20 Most Recent RCA Lyra RD1071 MP3 Player Questions & Answers
hi Arnie, 1. make sure you put the battery in right way first before I can help further.
2. for this player to come on you just push play button(which is a on button,if you push it again meaning you pause) and if you push stop button meaning is stop and if you hold on it for few seconds the player goes off.
RCA Lyra RD1071... • Answered on Jul 27, 2010
You can manually sync this what you need to do is conatct these guys and tehy will take you through the proceedure
tom
http://www.lucidica.com
RCA Lyra RD1071... • Answered on Jun 18, 2010
It maybe that you downloaded poor quality mp3's, which is why they sound poor. Also, check the headphones - try using a different pair and check the difference. Although, it is MOST likely to be that the mp3's downloaded are of LOW QUALITY. The usb cable does not influence the quality of the sound at all. HOPE THIS HELPS!! :)
RCA Lyra RD1071... • Answered on Jul 28, 2009
Maximum memory upgrade is 512Mb.
RCA Lyra RD1071... • Answered on Apr 30, 2009
http://www.retrevo.com/support/RCA-RD1071-MP3-Players-manual/id/288ag307/t/2/
RCA Lyra RD1071... • Answered on Mar 20, 2009
umm i just want to learn how to put stuff onto my sd then on my wii
RCA Lyra RD1071... • Answered on Sep 22, 2008
Yes, a format should solve the problem. Plug the unit in to USB and go to my computer, it should show up as removalbele dics drive f:, right click and select format, a "quick format" should work. L8R Good Luck
RCA Lyra RD1071... • Answered on Sep 20, 2007
Yes they can be made more brighter.
RCA Audio... • Answered on Feb 17, 2021
The subwoofer is much more than just another bass unit and the purpose is to reproduce sub-audible content in order to add ambience to the listening experience and before it can reproduce the sound it must first be part of the recording or performance. Even if a recording is rich in sub-audible content, unless the amplifier is designed to process and filter sub-audible frequencies, the amount of content available at the output is likely to be minimal. A pair of good 3-way loudspeakers will, most of the time produce a purer and more realistic sound with plenty of power and render a subwoofer superfluous. The fact your amp doesn't have an output for a sub means, even if you successfully connect it there is unlikely to be much activity from it. The only sensible way to connect it would be as a ghost speaker as used by many hi-fi enthusiasts since the introduction of stereo. The purpose of a ghost speaker is to fill a gap between the channels and is driven by the difference in emf between the loudspeaker positive of each channel. Unfortunately the difference between the channels isn't great enough to drive a loudspeaker so another amplifier will be needed. As it is a surplus subwoofer you are trying to find a use for you should either obtain the signal from the bass unit of each speaker or use a crossover type filter in the output of the second amp.
RCA Audio... • Answered on Jan 27, 2021
Contact RCA directly to inquire.
RCA Audio... • Answered on Nov 29, 2020
Request the manual from RCA.
https://www.fixya.com/support/t13862396-set_clock_rca_model_rp_5606_b_disc_clock
RCA Audio... • Answered on Nov 21, 2020
RCA Lyra RD1071 MP3 Player Logo
Popular Tags
19 questions posted
Top RCA Audio Players & Recorders Experts
Jean Sintulaire
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
rca lyra memory card
  • Audio Players & Recorders
