20 Most Recent RCA P52771AT 52" Rear Projection Television Questions & Answers
My tv turned on, cant
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem.......
6/12/2011 6:28:06 PM • RCA P52771AT 52"... • Answered on Jun 12, 2011
No picture loud ticking noise like a alarm clock
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this help in solving the problem....
6/12/2011 5:57:40 PM • RCA P52771AT 52"... • Answered on Jun 12, 2011
Spider webs inside screen.
randjmathis,
I have a tip at http://www.fixya.com/support/r4690955-clean_lense_screen_in_projection_tv which will help you accomplish your goal.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
2/16/2011 9:45:58 PM • RCA P52771AT 52"... • Answered on Feb 16, 2011
Picture problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
6/6/2010 5:33:38 AM • RCA P52771AT 52"... • Answered on Jun 06, 2010
TV has no power
try disconnecting the red wire from the hv distribution block right behund the front speaker grill then take off the wood cover it looks like a distributor cap with a bunch of large red wires connected to it the wires run to the picture tubes, and one goes to the flyback tranformer on the pc board.the high voltage is black or grey in color
Techman
5/16/2010 4:55:59 PM • RCA P52771AT 52"... • Answered on May 16, 2010
Are the projection tubes between a RCA P52771at
NO they sure will not.
12/12/2009 2:00:08 PM • RCA P52771AT 52"... • Answered on Dec 12, 2009
RCA P52754AT POPPING SOUNDS. COLOR FLICKERS AND
It sounds like your high voltage block is arcing and causing the TV to go into protection shutdown temporarily. If that's the case, you'll most likely need to replace that HVB.
The other thing it could be if you're hearing "popping" (snapping ?), is that one of the CRTs could be arcing to ground, maybe the green one since you're getting too much green.
Good luck.
11/28/2009 10:23:07 PM • RCA P52771AT 52"... • Answered on Nov 28, 2009
ON OFF SWITCH
ur power ic inverter board is dead.
U need a new one.
8/19/2009 2:33:05 AM • RCA P52771AT 52"... • Answered on Aug 19, 2009
Rca rear projection screen way to much blue
replace convergence ics .press the menu and go into the convergence
alignment.see if you are able to align the blue convergence. if not replace the convergence ics.
8/4/2009 8:44:43 AM • RCA P52771AT 52"... • Answered on Aug 04, 2009
To much blue in screen and lighter colors are bright
Caution: you need the "O' ring kits for all 3 guns. If you can take the front off you can look into the lens and possibly see white stuff. If it's clear, it's not the fluid. If you see floaters, than the fluid is contaminated, usually from the factory or a prior repair? The Gasket kits come with instructions, most of the time. The repair manual is close to $100.00 so If your gonna dig in be ready for anything, especially if you've never done it before. PS: The 450 is a good price...
3/30/2009 10:29:31 PM • RCA P52771AT 52"... • Answered on Mar 30, 2009
Model; P52750WK serial; 340486076
Hit remote power button. Brief " crackling " sound, no picture. No problem with TV since new. There is a brief spark like light with sound.
12/31/2008 11:39:20 PM • RCA P52771AT 52"... • Answered on Dec 31, 2008
Power not working
the tv needs to be repaired take it to a tech the power supply is the culprit along with the related circuit.your tv must be repaired by a proffessionl tech good luck.
10/27/2008 7:47:31 PM • RCA P52771AT 52"... • Answered on Oct 27, 2008
Rca p52771at - dark picture
Sounds like a bad screen asy,part number 204809,must use the generic,or you could have weak tubes,if so you may just need to turn up the screen drives,this part is located in the right top of the set with the back removed,if no cracks are present adj. the three marked screen's,turn the color all the way down in your menu and adj. for a black and white picture.
5/9/2008 4:17:13 AM • RCA P52771AT 52"... • Answered on May 09, 2008
Blue Halo and too much blue...
if its a halo such as a glo you need coolant change in the CRT, if its like a 3D effect then you need new Convergence ICs. Can you post a picyure of your screen and I will properly diagnose it for you then be better equiped to help you properly.
4/5/2008 5:01:16 PM • RCA P52771AT 52"... • Answered on Apr 05, 2008
2answers
No sound
Get an external sound system! :-D
Although I highly recommend you get an external system, you will also want a backup system. Sounds like an electrical problem to me. There would be like fifty things to check, electronically. If you are good with electronics, like you actually have a multimeter and soldering iron laying around and know how to use them, it might behoove you to buy or download the service manual for your set.
Or call a pro to fix it, for the cost of which you could buy a cheap home-theater-in-a-box sound system. I recommend Yamaha.
3/24/2008 1:01:15 AM • RCA P52771AT 52"... • Answered on Mar 24, 2008
Just red will not work
The screen asy is bad,part number 204809,must use the generic for this part.
3/4/2008 2:23:19 AM • RCA P52771AT 52"... • Answered on Mar 04, 2008
Wire diagram for splitter
On the 205064 hv splitter with the splitter mounted in the set,left to right, hv transformer,red tube,green tube,blue tube,plug on right side goes to screen asy,the black wires plug on the left side of splitter,which are grounds.
3/4/2008 2:07:28 AM • RCA P52771AT 52"... • Answered on Mar 04, 2008
Rca p52771at
Sounds like you have a bad screen asy,check around the pots to see if cracks are present,part number for this item is 204809,must use the generic,the part is no longer available from Thomson.
3/4/2008 2:00:39 AM • RCA P52771AT 52"... • Answered on Mar 04, 2008
Red and green do not light up
Start by raising the screen control for the red and green to see if they have any type of luminance.
C-Dog
2/10/2008 9:27:55 PM • RCA P52771AT 52"... • Answered on Feb 10, 2008
RED LINES
Your red CRT socket may be loose or have cracked solder if not, try turning down the red gun screen control inside the set just a little. Youre experienceing what is known as retrace lines
1/22/2008 2:41:48 PM • RCA P52771AT 52"... • Answered on Jan 22, 2008
Televison & Video Logo
30 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
picture problem
  • Televison & Video
