20 Most Recent RCA P52920BL 52" Rear Projection Television Questions & Answers
2answers
Model P52920bl Have sound but
Test the TV with different inputs: over-the-air antenna, DVD player, game box, cable or satellite box, etc. Picture problem with only one input? You've partially solved it: bad source, jack, or cable.
Picture problem on every input? First, unplug the TV and let it set for 15 minutes or so, then plug it back in and try it.
No help?
You most likely have a backlight issue with this TV set. Could be the inverter circuits for the backlights. The inverter is the power supply source for the backlights. there could also be a screen driver problem. This would entail changing the entire board. You should call in an authorized LG repair center to check this set out for you. Good Luck and please let us know what you found out about this TV set.
For complete TV repair kits including parts goto www.TvRepairKits.com
If you have no volume bar or menu showing on the screen, then it cannot be anything you have wired wrong.
to see the picture on an lcd tv, you need to have back lights. the light shines through the lcd panel and you can see the picture. I suspect that you have video on the screen, but you cannot see it because the back lights are not lit. To prove this simply turn the tv on in a very dark room and tune in a channel so you can hear the audio. then with a powerful flashlight, point it into the screen and look around the edge of the flashlight for evidence of video. Be careful not scratch the panel with the flashlight as you place it on it..
Back to your problem, the back lights are tiny florescent bulbs and a ballast to run them, similar to the ones in a shop light. If the lights go bad or the ballast fails them you will get your symptom. Many times if the lights fail then not all of them will fail all at once, so the others will start up and then after a second they will cause the ballast to quit trying. In this case when you first start up the tv, you will see a slight glow on the screen (if the room is really dark). Many times you can see which light isn't working, there will be a darker horizontal stripe. This usually means the panel must be replaced, and unless it's cover with a warranty, you will probably not fix it due to the costs.
If it never glows slightly, then replacing the ballast may fix it. On some set this board is not available separately, but many have now been released. And on newer sets the ballast is part of the power board, and they have issues with a diode shorting so the part is cheap. With out a model number, I'm spit balling.
The last thing that can happen, is there is a slight back glow and no picture is being displayed. This is almost alway the fault of the lcd control board. Like the ballasts, many of these boards are now available without buying the whole panel.
At any rate, you know what to expect, there is nothing you can do, because a technician will need to fix it.
Also Hello,
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Fixing it will not take long..
Hoping this will help in solving the problem....
8/27/2011 2:01:39 AM • RCA P52920BL 52"... • Answered on Aug 27, 2011
RCA 52" rear projection tv
rscimeca,
This could literally be anything. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will help you isolate the problem and tells you where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
5/23/2011 8:26:34 PM • RCA P52920BL 52"... • Answered on May 23, 2011
I see a halo of
Possibility is the geometric correction drive IC / convergence IC, need replacing. Another possibility is the bulb is reaching end of life.
1/15/2011 7:18:26 PM • RCA P52920BL 52"... • Answered on Jan 15, 2011
I have an RCA Home
If I am not wrong, this is a CRT projection tv and does not have any lamps(they exist only in DLPs). SO i guess you are talking about the three CRT tubes. This sounds more like a convergence problem. Did you try adjusting it?
8/31/2010 6:36:45 PM • RCA P52920BL 52"... • Answered on Aug 31, 2010
RCA 52" projection tv convergence problems,can i fix it?
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
3/31/2010 2:20:55 AM • RCA P52920BL 52"... • Answered on Mar 31, 2010
Problem with sony tv kp-15ws150 convarace
Ur convergence it dead.Know how to solders?Tries these websites for convergence kit.Tv repair World.com,Tvrepairkits.
12/12/2009 4:22:41 AM • RCA P52920BL 52"... • Answered on Dec 12, 2009
TV WONT TURN ON
try unplugging and plugging back in but wait 2 minutes in between. this will reset it.
11/14/2009 3:07:14 PM • RCA P52920BL 52"... • Answered on Nov 14, 2009
RCA 52
check the back of set to see if there' an internal external speaker switch- also check on screen audio menu to see if speakers are set to off
10/19/2009 8:09:38 AM • RCA P52920BL 52"... • Answered on Oct 19, 2009
Blurred picture
It sounds like aging electrolytic capacitors have reduced the high voltage on the "guns" in your projection TV. You cannot fix this problem yourself. There are DANGEROUS high voltages inside the set, even after it has been off for WEEKS. We're talking HEART ATTACK voltages. Call a qualified service technician.
10/10/2009 9:17:24 PM • RCA P52920BL 52"... • Answered on Oct 10, 2009
Repairman said i need a new transformer......are
Part# 239111 Call ACME 1-800-575-9833 have 1yr warrant on FBT cost 22.95 plus shipping.
9/19/2009 11:59:34 PM • RCA P52920BL 52"... • Answered on Sep 19, 2009
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
7/21/2009 4:29:22 PM • RCA P52920BL 52"... • Answered on Jul 21, 2009
My RCA projection TV is showing double vision
You can get the STK730-130 convergence IC at the following link which should take care of that issue. Its 24.00
http://servicemanuals.vstore.ca/product_info.php/pName/stk730130/cName/convergence-ics
7/13/2009 1:46:19 AM • RCA P52920BL 52"... • Answered on Jul 13, 2009
Problem with picture
Call in the tech your tv needs to be repaired you are having problem the tv video ciruit.if it does not have sound it wiil be in the IF circuit.good luck.
4/27/2009 6:05:58 PM • RCA P52920BL 52"... • Answered on Apr 27, 2009
What is Convergence IC's?
Tube-type projection TVs have separate picture tubes (CRT) for red, green and blue. Convergence is the process of getting the images from the three CRTs to line up properly so you see the correct colors on the screen. The convergence output integrated circuits (ICs) are the electronic devices which make this happen.
3/28/2009 6:24:24 AM • RCA P52920BL 52"... • Answered on Mar 28, 2009
RCA P52920BL (1999)
The fuse fails when the convergence power supply fails,putting a new fuse in the set will let the unit come back on but convergence is not working,check in screens in the menu to see if you have adj. projection t.v.,if the is not in the menu,replace reg ic part number 215530 on the convergence power supply,this board is above the right module mounted on the black plastic.,hope this helps
3/28/2009 5:42:22 AM • RCA P52920BL 52"... • Answered on Mar 28, 2009
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
3/22/2009 11:38:10 PM • RCA P52920BL 52"... • Answered on Mar 22, 2009
MY RCA 52 IN TV WONT TURN ON?
MOST LIKELY, THE PROBLEM
IS THE BULB USED IN THE SET?
BY THAT I MEAN THE HIGH INTENSITY REAR PROJECTOR BULB?
DO A SEARCH ONLINE AND THERE ARE COMPANIES SELLING THE BULBS AT A PREMIUM. YOU MAY WANT TO CONSIDER DUMPING IT.........
3/14/2009 10:52:11 PM • RCA P52920BL 52"... • Answered on Mar 14, 2009
Tv will not stay on
there is nothing you can do but get rid of it
12/26/2008 7:50:28 PM • RCA P52920BL 52"... • Answered on Dec 26, 2008
Problem with RCA 52 inch
The flyback has burned a hole in the side,it needs replacing
10/27/2008 9:57:05 PM • RCA P52920BL 52"... • Answered on Oct 27, 2008
No Power to Model # P52920BL
Sounds like the flyback transformer and horz output,the output shorts and the set will just tick when its pluged in to the ac
6/4/2008 12:10:24 AM • RCA P52920BL 52"... • Answered on Jun 04, 2008
Televison & Video Logo
27 questions posted
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
blurred picture
  • Televison & Video
