20 Most Recent RCA F27636BC 27" TV Questions & Answers
3answers
I can't select TV/Video input on the menu
If you have the original remote (RCA Universal with red and blue buttons), you can switch from the TV tuner to the audio/video input with the INPUT button. It is to the left of zero on the numeric keypad, above the red CLEAR button. Press it again to get back to the TV tuner.
8/9/2016 2:18:48 PM • RCA F27636BC 27"... • Answered on Aug 09, 2016
Picture is to large for 27in
If model indicated here is correct either a problem in the Vertical circuit of the set or an adjustment.Almost any shop can take the set into the service menu and adjust vertical size a bit to correct if not circuit problem.
11/3/2012 5:51:01 PM • RCA F27636BC 27"... • Answered on Nov 03, 2012
0answers
I have an RCA F27636BC made in Oct. of 96 and I
There are a few possible reasons, the first being that the tube has burned out inside the TV. But before jumping to that conclusion I would check to make sure that your A/V cables are connected properly (video being the yellow cable, or if you may be using S-video which is a black cable that has 4 steel pins and 1 horizontal black plastic or metal one) and make sure that you have the cables plugged into the same numbered input: ie. Audio is in audio 1 and video is in video 1 rather than audio being in audio 1 and video being in video 2.
Also be sure that you've selected the right input from the remote or from the television itself.
12/8/2009 10:57:29 PM • RCA F27636BC 27"... • Answered on Dec 08, 2009
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
11/24/2009 3:16:01 PM • RCA F27636BC 27"... • Answered on Nov 24, 2009
Autoprogramming
On many televisions with built-in tuners, you have to tell the tuner whether it will be connected to cable or antenna, since the RF spectrum is different for these.  Make sure you have cable selected (assuming you are connecting to the cable service) and then try the autoprogramming again.
1/24/2009 7:40:14 PM • RCA F27636BC 27"... • Answered on Jan 24, 2009
Picture height adjustment
The screen parameters were factory set by firmware programing during production.
If over time the picture became out of spec, this is due to some components that have changed in characteristics with use and age.
The fix is to have the set properly serviced. The tech will have to troubleshoot the set to find the defective parts and change them.
Jerry G.
7/16/2008 2:17:20 PM • RCA F27636BC 27"... • Answered on Jul 16, 2008
2answers
Not receiving channels below 51
removed cable at the back of your TV insert any pin metal material like paperlip without the plastic cover and search local channels from 1-13,, if it does,, contact your cable provider.. it may had cable line problems.
2/29/2008 4:44:58 PM • RCA F27636BC 27"... • Answered on Feb 29, 2008
I have a RCA TV model # LED 22B45RQD and I can't find the code for it
One possible solution to find the remote control code for your RCA TV model LED 22B45RQD is to look up the user manual for your specific TV model. The manual should contain information about the compatible remote controls and their programming codes. If you don't have access to the physical manual, you can often find electronic versions of manuals online through websites such as Manualslib.com or the manufacturer's website. Once you locate the manual for your TV model, refer to the section on remote control programming and look for the programming codes listed under the RCA brand. Alternatively, some universal remotes allow you to automatically scan and detect the correct code for your device. To do this, follow the instructions for your specific universal remote control and select the option to program the remote using auto scan mode. Point the remote at the TV and press the appropriate buttons (usually power and input select) until the TV turns off and back on again. This process may take several attempts before finding the correct code. It's also worth noting that the color of the OK/SELECT button on the remote control could affect which code works with your TV. As mentioned in the search result excerpt, if the OK/SELECT button is red, then you might try the codes previously suggested by another user. However, if those codes don't work, it's best to continue searching for the correct code based on your specific TV model number.
4/30/2024 7:50:23 AM • RCA Televison &... • Answered on Apr 30, 2024
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
2answers
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them. Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
2/2/2024 11:35:38 PM • RCA Televison &... • Answered on Feb 02, 2024
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse . TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
1/21/2024 8:13:40 PM • RCA Televison &... • Answered on Jan 21, 2024
What is the code for remote control for RCA model# RT 1971-AC
Better idea https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com https://www.amazon.com > Replacement-DETG160R-... Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control. US$32.99 · ‎In stock
RCA RT1971AC Replacement Remote
Remotes.net https://www.remotes.net > products > replacement-rem... If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems. US$34.90 RCA Universal Remote Codes:
  • The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
  • The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
  • The cable box codes are: 000 and 027.
Apr 26, 2023
RCA Universal Remote Codes List 4 Digit - GenTwenty
12/27/2023 12:47:10 AM • RCA Televison &... • Answered on Dec 27, 2023
Rca remote r26211 code for trutech tv dvd
Better to get a Facsimile Remote, a copy made for the unit. It is unlikely, you can input codes to work both applications in a combined set.
TruTech TV universal remote control codes (3, 4 and 5 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > trutec... Universal remote codes for TruTech TV sets - 3 digit, 4 digit and 5 digit codes.
My mom has a Trutech combination TV/DVD, about 20 ...
JustAnswer http://www.justanswer.com > TV Problems Feb 6, 2013 - There are very few universal remotes that will operate a tv/dvd combo and of ten if you find a code then the tv a dvd have separate codes. 1 answer · Top answer: Jack : Hi and welcome to justanswer. To answer your question; There are Make sure you use the FULL Model Number for it.
TRUTECH TV Replacement Remote
Remotes.com https://www.remotes.com > trutech-remote-controls-s Replace new & discontinued remote controls for TRUTECH devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Trutech Remote for sale
eBay https://www.ebay.com > ... > Remote Controls Sort ; 2PCS Remote Control For TruTech KLV3170 LCD Drop Down TV Built-in DVD Player · $13.83 ; TruTech A60P0315 Remote Control Genuine OEM TESTED · $3.00 ; Original ...
Trutech Remote Control
Amazon https://www.amazon.com > trutech-remote-control > k... GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, TCL, Panasonic, Smart TVs, Streaming Players, Blu-ray, DVD, 4-Device, ...
12/20/2023 1:17:20 AM • RCA Televison &... • Answered on Dec 20, 2023
Televison & Video Logo
14 questions posted
Top RCA Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
picture large 27in
  • Televison & Video
