JPay Contact information:
https://www.jpay.com/ContactInfo.aspx
I believe you will need to send the JPay 5 to JPay with a check to cover the unlocking fee. JPay will send the unlocked JPay 5 back to you.
Best wishes.
Audio Players &... | Answered 2 days ago
Contact Thomas directly to request instructions.
It would be helpful to know a model.
I have the service manual for the LT-120 which explains how to do that. There are explanations with diagrams, etc. that won't help without your being able to see them.
Audio Players &... | Answered 3 days ago
Unknown if the following is the one you were looking for, but link has many manuals which ask for an ES version.
http://nsmjukeboxmanuals.yolasite.com/
" Welcome
Here you can find nearly all the NSM jukebox manuals for nearly all the ES- Versions of these fab machines
All you need to know is the ES version of your machine. This is usually printed inside your machine, on the CD player unit or on the record players assembly. Sometimes its printed or stamped into a metal plate by the power lead. It's important you find the correct model and ES version as you can sometimes cause more damage then good!
If you cant find your specific manual try the generic manual for that ES version, this should contain most the stuff you need
http://nsmjukeboxmanuals.yolasite.com/resources/The%20Performer%20Grand%20II.pdf
By "stuck on android", the entire operating system is android. It is the Google Android operating system.
If the device cannot load up then it may need a factory reset. I am assuming like most android devices it has volume keys. If this is the case, turn the device off. Then, hold down the Volume DOWN button and keep holding it. Then turn the device on (still holding volume down). This will bring you to the recovery screen. From these selection, you can select using volume up and volume down. On that menu or one of the sub menus should be the option to do a data reset (factory reset etc). Select this option.
This will restore the device back to factory settings
WARNING: Doing the following will remove ALL data from the device, and MAY potentially stop the device from working. However, seeing as its not working at the moment anyway, you don't have an awful lot to lose!
Knowledge: HTC Desire owner (rooted) : Restored 10+ times with no errors
Audio Players &... | Answered on Jul 02, 2020
My sound don't come out please help my [email protected]
Audio Players &... | Answered on Jul 01, 2020
HI I HAVE FIXED THE SAME FAULT ON MY SONY SCANNER BUT NOT FOR THE FAINT HEARTED!. YOU WILL HAVE TO UNSOLDER AND EXTRACT THE CONTROL AS THE TRACK SPRING LEAVES HAVE BECOME WEAK AND ARE NOT TOUCHING THE TRACK PROPERLY.CAREFULLY TAKE APART THE CONTOL CLEAN ANY RESIDUE ON THE TRACK AND CONTACT SPRINGS THEN RE ASSEMBLE AFTER SLIGHTLY BENDING THE CONTACT LEGS TO IMPROVE PRESSURE ON THE TRACK. BEST OF LUCK I HAVE GOT A SPARE WHICH MIGHT FIT YOUR MODEL. CHRIS
This sounds more like a low power situation. The voltage to the unit might be low, and should be measured.
As far as I know, there's no reset for the unit. Disconnecting the power should reset it, if there is one.
Hi raj
what happens when you turn up the volume... does it come back in again... if so it could be a faulty speaker protection relay, or at least dirty contacts to same. Can be fixed by burnishing the contacts.
Let me know if sharp increase of vol changes the muting problem
regards
Graeme
Audio Players &... | Answered on Jun 30, 2020
I use Allavsoft to download Spotify music to MP3
http://www.allavsoft.com/how-to/spotify-to-mp3.html
It also helps to download from Deezer, Soundcloud, YouTube, etc. Spotify to MP3 Download Spotify Playlist Music to MP3 WAV AAC
Last time I encountered this, the guy's helpful brother had run the format command before loading new songs onto the device and it would no longer work as format also removed the operating software.
Audio Players &... | Answered on Jun 29, 2020
MSI MEGA Stick (256 MB) MP3 Player Logo
3 questions posted
Top MSI Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a MSI Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Audio Players & Recorders
Most Popular Question
recorded voice in msi 527 may
  • Audio Players & Recorders
