20 Most Recent RCA 20V500T 20" TV Questions & Answers
This TV has no TV/AV selection button at its front panel controls. You should have a remote control to select its inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Type in the "brand name" of your device, in the search box [at the top right] of the display window and press Enter. It will make surf easy.
RCA 20V500T 20"... • Answered on Jun 07, 2015
Hi,Without remote its not possible to disable child lock. If it possible to arrange the remote then you can do the following to override the lock.1.Press VOL+ on the remote and CHANNEL + on thefront of the TV at the same time. Enter New Pwd.will appear on the screen. (You must be in the Enterpassword screen when attempting this).2.Press the number buttons to enter a four-digit code.The code will appear on the screen as you enter it.3.Press OK to save the code.4.Press MENU repeatedly to exit the menu or the menuwill automatically disappear within a few seconds ifno buttons are pressed on the remote control
RCA 20V500T 20"... • Answered on Dec 16, 2012
Not a sure thing but I remember it being hold both vol up and channel up for several seconds to release the unit presuming it is actually locked.
RCA 20V500T 20"... • Answered on Dec 11, 2012
There is shorted component/s inside the circuit board. Contact any experienced service technician. This is not a user repairable work.
RCA 20V500T 20"... • Answered on Nov 18, 2012
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET. Try this link for more details.
RCA 20V500T 20"... • Answered on Sep 29, 2012
About which problem you're discussing with?
try checking your manual,that came with your tv.
If not try e-bay for a new remote.
RCA 20V500T 20"... • Answered on Sep 22, 2012
that cannot be done----what is set doing or not doing?
RCA 20V500T 20"... • Answered on Aug 29, 2012
There is not much to do that simply use the remote and go into Main Menu/Preference and set FPA lock to OFF.
If the TV is on it should say "FPA ON" eacg time you press a button. When in FPA mode, the only button on the TV that should work is the power button, and only to close the TV.  Press and hold the channel up button on the TV and press the volume up button at the same time. If this does not work repeat this but pressing the volume down button. With the original remote you would Press VOL- on the TV's front panel and then CLEAR on the remote for approximately 5 seconds.
If you have the non working original remote then follow the below link for information on having it repaired -
http://www.replacementremotes.com/store/productdetailp.cfm?productid=12853&categoryid=110
Good Luck!!
Thanks
RCA 20V500T 20"... • Answered on Jun 22, 2011
The dry solder might be in horizontal section
Check the out put transistor pins / Driver cct. / FBT pins.
RCA 20V500T 20"... • Answered on Jun 03, 2011
Same problem here, did you ever figure get an answer? If possible please reply to [email protected]. Thank You
RCA 20V500T 20"... • Answered on May 23, 2011
Unfortunately Its not that simple, every remote has its own codes for different brands. There isn't 1 set code for all brands of remotes so would have to know what type of remote it is and maybe we can find the info on the net.
RCA 20V500T 20"... • Answered on May 13, 2011
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
RCA 20V500T 20"... • Answered on Mar 20, 2011
It can be downloaded here
change file extension from .php to .pdf after you save it to your desktop
it will mention something about a font problem
I didn't notice a problem
RCA 20V500T 20"... • Answered on Feb 24, 2011
High Voltage leak coming from anode button ,it nees to be resealed. TV contains around 20,000 volts up to 22,000 volts . Tube must be discharged in oder to correct problem .
RCA 20V500T 20"... • Answered on Dec 27, 2010
Hello
You just try the following to open your TVs lock.
You must have its remote to unlock it.
OK.
RCA 20V500T 20"... • Answered on Dec 24, 2010
Televison & Video Logo
63 questions posted
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
tv sound but no picture
  • Televison & Video
