20 Most Recent RCA Lyra RD1090 MP3 Player Questions & Answers
Thats happen to me many times its either 2 ways to fix it...Pull the batteries out for then try it again..or your memory card is making it freeze..its done this so many times to me thats why i keep a few cards around...replace your memory card...then the one you took out format it then youll see it will work again later..
RCA Lyra RD1090... | Answered on Feb 19, 2012
Iv had my Lyra RD 1090 for least 6 years now with no problems at all..Why because i never use the software that came with it..What i do is just plug it into a USB port and it comes up in my File MY COMPUTER as a drive you just open it up and fill it..Or if you have a card reader on you PC just take the card out the the Lyra and put it in the reader then fill the card with music then put the card back into your Ltra then your good to go
maybe this caused by virus
scan your mp3 player using antivirus at computer
RCA Lyra RD1090... | Answered on Mar 21, 2011
The cable is a standard USB cable, it's just that there are some peculiar variations on the end that goes into the device. Just take your Lyra to Radio Shack or what have you and make sure to get the right one.
RCA Lyra RD1090... | Answered on Dec 22, 2010
By rights you shouldnt have to download any drivers....out of the box you plug in ur device and it comes up in My Computer as a drive...just like sliding in a SD card and from there you just add or remove ur music.....Using the software that you get from the net is just looking for trouble. I never did and this is why iv gone 5 years trouble free
RCA Lyra RD1090... | Answered on May 28, 2010
i´m not sure if it helps but i fixed the same problem downloading the program from the internet. the problem is that i don´t remember where i went to find the program. try downloads.com ?
RCA Lyra RD1090... | Answered on May 19, 2010
What i do is i remove the card then i insert it in a card reader...i fill the card with music then i insert the card back into the device...tell you it works well...saves you from using the software you get with the device....ill save you all kinds of problems...take the disc that came with the Lyra and chuck it in the garbage and never download nothing from the net...if you can just use windows 7 then all ur problems are solved
RCA Lyra RD1090... | Answered on May 18, 2010
If you have a computer with windows 7 all ur problems will be solved....just plug it in and windows 7 will fix the problems....but one thing it will only run well on 7 so think about changing
RCA Lyra RD1090... | Answered on May 10, 2010
What i do is i never put songs in my internal memory...this way you never have to worry about formating the internal memory....so i have several exteral card i use say one for country or rock and its so easy to format a exteral card just place it in ur card reader if ur using a laptop them go to my computer right click on ur card that youll find then youll notice on the list theres format so its so easy...im sure its asking you to format ur drive because you must have a few corrupted files....best of all when adding music just pull ur external card out place it in a reader fill ur card with music then insert it back in ur device...this way ur getting away with using any firmware....by the way take any disc that came with ur Lyra and chuck it in the garbage that 90 percent of all ur problems
My Lyra does the exact same thing...what i do is i pull the batteries out for a second and the unfreezes the device...then i delete the song that froze my device....then i reload the song..if it freezes again delete that song from ur computer them find a better music provider because most likely the song was corruped
Remove your external card if you have one....Then try plugging ur device into ur computer using windows 7 then your going to have a pop up like if you pluged a storage card into ur card reader....click open folder then youll see all you internal music...right click and start deleteing..If you want to format go to my computer find ur device right click and on the list and youll find format just click it and it will format ur internal memory...or insert ur card and do the same
Have you tried replacing the firmware? The newest firmware for that model is here http://download.rcaaudiovideo.com/downloads/RD1080_90FWUpgrade_v4.26.exe
If you have any problems with ur RCA RD 1090 Try plugging it into a computer running windows 7....Two of my friends have the same device with the same problems...who took my advice after taking there device out of the closet they both plugged it in and they got the same pop up saying you have a problem with ur device would you like windows 7 to fix ur problems and now there both using there devices again and the sweet thing about it they didnt have to download any drivers
RCA Lyra RD1090... | Answered on May 09, 2010
connect your MP3 player to the computer with a USB cord. click My Computer you should see RCA Lyra. Next,
go into windows and open up a folder --- any folder will do (you can use one on your desktop if you like) once the folder opens, please click the little arrow around the top of the folder. you should see it say :
Desktop,
My Documents,
My computer
c:\
(and which ever drives you have on your pc) please look for one called:
RCA_LYRA.
once you see that one, please click on it.
then, what you will see in your folder is all of the music you have inside your mp3 player. even those disturbing audio files that they put into our players.
To delete those files, and any mp3 songs, highlight them, and press delete. then press ok and there you are. if you would like to move the songs to your computer, just highlight them and drag them onto your desktop, or another folder, or where ever yopu would like to put them.
once your done, just unplug and there you go (oh! you can also add files to your player this way. just add them into the folder with your mp3 pluged in).
altight, hope that helps. i hope you all have a nice day and take care. cheers..."
Try this device using windows 7....if theres any problems with your divice windows 7 fixes them...you need no drivers at all..windows 7 really improved this device
RCA Lyra RD1090... | Answered on May 07, 2010
Contact RCA directly to inquire.
RCA Audio... | Answered 13 hours ago
Request the manual from RCA.
RCA Audio... | Answered 14 hours ago
RCA Lyra RD1090 MP3 Player Logo
26 questions posted
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
clearing internal memory
  • Audio Players & Recorders
