20 Most Recent RCA F25442 25" TV Questions & Answers
TV TURNS ON BY ITSELF IN MIDDLE OF THE NIGHT HELP
If you have eliminated the obvious things the tv must have a fault... The obvious things - a night prowler with a remote, a cat walking across your remote, a ghost that likes to watch tv, somebody sleepwalking... It is possible the infra red signal needed to switch on the tv is not coming from your remote. You can test this by removing the batteries or taking the remote to bed with you. If the tv still turns on then tape over the infra red receiver on the tv to eliminate the chance of some stray infra red beam from elsewhere being the culprit. If that stops the tv turning on you need heavier curtains or blinds or the tv moving perhaps, but if the tv still switches on it has a fault. There is another thought. Digital TVs and digiboxes are often programmed to wake up periodically to check for software updates. Mine wakes up at 3am but it only checks for software updates and doesn't switch on the tv, but maybe this is what your tv is doing. A further thought - a tv often has the functions of an alarm clock. They have a sleep function so they can switch themselves to standby after you have fallen asleep and then can wake you in the morning. Perhaps the alarm has been inadvertantly set for 2am? These days it is rather anti-social to leave any appliance on standby. Rather than unplugging the set every night and worrying about the kids, why not arrange for the tv to be plugged in to a switched outlet so the kids can switch it on or alternatively use a cheap plug-in timeswitch to prevent the set switching on in the wee small hours...
4/16/2017 11:22:08 AM • RCA F25442 25"... • Answered on Apr 16, 2017
TV Comes on by itself at 5 AM
Dou !! Try looking at the menu and see if the "On Timer is set.
3/18/2016 7:18:25 PM • RCA F25442 25"... • Answered on Mar 18, 2016
Is the RCA F25442 model TV a ATSC TV?
Check this site to download the user manual to your TV. It have all details.
3/27/2013 5:04:01 PM • RCA F25442 25"... • Answered on Mar 27, 2013
On screen writing over past the left side
Ok, so I'm seeing RCA TV, but you're talking about writing, so I'm wondering if you're using this TV as a monitor? If that's the case, it could be dependent on the the video card settings.If not, the input device. You could possibly have your view mode set to stretch or something like that. Maybe look in the settings on the monitor and see if it'll let you do a factory reset.
9/2/2012 10:18:34 PM • RCA F25442 25"... • Answered on Sep 02, 2012
Tv is stuck on channel
Try turning the TV off and turning it back on. If that doesn't work try going into the menu and performing a program of the TV. Most TV's will have an option to program the channels. It sounds like your TV has only one channel programmed.
2/28/2011 11:26:32 PM • RCA F25442 25"... • Answered on Feb 28, 2011
Just got this tv from
The horizontal line indicates the vertical deflection circuit is not working. Either the set is stuck in service mode for adjusting color (turns off vertical), or the deflection circuit has failed.
Some RCA TV sets have a "Service" switch in the back, down near the bottom of the set. Most of the newer sets use a combination of remote control and front panel buttons to get into service mode, and that can be turned off by unplugging the set and plugging it back in. Try looking for the mechanically operated service switch in the back first.
1/5/2011 3:52:21 AM • RCA F25442 25"... • Answered on Jan 05, 2011
I have a RCA F25442 TV. Cable company feeding my
yes,100%
12/5/2010 6:55:55 AM • RCA F25442 25"... • Answered on Dec 05, 2010
I need a list of codes to program a rca tv to dish
you need dish network remote control manual for codes.
12/5/2010 6:49:37 AM • RCA F25442 25"... • Answered on Dec 05, 2010
Tv went black and now it just hums or buzzes had
The HOZ output tran is short . it cost
about 3.00-5.00 from a parts store
so if you have a shop repair it dont
let them carge you more than 60.00
for the repair.
6/28/2009 7:05:26 PM • RCA F25442 25"... • Answered on Jun 28, 2009
2answers
Can't find button on tv to change source in order to play dvd
I'm assuming that you do not have access to the remote for the TV. If you do, you can simply press "INPUT" on the remote.
If you have no remote, try this:
Press the "MENU" button on the TV.
Press "CH Down" until "Channel" is highlighted, and "MENU" to select it.
Press "CH Down" to highlight "List and Labels", and "MENU" to select it.
Press "CH Down" to go below channel 1, you should see "FRNT" displayed.
Press "MENU" to get out of the Menu system.
You should now be seeing whatever is plugged into your front connectors.
Simply pressing one of the channel buttons will switch back to normal TV mode. I could find no faster way to access the front connectors without using the remote.
3/18/2009 10:04:47 PM • RCA F25442 25"... • Answered on Mar 18, 2009
2answers
KEEPS POPING UP GUIDE PLUS MENU
try to change all the micro switch button on the pcb board
12/11/2008 8:16:14 AM • RCA F25442 25"... • Answered on Dec 11, 2008
Seeing red !
I had a television that went to a bright shade of blue.A friends neighbor worked for sony television plant where the new tubes came down the assembly line.His job was to make sure tubes were working fine,if one color was dominant then his job was to smack the front center of the tube with a rubber mallot to fix the problem.He suggested i try that with my tube while the set was on.It worked and solved my blue problem.Apparently he explained,the gun connections in the tube came loose and to fix it was to smack it this caused the connection to reweld itself.For you I would use the palm of an open hand and smack the tube dead center with a good hard smack.Dont be afraid of breaking the glass because its very thick and strong.Give this a try.Hope it helps.Good luck!
