20 Most Recent RCA F25645 25" TV Questions & Answers
Manufacturer phone number forgotten... tech help line forgotten...
RCA F25645 25"... | Answered on Jul 31, 2013
This is commonly known as a vertical deflection problem. It cannot be fixed with an adjustment, but requires changing some electronic components. Namely the vertical output IC (integrated circuit) and in addition usually in this model a resistor which may appear to be burned.
RCA F25645 25"... | Answered on Jun 16, 2011
Hi nrlehman,
Based on your description of the symptoms, this is not a quick fix but need to attend by an experienced technician because a lot of parts are going to be considered to isolate the fault. First, the tuner may one of the caused of the symptoms why the channel didn't come on but a snowy picture only. This is one of the expensive parts on your set. Second is the AV switching IC may gone bad also because all inputs are affected. Another is the Jungle IC is going to check also for malfunction(one of the expensive parts also). Sound circuitry is also going to be checked since it is not normal in all inputs.
This is fixable but you must prepare $200-$300 for service fee alone plus parts. I would advice you to ask for an estimate first if you are going to send it in to have an idea whether to buy a new high end unit like a LCD TV, LED TV, DLP TV...
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
RCA F25645 25"... | Answered on May 11, 2011
Hello
There is no RGB connector input at the rear of your RCA tv. There is Video, Audio-L, Audio-R and S-video inputs. You won't get any response from your TV, if you connect the RGB connector to the above said audio video connections. You can connect the Blu-ray player with S-Video connector. After connecting it with specific S-Video cable to your TVs S-Video input and Blu-ray players' S-video output, assaign the input of your TV to S-Video, by going to its Menu, and sufing through it. OK.
RCA F25645 25"... | Answered on Jan 02, 2011
The output from the blu-ray is probably component video, where the brightness, blue and red difference signals are the three outputs. Sounds like the TV only has composite video input so won't work. Check the manuals, if you can get a composite signal from the blu-ray then your TV will display it but not high definition. A HD LCD or plasma TV is needed to show the blu-ray films in high definition.
I was able to get the manual and by following the instructions on the set up was able to get the set back to normal.
RCA F25645 25"... | Answered on May 18, 2009
I don't know the menu system on your model, but you have to check that the tuner is in the proper mode. Also, some of the new TV set models cannot receive a standard analog TV signal from its tuner.
As for the distance from the transmitter sight, this depends mostly on the antenna quality, antenna location, the power output of the transmitter sight, compatiblity of the TV to the received signal, and also the capability of the TV's tuner.
Modern TV sets are really designed to be used with a satellite or cable TV box with their respective service.
Terrestrial TV is dying out, and in a matter of a number of years, it will be gone.
Jerry G.
RCA F25645 25"... | Answered on Apr 23, 2009
I would suggest buying a new power supply from ebay or other places.
RCA F25645 25"... | Answered on Dec 31, 2008
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
RCA F25645 25"... | Answered on Nov 08, 2008
This is a common problem and a local repair place shouldnt charge more then 90 to 125 bucks to repair. Its the tuner and tuner sheilds that need to be resoldered. Theres even an RCA service bulletin about this repair. At one time RCA was giving out rebate coupons if you had this repair done for future purchaces of RCA products but Im not sure if they still do this . Good Luck
RCA F25645 25"... | Answered on May 07, 2006
Your problem is the old rca tuner sheild repair thingy. Its a simple but tricky repair where the tuner grounds around the tuner sheild and under the bottom of the tuner sheild has to be resoldered. Most repair shops in the states that i know of charge like 65 to 125 .00 to do this simple repair. Now if you know how to solder you can get this reapir mod from sams photo facts and do it your self but its really an involved thing if you dont know what your doing as some of the serface mounted parts look like a spec of dirt and i've seen a few peeps clean off those specs and ruin the whole set. Best for you to take this set in for a repair. Good luck
RCA F25645 25"... | Answered on May 05, 2006
ask google but I doubt they will work together
RCA Televison &... | Answered 3 days ago
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Search the site by type in the brand in its search box.
RCA Televison &... | Answered on Feb 12, 2020
Try these codes. [1294, 1285, 2106, 2176]. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Start getting paid each month more than $17,000+ just by w0rking 0nline from home. Last month i have earned and received $18539 from this easy 0nline j0b. This 0nline j0b is just amazing and regular earning from this are just awesome. Start making extra dollars 0nline just by follow instructions on this website....HER
Heres what I do... .............. http://www.jobs120.com
RCA Televison &... | Answered on Feb 11, 2020
If there is one it will be listed on the controllers web site.
RCA Televison &... | Answered on Feb 05, 2020
RCA F25645 25" TV Logo
Popular Tags
19 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
25 inch rca model
  • Televison & Video
