20 Most Recent Northgate WALINN140A Notebook Questions & Answers
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, Driver downloads and Installation Instructions as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
There are no XP drivers to be found with Microsoft as XP is no longer supported.
Some manufacturers may have a limited number of Drivers still listed.
I hope this helps.
Northgate... | Answered on Feb 02, 2011
go to the device manager (right click my computer - properties - hardware tab - device manager button)
look under sound devices, if there are any yellow question marks you need the approprate sound driver device driver, go to the manafacturers website for it, or find the original utility disks that came with the laptop to re-install the driver
if it has its drivers, check the sound devices in sound options (control panel - sounds and audio devoces) and make sure the playback device is set to the default and hasent been changed to something that is no longer connected to the laptop.
Northgate... | Answered on Sep 02, 2010
Sometimes I have problems with this on my laptop. Simply opening and closing the screen fully once or twice works for me. If this doesn't work I had a laptop where I had to completely take it apart and something was pinching the display connector and keeping it from working.
Northgate... | Answered on Jun 04, 2010
check the nortgate laptop manufacturer site; or check this site
driverguide.com
Northgate... | Answered on Jul 07, 2008
Try changing the CMOS battery, and see if the problems go away.
Northgate... | Answered on Aug 07, 2014
You should have mentioned your Operating System, but I would email or call Newegg, and ask them. http://help.newegg.com/app/home/site/US#ContactUsTab
Northgate... | Answered on Jul 30, 2014
Please don't turn it back on. Unplug your computer from the wall and examine the wall socket for blackened or burned sections. It is likely that dust has caused a short in your computer. Sadly, most times this means that you are going to need a new computer or at the very least, some new parts. Take it to a reputable computer repair shop near you and have them test the power supply and other components to see what is salvageable of your computer. With any luck, your hard drive contents MAY have survived but there is no guarantee.
Northgate... | Answered on Mar 27, 2014
"40drhol"? If you are re-installing the OS, when you re-install it will ask if you want to format. If the HDD is not the Primary HDD in your computer. a spare HDD, If the HDD is compatible with your computer interface you can install as a slave/second/primary, depending on the interface/pin outs, or load a different OS on it if you wish and have a Dual-Boot. If it's a second drive in your computer, Open Start Menu, Computer, Select the HDD, just right click and format ,select File System.
Northgate... | Answered on Feb 15, 2013
You need to install the driver of your printer that works with the operating system of your northgate computer. The driver is in the CD/DVD that came with your printer.
After installing everything, you can add RadarSync to your computer to optimize your computer's driver (eg. keeping them updated to avoid from some problems, and running automatic updates so that you can avoid from the headaches of doing the updates manually).
I hope this helps.
If you need more info, please let me know.
Carlo
Northgate... | Answered on Jan 23, 2013
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
You may have to use the XP drivers . there may not be drivers developed yet for the Windows 7.
The manufacturer is the one who supplies compatible drivers to run with the operating system.
Northgate... | Answered on Jun 21, 2011
Go to the control panel and find the system folder then find the device manager then find your sound card and you can load the driver from there. Also make sure your sound is not muted.
Northgate... | Answered on Apr 20, 2011
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your ((motherboard to your hard drive)) or just replace them there probably old and faulty
hope this helps
Northgate... | Answered on Mar 27, 2011
Download pc login and burn under nerro burning option ,and restart pc pres F2/F10/Dell boot from cd Insert bootable pc login and it automtically reset your password ,
http://www.windowsreinstall.com/articles/bios/
http://sourceforge.net/projects/pcloginnow/
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Northgate... | Answered on Mar 11, 2011
Does this problem came all of a sudden? Do you hear sounds before? Check the icon with the speaker (or something like this) at the lower right end of the taskbar. Is it marked as forbidden? Click on it and enable sounds.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Northgate... | Answered on Sep 09, 2010
Northgate WALINN140A Notebook Logo
5 questions posted
Top Northgate Computers & Internet Experts
Ekse
Carlo Barzo
Carlo Barzo
Tom Chichester
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Northgate Computers & Internet
Most Popular Question
download driver northgate laptop model
  • Computers & Internet