11/19/2008 1:25:00 AM • RCA F25442 25"... • Answered on Nov 19, 2008
Squealing set
It looks like an output transistor problem. You can't fix it by yourself; you will need to call a service. It will cost you at least 100$, so consider buying a new one good luck
11/15/2005 12:08:30 PM • RCA F25442 25"... • Answered on Nov 15, 2005
Model LED32B30RQ need 4 digit code to program universal remote. RCA TV
The 4-digit code to program a universal remote to work with a RCA LED32B30RQ TV model is likely to be one of the following: 11447 11758 11442 To program the universal remote to work with the RCA LED32B30RQ TV:
  1. Turn on the TV
  2. Press and hold the "Setup" button on the universal remote until the "TV" button blinks twice.
  3. Press the "TV" button on the remote.
  4. Enter the 4-digit code for your TV using the number buttons on the remote.
  5. Press the "Power" button on the remote. The TV should turn off.
  6. Press the "Setup" button again to lock in the code.
If the TV does not turn off after entering the code, please try the other codes listed above. If none of the codes work, you may need to refer to the universal remote manual or contact the manufacturer for further assistance. Note: The method to program the universal remote may vary depending on the remote brand and model
1/22/2023 3:14:02 PM • RCA Televison &... • Answered on Jan 22, 2023
55' polaroid tv & rca universal remote I can put code in for the menu to show up & it won't let me program reset or scan for channels or change cable to antenna nothing what am I doing wrong
It sounds like you may be having trouble programming your RCA universal remote to work with your 55" Polaroid TV. There are a few things you can try to troubleshoot the issue:
  1. Make sure you are using the correct code for your TV. RCA universal remotes come with a list of codes for different brands of TVs, so you will need to refer to the instructions for your remote to find the correct code for your TV.
  2. Try manually inputting the code. Some universal remotes require you to manually enter the code for the device you are trying to control, rather than using the automatic search function. Refer to your remote's instructions for more information on manual code entry.
  3. Check the batteries in your remote. Weak or dead batteries can cause issues with remote functionality.
  4. Check if the remote is in the correct mode for the device you are trying to control. Some universal remotes have multiple modes for controlling different types of devices, such as TV mode, DVD mode, etc.
  5. Check if you have the right remote for your TV, if not, try to find the right remote.
If none of these troubleshooting steps work, you may need to contact the manufacturer of your TV or the manufacturer of your universal remote for further assistance. My recommendation https://amzn.to/3WfBNpJ https://amzn.to/3INRZeH
1/16/2023 5:19:48 AM • RCA Televison &... • Answered on Jan 16, 2023
Rca tv pld50a45rq tv screen has a shadow on the left side
If your RCA PLD50A45RQ television has a shadow on the left side of the screen, it may be caused by a problem with the internal hardware of the TV. Here are a few things you can try to fix the issue:
  1. Check the cable connections on the back of the TV to ensure that all cables are securely plugged in. This could be the problem if the cables are loose or not properly connected.
  2. Check the settings on the TV to make sure that the picture is not being stretched or distorted in any way. This can cause a shadow on one side of the screen.
  3. Check the TV for any physical damage to the screen. If the screen is cracked or damaged, it can cause a shadow on one side of the screen.
  4. Check the backlight of the screen, if it is not working properly, it can cause a shadow on one side of the screen.
  5. If you have tried the above steps and the problem persists, it may be best to contact RCA customer service or a technician for further assistance.
  6. It is also possible that the problem is with the T-con board or the LCD panel, in this case, it is best to consult a technician to check the TV and possibly replace the damaged component.
It's important to note that if the shadow is persistent and appears even when the TV is turned off, it could be a hardware issue that requires service or repair.
1/16/2023 12:58:18 AM • RCA Televison &... • Answered on Jan 16, 2023
I have a rca HDMI tv, I can’t get channel 526 or 54 they go pixels,freeze.
If you are unable to receive channel 526 or 54 on your RCA HDMI TV and the picture goes pixels or freezes, it may be caused by a few different issues:
  1. Check the cable connections on the back of the TV and the cable box or streaming device to ensure that all cables are securely plugged in and the devices are properly connected.
  2. Check the settings on your TV and cable box or streaming device to make sure that they are set to the correct channel and that the channel is not blocked or set to a different input.
  3. Check the signal strength of the cable or streaming service, if the signal strength is low or poor, it can cause picture issues like pixels or freezing.
  4. Check for any physical damage to the cables, if the cables are damaged, it can cause picture issues.
  5. Try to scan for channels on the TV and cable box or streaming device to ensure that all channels are being picked up properly.
  6. If the problem persists, contact your cable or streaming provider for further assistance, as the issue may be on their end.
  7. If the problem is not resolved, you may want to contact RCA customer service for further assistance.
It's important to note that in some cases, the channels you're trying to watch may be experiencing technical difficulties, or the channel is not available in your area.
1/14/2023 10:44:08 PM • RCA Televison &... • Answered on Jan 14, 2023
RCA F25442 25" TV Logo
Popular Tags
24 questions posted
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
tv went black now just hums or buzzes
  • Televison & Video
