20 Most Recent RCA F27645 27" TV Questions & Answers
If I'm Correct There Is Only One Set Of Inputs On That Model TV. What Inputs R U Reffering To?
RCA F27645 27"... • Answered on Dec 14, 2010
The input on the tuner needs to be replaced. It will have to be unsoldered from the outside of the tuner and there is a lead inside of the tuner that has to be unsoldered to get the old one off. You will then have to solder the new one back into those places. The input is only a buck or two. An old trick that some people do, is get a small piece of aluminum foil and stick it into the hole, and then reconnect the cable. Just make sure the foil is all the way in, and not touching the metal on the outside of the input. That will help a lot of times.
RCA F27645 27"... • Answered on Jul 29, 2010
yes there must be a button for restoring factory settings
consider ur tv manual for knowing how to reset it.
RCA F27645 27"... • Answered on Mar 31, 2010
Yes, To change the input to video jacks, you must change the channel to 00.
RCA F27645 27"... • Answered on Dec 26, 2009
You cant unless you have been trained to trouble shoot solid state electronics as this set has no user serviceable parts inside and is best left to the pro tech to service. good Luck
RCA F27645 27"... • Answered on Dec 21, 2008
typical problem with an older set. sounds like the crts starting to fade as manufactureres Im thinking build into a set faults that they know will happen after a certain time frame and most do this is why there are so many reoccouring falures in a tv sets life. this is simply my thoughts on this subject!! You could have your local tv guy shoot the tube (not with a gun!!) with a crt rejuvenator to maybe clean off the grids of the tube. sometimes this will help BUT its a risk also Sometimes it will ruin the picture tube also. I have a set that I rejuvenated the tube 4 years ago as it looked like crap but to this date s its stil looking good as it did when new!
RCA F27645 27"... • Answered on Dec 14, 2008
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
RCA F27645 27"... • Answered on Aug 03, 2008
check high voltage rating capacitor hoirzontal output or around the the flyback transformer. if you need my [email protected]
RCA F27645 27"... • Answered on Jul 07, 2008
No you didnt answer the most important questions> When the tv"blinks" does the sound go on and off with the picture? Or does the picture go out to a black screen or a grey screen? or does the whole set seem like its shutting off and on again? or does ir seem like the tvs trying to tune in a channel but keeps going past the right frquency? Answer these questions and we can get somewhere.
RCA F27645 27"... • Answered on Jun 25, 2006
Are you saying the input for the rf dosent work?? Have you tryed the video input?? Do you get any picture on the tv at all, i.e. a blank screen, lines white screen, ect, ect. Cable jack dosent work???? Ok I think I know what you mean, but PLEASE in the future dont make me quess ?? Give as much info as possible if you want help?? Pleasse?? It sounds like the typicale RCA tuner problem as RCA's have been having this problem since they went over to canada ( and no insult to the kanooks LOL) No really since RCA was bought by Thompson corp they have been having problems with their on board tuners and the tuner sheilds. Almost every set sold in the past have had this problem and to this date. Im not sure who they paid off not to have a class action law suit against them?? Its a commonm problem that will cost you abot 75 to 150.00 Bucks to have fixed once and for all. .BUT IF YOUR NOT A TECH!!!!! do not attemt this repair as it will kick you in the butt as these sets as well as all tvs hold a very high voltage charge that will kill ya if you dont know where or what your doing!! Good Luck
RCA F27645 27"... • Answered on Jun 11, 2006
Unplug the tv set for 30 seconds, plug back in and turn set on. if this does not return your audio you need and you're NOT still under warrantee you should at least open the TV and check the board where the components are mounted and resoled any that look bad. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint. All can be replaced at a local electronic or hardware store and they're easy to replace good luck
RCA F27645 27"... • Answered on Jan 06, 2006
we could never figure it out but perhaps your local repair service can
RCA Televison &... • Answered on Apr 30, 2021
Programming procedure https://voxxintl.zendesk.com/hc/en-us/articles/225309147-Programming-the-RCA-RCU4GLW-Niteglo-Remote-Control Zenith Remote Codes Zenith Universal Remote Codes Zenith Universal Remotes Codes for all devices: 101, 142, 149, 177, 201, 224, 225, 229, 237, 153, 154, 172, 401, 460, 461, 498, 501, 502, 521 In reality, the days of Universal Remotes are over. People buy remotes SPECIFICALLY for the set you have from places like this. A direct copy aka, a facsimile copy. https://www.replacementremotes.com/zenith/sb1327w-tv ..
RCA Televison &... • Answered on Apr 29, 2021
RCA universal remote control have to setup code to Vizio. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check these sites too. http://remotesearch.blogspot.com/ https://elektrotricks.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; as well as online shops
RCA Televison &... • Answered on Feb 28, 2021
RCA remote control have no set-up code to Funai. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check these sites too. http://remotesearch.blogspot.com/https://elektrotricks.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; as well as online shops.
RCA Televison &... • Answered on Feb 26, 2021
RCA F27645 27" TV Logo
16 questions posted
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
rca colortrak 27 non flat connection
  • Televison & Video
