20 Most Recent RCA 36F530T 36" TV Questions & Answers
Hello
There may have some problem with its power supply regulator section. If you are handy, try to detect the faulty compnent/s.
RCA 36F530T 36"... | Answered on Mar 03, 2012
you can access guide plus from front panel switches. press menu and select no. 7 or 8 guide plus setup. it asks for zip code type in using another remote using keypad.
RCA 36F530T 36"... | Answered on Sep 17, 2011
It sounds like the convergence has failed, and if it is all over the screen and very pronounced I would check that the scan coils have not loosened and moved before I investigated for an electronic fault in the convergence circuit
I appreciate your vote if you appreciate my reply.
RCA 36F530T 36"... | Answered on Feb 26, 2011
this is no baru this is no opne this tv
RCA 36F530T 36"... | Answered on Jan 07, 2011
the v chip is your problem. you need to go in adjust your settings
RCA 36F530T 36"... | Answered on Sep 07, 2009
maybe a lizard is die inside and shock your power supply circuit
RCA 36F530T 36"... | Answered on Jul 01, 2009
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
RCA 36F530T 36"... | Answered on May 02, 2009
vertical deflection failure. either solder on vertical ic, or bad capacitors in vertical circuit, and bad resistor &or ic failure. we fix these in home for 150.00 including 1-year warranty and trip. (oh plus tax for the next stimulus) mch
RCA 36F530T 36"... | Answered on Mar 10, 2009
There is a good chance that the failure is in the main power supply.
A second chance is that the set is protecting itself from a failure after the supply; this is more likely to occur in the horizontal section where the highest power consumption occurs.
If the failure is in the supply, it could be a fairly reasonable cost repair. If in the horizontal section, depending on whether the failure is limited to a $10 horizontal output transistor or a bad flyback transformer. The transformer should still be available but with markup, shipping and installation, the cost could exceed the $100 US mark.
Generally, I have been recommending folks repair their old standard definition sets, buy a converter box for digital TV, and not dispose of them since the flat panel sets are dying like flies, often just after the warranty expires.   This would at least provide some kind of set when the expensive LCD or plasma sets go belly up.
RCA 36F530T 36"... | Answered on Mar 09, 2009
hit pictue tube w open palm if colors move crt shot.  if not magnatized need degaussing.  or defl youk loose.
RCA 36F530T 36"... | Answered on Nov 30, 2008
Are there any external speakers next to your tv? The magnets in the speakers will cause this effect to happen. If you do, relocate them and the pattern should go away.
The set has gone into protective shutdown. This is to prevent further damage. The most common part failure is hte horizontal output transistor. This is a 3-legged part attached to a heat sink close to the flyback transformer (part with large red wire coming out of the top). Try replacing that part.
Keep us posted.
Dan
RCA 36F530T 36"... | Answered on Sep 03, 2008
The text box function of the closed captioning is on. There may be a button on the remote to turn it off or you may have to go into the menu to do it.
RCA 36F530T 36"... | Answered on Aug 25, 2008
Bad flyback transformer part # 257807 possible damage to horiz out xistor # 237470...change transformer first,then xistor if you
must.....no generic....OEM quality only........T.
RCA 36F530T 36"... | Answered on Mar 10, 2008
what do you mean only to plugs in front does it have scart lead in back of dvd and in back of telly or do you mean that you only have to plugs that are different colours let me know
RCA 36F530T 36"... | Answered on Feb 08, 2008
RCA 36F530T has a component video input, plus 2 rear and 1 front composite video and audio inputs
http://www.amazon.com/RCA-36F530T-36-TruFlat-TV/dp/tech-data/B0000BZHA2/ref=de_a_smtd
RCA 36F530T 36"... | Answered on Jan 19, 2008
I read your article every thing is clear , Thanks for sharing.
http://quick-product-activation.com/
http://en-us-office.com/
http://now-mcafee.com/
RCA Televison &... | Answered 3 days ago
Use code search on your RCA remote control to find something that works.If a search through all codes stored in the remote control fails, you may have to try a different one. All remote controls do not contain all possible codes.
RCA Televison &... | Answered on Mar 31, 2020
RCA 36F530T 36" TV Logo
21 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
rca tru flat came home
  • Televison & Video
