20 Most Recent RCA P56950 56" Rear Projection Television Questions & Answers
Sounds like the flyback went out. Your set is a CTC195 you can get a replacement flyback for it at the following link. They also provide free instalation instructions and free on line tech support.
http://servicemanuals.vstore.ca/
RCA P56950 56"... | Answered on Oct 16, 2013
IF YOU USED THE 75 OHM CONNECTION SET TV TO CH 3 IF YOU USE THE RED WHITE AND YELLOW JACKS THEN YOU HAVE TO SELECT THE TV INPUT TO WHERE EVER YOU CONNECT THE JACKS INTO
RCA P56950 56"... | Answered on Aug 14, 2013
may be some thing is stuct on the controt pannel power button or others check. try this it may work
RCA P56950 56"... | Answered on Jun 04, 2012
What is your Chassis# and what year is TV??
RCA P56950 56"... | Answered on Nov 27, 2011
No,only the original tv remote that design for that tv model will work only for that tv without a universal codes.All universal remotes have to have a codes enter to program it to make work for the tv dose not mater same model or simular.All the rest same model of tv or simulair tvs the original remote only 50/50 should work,some fuctions just not there or just don't have it.
RCA P56950 56"... | Answered on Aug 14, 2011
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
RCA P56950 56"... | Answered on May 18, 2011
are you sure it need to be replaced or did you try to clean it first?
RCA P56950 56"... | Answered on Feb 20, 2011
blowing the fuse means that you have a shorted parts on your unit, it is mainly due to a shorted rectifier diode/voltage regulator i.c.,check it and replace the shorted parts will cure the problem also replace the open fusible resistor.
RCA P56950 56"... | Answered on Dec 26, 2010
Use a different input and choose that input on the TV.
RCA P56950 56"... | Answered on Apr 15, 2010
YOU HAVE BAD BUTTONS ON THE FRONT PANEL THEY ARE STICKING OR ARE SHORTED.
RCA P56950 56"... | Answered on Sep 14, 2009
It sounds as if you have a convergence issue. If you go into the menue with the remote control
and highlite the screen selection. this should get you to the convergence selection. if you highlite
the RED selection and use the arrow buttons on the remote, you should be able to move the RED
either vertically or horizonally over top of the green line. Do the same with the BLUE selection.
If they do not move, you probly have a failure with the Convergence power Supply. To my knowlege, that board is no longer available and you would need a professioal Service tech to repair the board.
Hope this helps,
Skyassoc
RCA P56950 56"... | Answered on Jun 16, 2009
Bad FBT flyback transfomer,ck hori output transistor.
RCA P56950 56"... | Answered on Jun 11, 2009
you probably have a little of both. the shutting off is definately heat related but could be too much dust on heatsinks, etc causing it to shutdown. cleaning may eliminate problem but could be a sign of an underlying issue..
the dust can really cause the picture to dim. most of these tvs you can pull the "lightbox" or guts out of the cabinet to clean all 3 lenses, and clean the mirror if needed. don't mess with the screens except cleaning the front from outside. usually a 1/4" driver will be all you need, and a soft cloth for the lenses. use compressed air or a vacuum to clean out dust which will help with cooling, but the picture is only effected by dust on lenses, mirror, and screens.
RCA P56950 56"... | Answered on Feb 18, 2009
Horizontal output transistor is needing replacement for sure and quite possibly the flyback as well
RCA P56950 56"... | Answered on Jan 15, 2009
RCA P56950 56" Rear Projection Television Logo
Popular Tags
37 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
ve got rca ctc195 series tv lamps
  • Televison & Video
